				 Posted: Wed Mar 14, 2007 2:03 pm    Post subject: A possible suggestion |
				Lately I have become pretty deeply involved in Yak electrical issues.
 One part of the Yak (and other Russian aircraft)in the overall design
 seems to have a pretty significant failure rate, and also is difficult
 to impossible to replace, with the current "if you can find one" price
 being around $650 each.  This is the DNP-200A "Combined Device" detailed
 in my White Paper posted several weeks ago.
 I may indeed have become "overly sensitive" to this issue and my
 up-coming suggestion may indeed be over-kill.  I will leave that up to
 each persons individual judgment or even open debate for that matter.
 That said, I personally am going to modify my operating habits a little
 bit.  Namely, I am going to start my engine from now on with the
 generator switch in the OFF position.  I am going to LEAVE if off for
 all taxi operations.  I am ONLY going to turn it on when performing the
 pre-take-off run up, and of course I will then leave it on for the rest
 of the flight.
 After landing, I will turn the generator switch off immediately and
 leave it off even past engine shut-down.
 Why am I doing this?
 Because every single time you increase engine RPM to about 40% or so,
 the generator comes on right?  No... Not really.  The generator is on as
 soon as you start the engine.  The generator VOLTAGE only gets high
 enough around 40% or so and then the DNP-200A contactor relay closes and
 generator power is fed to the bus.  Reduce engine speed back to idle,
 and what happens?  REVERSE current flows TO the generator and the
 DNP-200A contactor OPENS (at least we hope it will) and generator power
 is REMOVED from the aircraft bus and the generator LIGHT comes on.
 Consider if you will how many times this happens from when you first
 start until you are ready to take off.
 Reducing the amount of times this happens will extend the life of the
 DNP-200A Combined Assy.
 Is it worth taking such a step in order to extend the life of this part?
 You be the judge.
 Mark Bitterlich
 N50YK
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		david(at)mcgirt.net Guest
				 Posted: Wed Mar 14, 2007 3:41 pm    Post subject: A possible suggestion |
				Mark,
  Very good points, I just finished REPLACING my regulator and alternator in
 my TW - purely due to a DOS error... ( Dumbass Owner Syndrome )
 My batteries we low, and instead of pulling and charging, I started up, and
 let them charge off the alternator at low RPM.. thus burning up a 50 AMP
 Alternator and regulator...  That would have worked ( although, still not
 the right was to go about it.. )  if I would have waited to after takeoff,
 at high RPM, thus getting the full capability of the Alternator..
   After owning up to my error to the Manufacturer, they also asked if I was
 starting and shutting down with the Alternator on, and HIGHLY recommended
 turn it off during these low RPM areas.. as you suggested..
 I know Gen's and Alternator are not the same, but the practice should help
 all..
 Just my $750 worth of experience.. that is a lot of gas money wasted..
 David
		dsavarese(at)elmore.rr.co Guest
				 Posted: Wed Mar 14, 2007 3:53 pm    Post subject: A possible suggestion |
				Mark,
 I like your suggestion and plan on implementing that procedure beginning
 with the next time I fly.  Thanks for taking the time to "educate" our
 group.
 Dennis
				 Posted: Wed Mar 14, 2007 4:07 pm    Post subject: A possible suggestion |
				Thanks David for sharing your experience.   When I went through my own
 electrical nightmare, I came close to just bagging the whole mess and
 going the "American way", namely by converting to the exact same system
 you have in your TW.  There is no question that it is the 'cat's meow'.
 Then I started to think about it and wondered if there was any
 circumstance where you could blow that really beautiful but very
 expensive Alternator!  Hmmm, thanks for THAT education!   I then decided
 to sweat some more and see if I could figure out what really was wrong
 with my Russian system.  At least with it, the parts are cheap....
 EXCEPT for that dang DNP-200A thing.  So, bottom line is that any way
 you look at it, you're damned if you do, and damned if you don't.
 By the way, sooner or later all of our readers here are going to
 experience the "DNP-200 syndrome".  I am thinking about going into
 business repairing them...
 Dennis.... Thanks for your comments as well.  The way I look at it, it
 can't hurt anything, and if your batteries go dead that fast, it's
 better to know that sooner than later as well!
 Mark
		drc(at)wscare.com Guest
				 Posted: Wed Mar 14, 2007 6:54 pm    Post subject: A possible suggestion |
				Exact same experience in mine with the same advice from the
 manufacturer.  We have been starting on air (or battery electric
 start) then not turning on alternator until run up.  Shutting down
 the alternator when turning off the runway.. so far so good.
 Herb
 On Mar 14, 2007, at 6:40 PM, David McGirt wrote:
  Mark,
  alternator in
  up, and
  50 AMP
  still not
  takeoff,
  if I was
  recommended
  should help
  all..
  David
				 Posted: Wed Mar 14, 2007 7:51 pm    Post subject: A possible suggestion |
				Hey, I'm having the BMP 200 issue as this thread unravels. I agree with the
 idea whole heartedly. That reverse current thing is real. To high a voltage
 and the 50 fuse to the battery fries too. Will be doing a voltage check on
 the generator side of the DNP 200 tomorrow to see what else is or is not
 working after that failure. Hopefully it is just the DNP 200A. That cost
 just about as much as Dave's B&C Alternator/ regulator by itself. And to
 think it all started with flickering indicator lights and volt meter only
 to fully crap out within 24 hours.
