fstringham
Posted: Tue Jun 13, 2006 3:32 pm Post subject: Fiberglass tips for tip up |
Hi to all
Hate to change the subject (IFR or NOT)...........but I need some advice on
the type of fiberglass / carbon cloth (Bi or Uni), and resin / hardner (
West Systems, Aero epoxy) types to start the fiberglass portion of the tip
up canopy build. Best vendors would also be appreciated. I have searched the
archives and google for info but need some more info to make the final
choice.
TIA
Frank (at) SGU and SLC Canopy and looking for $$$$$$$$$$$$$ to finish the
project
lhelming(at)sigecom.net Guest
Posted: Tue Jun 13, 2006 4:37 pm Post subject: Fiberglass tips for tip up |
I used West Systems. I'd do it again. Larry in Indiana
sarg314(at)comcast.net Guest
Posted: Thu Jun 15, 2006 10:01 pm Post subject: Fiberglass tips for tip up |
Frank:
You don't have to use fiberglass at all. I didn't like the idea of
epoxying fiberglass to the aluminum. It would make changing out the
canopy very difficult. I followed the instructions in the RV-ator for
making the front fairing from a sheet of 0.025 aluminum. It took an
afternoon. My third attempt fit perfectly. Fiberglass would have taken
much more time. I can remove it by drilling out the soft pop rivets
that hold it in. Lexel seals the aluminum to the plexi. I like to make
things so they can be disassembled.
Frank Stringham wrote:
Hi to all
advice on the type of fiberglass / carbon cloth (Bi or Uni), and resin
/ hardner ( West Systems, Aero epoxy) types to start the fiberglass
portion of the tip up canopy build. Best vendors would also be
appreciated. I have searched the archives and google for info but need
some more info to make the final choice.
TIA
the project
Tom Sargent, RV-6A
Posted: Fri Jun 16, 2006 3:09 am Post subject: Fiberglass tips for tip up |
I built mine from fiber glass and it is removable also. I laid it up on the
canopy/canopy frame after covering it with a layer of plastic saran wrap.
After it sets up, pop it loose. Sand and finish it, paint it, drill it and
attach with screws. I also used some Lexel sparingly. Works great after
100+ hours of flight. No chance of accidentally sanding into your canopy
like with other fiberglass attachments. Only down side is it takes about a
week or so to get a perfect finished product. If I was good with metal I
might of tried that method. However, fiber glass is a great way to get a
real quality finish. I am working on a targa strip now using the same
method. Larry in Indiana
timbolton(at)therv7.com Guest
Posted: Fri Jun 16, 2006 4:29 am Post subject: Fiberglass tips for tip up |
sarg314,
Any chance we can get some photos?
