tmoushon(at)gmail.com Guest
Posted: Sat Oct 26, 2013 2:58 pm Post subject: Dynon D10A EFIS |
I am Considering the Dynon D10A as a backup EFIS. I noted that the operating temp range limit was 122°F on the high side. As a reference point, I compared it to the temp range of the L-3's Trilogy ESI-1000 which is 165°F on the high side. I would appreciate the observations from those of you that have used this unit. Thanks
cooprv7(at)yahoo.com Guest
Posted: Sat Oct 26, 2013 3:25 pm Post subject: Dynon D10A EFIS |
Terry,
I use the D10A as a backup and have been very pleased with it. The internal 2 hour battery is what sold me initially (although in 2006 there weren't a lot of options). It does have some heat issues and I had to put a cooling fan above it (it is at the top of my stack) which conveniently serves as a defroster just in case. Since then I have had no problems whatsoever and it saved my bacon once already when the alternator gave out.
Marcus
Posted: Sat Oct 26, 2013 3:56 pm Post subject: Dynon D10A EFIS |
We used one as a primary for years. A few temp issues when parked in the sun for a period of time, but never in flight.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Oct 26, 2013, at 6:56 PM, Terry Moushon <tmoushon(at)gmail.com> wrote:
Posted: Sat Oct 26, 2013 4:02 pm Post subject: Dynon D10A EFIS |
More of the same: Â it's a good unit but it can overheat so plan accordingly. I installed a very small cooling fan after it blanked a couple times and it's been fine now for 1000 hrs.Â
On Saturday, October 26, 2013, Terry Moushon wrote:
| Quote: | --> RV10-List message posted by: Terry Moushon <[url=javascript:;]tmoushon(at)gmail.com[/url]>
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
     -Matt Dralle, List Admin.
--Dave Saylor
Kellym
Posted: Sat Oct 26, 2013 10:13 pm Post subject: Dynon D10A EFIS |
Why not go with the Dynon D1 that is less money, doesn't need pitot
static system hookups and gives you most of what the D10A will?
Granted you would be depending on GPS ground speed and ground track, but
in most cases that isn't a big deal if you know what the wind is at
point of intended landing. I guess it partly depends on where your main
EFIS connection to ADAHRS and pitot/static system is located. Mine is in
tail cone to avoid moving magnetic sources, so I didn't plumb pitot and
static lines up to instrument panel.
On 10/26/2013 3:56 PM, Terry Moushon wrote:
KCHD |
