asarangan(at)gmail.com Guest
Posted: Sat Oct 26, 2013 7:58 pm Post subject: Pip pin logic |
I am hoping someone can help me understand the logic behind the spar
pip pin. According to a posting by Neville Eyre some time back, the
pin is important for preventing the spar tang from migrating aft and
jamming the aileron crank. This makes sense, especially given how
close the spar is to the cranks. However, in my limited experience, I
have only seen pins used for shear stresses, not longitudinal stress.
The latter would mean the ball at the end the pin has to be load
bearing. This seems a bit odd to me, but I am sure there must be a
logic behind this setup. I am hoping someone can shed some light on
this for me.
Posted: Sun Oct 27, 2013 1:22 am Post subject: Pip pin logic |
Hi! Andrew,
I don't profess to be an authorised person to pass a professional comment
but since often I do ......!
It is an established fact that the wings fail forward which means that the
starboard spa tip will tend to want to be loaded towards leaving the port
pin AFT taking the metal socket with it off the port spa. Without the pip
pin the only restraint will be the CUFF which is wrapped round both spa's in
their centre portion and the socket bonded to the aft of the Port spa . So
an additional restraint on the starboard spa tip to keep it clamped to the
aft side of the Port spa when rigged is an obvious bonus.
( Just in passing it would be of prime interest as to the state of all these
items on the William Mills catastrophe aircraft? And surely the
investigators would do us all a big favour to circulate such fine detail for
our consumption?)
However to improve on the pip pin being used for this purpose I think would
need a pin threaded for a nut to be tightened and if you can develop a way
of access to a fully assembled aircraft for applying a bolt and nut I would
be pleased to hear of it ! In the meantime the pip ball rules!
Best regards
Bob Harrison G-PTAG
craigb(at)onthenet.com.au Guest
Posted: Sun Oct 27, 2013 2:48 am Post subject: Pip pin logic |
Bob, and all others of course
I like you and no doubt quite a few others have given the threaded bolt
option
You mention quite some thought, spending a lot of time traveling for work
Gives you the luxury of time to ponder such small things, the main issue
I have over switching to some sort of threaded arrangement is the alignment
issues
With the pin now can be troublesome, now say it has the be PERFECTLY aligned
to
Get the thread to start without cross threading it, and it just got a whole
lot
Harder, of course you could use some form of stepped alignment with say a
3/8
Taper stepping up to the 1/2 inch thread and a caged nut that can move to
align
But not rotate, that was my idea anyway, but I don't think there is enough
space
Say 1/2 an inch, for the caged nut, plus then the tapered end of the bolt
sticking through
The nut. One option that did come to mind was something similar to a masonry
anchor
Where you slide the whole thing into a hole, and tighten the bolt(or nut)
depending
On the style and the unit in the hole expands at the end to lock itself into
the
Concrete. If you used an internal thread arrangement to pull a set of jaws
outwards
You could "grab" the back end of the socket where the balls are now, and
pull both spars
Then hard into the seat back, by simply tightening one bolt
HOWEVER
The device mentioned would likely be a custom made part, with springs etc to
ensure the jaws
Retract, I know of no such part at present.
Secondly, no doubt someone will weigh in with and it is a concern of mine
too
It is generally accepted the seat back is NOT contributing to transfer lift
loads etc
To the airframe, and that like most aircraft the wings do flex and move in
flight
If you have the spars firmly bolted to seat back then you remove that
movement potential
Completely and probably make the seat back a major load bearing component,
and who knows
What the result of that might be
Just my thoughts
Make of them what you will, the pin works ok, sure its not perfect, but
would
Something else be any better
craig
Posted: Sun Oct 27, 2013 3:27 am Post subject: Pip pin logic |
We know that the wings & spars have been proof tested to
10g and the force on the spar pin is principally one of
shear with the spar tip trying to depart downwards, and at
10g MAUW, the actual shear force is likely to be something
in excess of 3000kg.
In comparison to this, the tendency for the spar tip to
move backwards and disengage itself from the spar pin must
be very small and I have no doubt that the clever fellows
at Europa did their stress calculations and concluded that
the tension strength of the pip pin system was sufficient.
I suspect that reinventing that particiular wheel will
achieve nothing but risking not being able to get your
wings off somewhere down the line.
Regards, David Joyce, G- XSDJ
On Sun, 27 Oct 2013 20:48:18 +1000
"craig" <craigb(at)onthenet.com.au> wrote:
can develop a way
rules!
the threaded bolt
option
traveling for work
issues
to
it just got a whole
lot
3/8
that can move to
align
space
sticking through
anchor
the bolt(or nut)
depending
to lock itself into
the
pull a set of jaws
outwards
balls are now, and
pull both spars
bolt
HOWEVER
with springs etc to
ensure the jaws
a concern of mine
too
loads etc
do flex and move in
flight
you remove that
movement potential
bearing component,
and who knows
Just my thoughts
not perfect, but
would
craig
Un/Subscription,
Forums!
