wcm(at)tampabay.rr.com Guest
Posted: Sun Jan 01, 2006 8:50 am Post subject: Fuel tank cleaning |
I syphon the bottom of the fuel tank on my FS II regularly to remove debris
and whatever else is there.
I use a cheap squeeze bulb syphon hose/tube that you can get almost
anywhere.
I put about a two foot length of straitened coat hanger wire inside the
syphon end of the hose/tube to keep it ridged and then syphon the bottom of
the tank through a Mr Funnel into a small gas can.
This way, I don't lose any fuel and the tank is free of trash.
Works just like a pool cleaner.
Chris Mallory
