Replacement bolts for lifting rings
recapen(at)earthlink.net
PostPosted: Mon Oct 21, 2013 3:56 am    Post subject: Replacement bolts for lifting rings Reply with quote
Does anyone have the correct designation number for the through bolts for the lifting rings?
I would like to remove the lifting rings and replace with the next size shorter bolts and nuts.
Ralph Capen
harley(at)agelesswings.co
PostPosted: Mon Oct 21, 2013 4:08 am    Post subject: Replacement bolts for lifting rings Reply with quote
Morning, Ralph...
Not sure which engine you have, as you used the plural of ring...I only have one ring on my O-235 (HAD one ring).  It was mounted with one of the case half bolts, so when I removed it, I just measured the existing case half bolt in the next hole over and used that size AN bolt/nut to replace the longer one that held the ring in place.
Larger engines may have a different attach method, however, so this may not apply in those cases.
Harley Dixon
Long EZ N28EZ
On 10/21/2013 7:55 AM, Ralph E. Capen wrote:
--> LycomingEngines-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net> (recapen(at)earthlink.net)
Ralph Capen
PostPosted: Mon Oct 21, 2013 4:29 am    Post subject: Replacement bolts for lifting rings Reply with quote
IO360B1F6...two rings. One forward and one aft - on case half bolts like your single.
I would like to replace it with similar (coarse thread) about three sizes shorter.
Thanks.
carl.froehlich(at)verizon
PostPosted: Mon Oct 21, 2013 4:33 am    Post subject: Replacement bolts for lifting rings Reply with quote
These are standard AN hardware from Aircraft Spruce.
Carl
On Oct 21, 2013, at 7:55 AM, "Ralph E. Capen" <recapen(at)earthlink.net> wrote:
Ralph Capen