Admin.
Posted: Sun Oct 27, 2013 3:44 am Post subject: Pip pin logic |
Bob, The AAIB report on William's plane made it clear that
the starboard wing broke away from its spar. Although not
specifically mentioning the pins or the strap system, that
implies that thy hadnot failed before the forces became
big enough to break the spar. Regards, David
On Sun, 27 Oct 2013 09:21:26 -0000
Hi! Andrew,
leaving the port
round both spa's in
the Port spa . So
it clamped to the
bonus.
surely the
our consumption?)
can develop a way
rules!
Best regards
Bob Harrison G-PTAG
peterz(at)zutrasoft.com Guest
Posted: Sun Oct 27, 2013 3:48 am Post subject: Pip pin logic |
Under extreme load the spar pin is being twisted downwards (at the rear end). So it is no longer purely in shear, thus the tendency for the rear spar to slide off and the need for a pip pin and strap.
If the spar arrangement was a fork type (in many gliders) instead of the scissors that we currently have this twisting load would not exist.
Cheers,
Pete
| Quote: | On Oct 27, 2013, at 7:27 AM, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
We know that the wings & spars have been proof tested to 10g and the force on the spar pin is principally one of shear with the spar tip trying to depart downwards, and at 10g MAUW, the actual shear force is likely to be something in excess of 3000kg.
In comparison to this, the tendency for the spar tip to move backwards and disengage itself from the spar pin must be very small and I have no doubt that the clever fellows at Europa did their stress calculations and concluded that the tension strength of the pip pin system was sufficient. I suspect that reinventing that particiular wheel will achieve nothing but risking not being able to get your wings off somewhere down the line.
> option
> issues
> to
> lot
> 3/8
> align
> space
> sticking through
> anchor
> depending
> the
> outwards
> pull both spars
> HOWEVER
> ensure the jaws
> too
> loads etc
> flight
> movement potential
> and who knows
> Just my thoughts
> would
> Regards
> craig Un/Subscription,
> Forums!
> Admin.
Posted: Sun Oct 27, 2013 3:58 am Post subject: Pip pin logic |
Thanks for that David but as ever photos speak thousands of words painful so looking would be to some.
Bob H G-PTAG
kingsnjan(at)westnet.com. Guest
Posted: Sun Oct 27, 2013 4:18 am Post subject: Pip pin logic |
I fully agree Pete and remember being shocked myself when I learnt how
Europa set up the spars. However, I would not like to try to redesign it
myself given the constraints within that small area. Europa made that
decision at the time and the set-up DOES work Ok.
Reminds me of an old mate of mine now deceased unfortunately . . . . . .
whenever I used to say "IF", he would always reply . . . . . "Yes, and IF
the dog didn't stop to shit, it would have caught the hare!"
In jest
Kingsley from Oz
do not archive.
Posted: Sun Oct 27, 2013 4:44 am Post subject: Pip pin logic |
I also agree, don't redesign something that has been proven..... Everything is an engineering compromise, and I assume tank capacity and simplicity was the original design intent.
Cheers,
Pete
| Quote: | On Oct 27, 2013, at 8:17 AM, "Kingsley Hurst" <kingsnjan(at)westnet.com.au> wrote:
I fully agree Pete and remember being shocked myself when I learnt how Europa set up the spars. However, I would not like to try to redesign it myself given the constraints within that small area. Europa made that decision at the time and the set-up DOES work Ok.
Reminds me of an old mate of mine now deceased unfortunately . . . . . . whenever I used to say "IF", he would always reply . . . . . "Yes, and IF the dog didn't stop to shit, it would have caught the hare!"
In jest
Kingsley from Oz
do not archive.
Posted: Sun Oct 27, 2013 12:25 pm Post subject: Pip pin logic |
I did speak to one manufacturer of "quick release pins" (on an
unrelated matter) who said that the load rating only applies to the
main shaft and not to the retaining mechanism (i.e. ball). This was
the reason for my original question.
In addition, I also recall seeing an email in this group who said
something was rattling around the belly, which turned out to be the
spar socket. There was no conclusion on why it had come off, but it
could be due to the pip pin ball slipping, allowing the spar to pull
the socket off.
The spacing between the spar and the aileron crank is just a few
millimeters. So if there is enough force to pull a socket off its
araldite bond, that same force can easily flex the spar enough to
interfere with the cranks, especially since the spars have a lot of
flex in the lateral direction.
On Sun, Oct 27, 2013 at 6:48 AM, craig <craigb(at)onthenet.com.au> wrote:
option
issues
to
lot
3/8
align
space
sticking through
anchor
depending
the
outwards
pull both spars
HOWEVER
ensure the jaws
too
loads etc
flight
movement potential
and who knows
Just my thoughts
would
craig
