		cooprv7(at)yahoo.com Guest
				 Posted: Tue Oct 15, 2013 1:33 pm    Post subject: Comm Antenna |
				I have been using a simple bent whip antenna on the bottom of my RV-10 for 7 years, but the signal has been getting weaker and I'm looking at upgrading.  I looked in the archives but seemed to miss a discussion that I'm sure has been made, but I was wondering how much better antennas like COMANT's CI-122 are over the significantly cheaper bent whip?  I'm using the low drag antenna on the cabin roof for COMM 2 and it works great.
 Marcus
				 Posted: Tue Oct 15, 2013 3:10 pm    Post subject: Comm Antenna |
				On 10/15/2013 5:28 PM, Marcus Cooper wrote:
 The bent whip antennas don't get 'weaker' ..... unless they're filthy.
 I think something is deteriorating .... most likely a kink or bend in
 the coax to the antenna or the connection at the antenna.  Putting an
 expensive antenna on the bad coax won't improve things much.
 Linn
  	  | Quote: | 	 		      I looked in the archives but seemed to miss a discussion that I'm sure has been made, but I was wondering how much better antennas like COMANT's CI-122 are over the significantly cheaper bent whip?  I'm using the low drag antenna on the cabin roof for COMM 2 and it works great.
 It's a lot of work but you might swap antennas to see what's up.
 Linn
  Marcus
  Checked by AVG - www.avg.com
		Bob Turner
				 Posted: Tue Oct 15, 2013 3:17 pm    Post subject: Re: Comm Antenna |
				Getting weaker? Antennas don't wear out in 7 years. Is it relatively clean? I would look under the antenna for oxidation or corrosion.
  _________________ Bob Turner
RV-10 QB |
		aerosport1
				 Posted: Tue Oct 15, 2013 3:44 pm    Post subject: Comm Antenna |
				Lynn
 Have you had the com checked to see if it is ok. I had an issue with my 430
 Nav portion. Single was getting weaker
 And weaker. Changed antennas checked everything spent 6 months chasing this and it turned out to be the
 430. The sad thing it was still in warranty when it started but by the time
 I found it, it was out by 3 months Garmin still charged me 1000.00 to repair.
 Geoff Combs
 Geoff Combs
 Aerosport Modeling
 On Oct 15, 2013, at 7:02 PM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
  The bent whip antennas don't get 'weaker' ..... unless they're filthy.  I think something is deteriorating .... most likely a kink or bend in the coax to the antenna or the connection at the antenna.  Putting an expensive antenna on the bad coax won't improve things much.
  Linn
  Linn
 > Thanks,
 > Marcus
 > No virus found in this message.
  _________________ Geoff Combs
 RV-10 QB N829GW
Flying 500 hrs
40033 |
				 Posted: Wed Oct 16, 2013 6:36 am    Post subject: Comm Antenna |
				Thanks for all of the responses, pretty consistent answers so I'll check out the connections.  I've been doing some touch up work in preparation for possibly putting the airplane on the market as 4 seats just isn't enough anymore and it seemed like a good idea to upgrade the antenna if it would make a difference, but it sounds like it really wouldn't.  Hate the idea of ever letting the machine go, but the mission seems to be changing a bit
 Marcus
 On Tue, 10/15/13, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
  Subject: Re: Comm Antenna
  Date: Tuesday, October 15, 2013, 7:17 PM
  "Bob Turner" <bobturner(at)alum.rpi.edu>
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p=410654#410654
  Forum -
     - MATRONICS WEB FORUMS -
  List Contribution Web Site -
                -Matt
  Dralle, List Admin.
