Manifold Pressure
JBernier(at)dart.org
PostPosted: Thu Jun 15, 2006 11:46 am    Post subject: Manifold Pressure Reply with quote
Can anyone supply me with the manifold pressure for their stock 285 hp CJ engine? Also supply the density altitude at which it was taken. Take it at full power, and cruise speed. I'm using no filter at all and the inlet is sealed. I'm assuming both engines are in good condition. Cheese grater only.
Jim B
>> threein60(at)yahoo.com 06/14/06 6:14 PM >>>
Can someone tell me the thread size of the stock 285hp engine? I tried
the standard 18mm adaptor that I use on my other aircraft to do a compression test and no luck.. Don't want to go out and get a 14mm if that is not the size.
Thanks in advance.
Larry
Larry Pine
dsavarese(at)elmore.rr.co
PostPosted: Thu Jun 15, 2006 12:32 pm    Post subject: Manifold Pressure Reply with quote
The plug thread size is 14 mm.
Dennis