 Doc
 [quote] [Original Message]
  To: <yak-list(at)matronics.com>
  Date: 3/14/2007 10:00:03 PM
  Subject: Re: A possible suggestion
  Herb
  > Mark,
  > alternator in
  > up, and
  > 50 AMP
  > still not
  > takeoff,
  > if I was
  > recommended
  > should help
  > all..
  > David
		jan.mevis(at)informavia.b Guest
				 Posted: Wed Mar 14, 2007 9:54 pm    Post subject: A possible suggestion |
				This seems to be a very good suggestion. I always switched on the generator
 AFTER the start, but it certainly is not too bad an idea to wait with the
 generator until applying full power. Thanks, Mark!
 Jan Mevis
		pa3arw(at)euronet.nl Guest
				 Posted: Thu Mar 15, 2007 12:06 am    Post subject: A possible suggestion |
				Mark,
 It's a dc-generator, so a high current diode ( e.g. from an old ac car
 generator) helps as well from preventing reverse current. The only thing is,
 you loose 0,5v over the diode....but I'm sure we can live with that...
 Hans
 -----Oorspronkelijk bericht-----
 Van: owner-yak-list-server(at)matronics.com
 [mailto:owner-yak-list-server(at)matronics.com] Namens Roger Kemp
 Verzonden: donderdag 15 maart 2007 4:51
 Aan: yak-list(at)matronics.com
 Onderwerp: Re: A possible suggestion
 Doc
  Herb
  > Mark,
  > alternator in
  > up, and
  > 50 AMP
  > still not
  > takeoff,
  > if I was
  > recommended
  > should help
  > all..
  > David
		Mozam
				 Posted: Thu Mar 15, 2007 4:14 am    Post subject: A possible suggestion |
				 	  | Quote: | 	 		  >>>From: "David McGirt" <david(at)mcgirt.net>
 Subject: RE: A possible suggestion
 Mark,
  Very good points, I just finished REPLACING my regulator and alternator in my TW - purely due to a DOS error... ( Dumbass Owner Syndrome )
 My batteries we low, and instead of pulling and charging, I started up, and let them charge off the alternator at low RPM.. thus burning up a 50 AMP Alternator and regulator...  That would have worked ( although, still not the right was to go about it.. )  if I would have waited to after takeoff, at high RPM, thus getting the full capability of the Alternator..
   After owning up to my error to the Manufacturer, they also asked if I was starting and shutting down with the Alternator on, and HIGHLY recommended turn it off during these low RPM areas.. as you suggested..<<<<
 Dave,
 Been there, done that, got the T-shirt.  DO NOT try to charge low batteries with the alternator in our TW’s.
 Also, besides the vastly improved CG, this is another good reason to move the batteries up in front of the oil cooler.  They are VERY easy to access for charging.  You don’t even have to remove them.  Just pop several fasteners, the batteries swing down, and connect the charger.  Piece of cake!
 I have one question about turning on the alternator just prior to takeoff, and I admit I am an electrical moron.  Is there any concern that your first indication of a bad electrical problem (like an electrical fire) will be during, or just after takeoff?
 Steve Dalton
		Rob Rowe
  Joined: 10 Jan 2006 Posts: 124 Location: Berkshire, UK
				 Posted: Thu Mar 15, 2007 5:42 am    Post subject: Re: A possible suggestion |
				A few other related thoughts ... regardless of whether you have the generator on OR off while taxying;
 The PAG-1 & PT200 inverters take c.20 Amps DC power ... over half a kilowatt of power from your battery!
 So if the generator is offline (of its own volition or has been turned off) it's a good idea to keep the invertors off too, as this helps prevent your batteries from getting hammered. If you've strobes fitted these can also be quite power hungry.
 Secondary benefit of taxying with inverters off (especially on rough surfaces) is that the gyros are consequently de-powered, this saves a lot of wear & tear on their delicate bearings (gather this is common practice in Russia ... 2nd hand info from someone who had instruction from Azat Zaydullin).
 Might be good practice to have the generator on-line for the power checks, as before commiting aviation it would be good to know that;
 - the DC power system will regulate at high RPM
 - the generator will disconnect at low RPM
 - the gyros have had time to spool up (think a minimum of 2 minutes is specified), assuming you've just turned the invertors on too
 After clearing the active on landing I add the following to the stop / brakes on / identify & operate flap lever / fully open oil & air cowls regime.
 - shed unnecessary electrical loads (strobes / ADF / slaved DI / PAG-1 / PT200)
 If you want to turn the generator off too, this is a good time to add it to your check list.
 Cheers, Rob R
				 Posted: Thu Mar 15, 2007 12:37 pm    Post subject: A possible suggestion |
				That is in fact true, and is a perfectly sound suggestion.
 Where you are going with this is basically engineering a simple and
 total replacement for the DNP-200.  I have been thinking along the exact
 same lines.  To cover any voltage spikes, I was thinking that the
 reverse voltage spec on the diode should be at least double (if not even
 more) the supply voltage, and probably rated for between 50 and 75 amps.
 Such devices are not CHEAP, but they are obtainable. Car alternator
 diodes?  Are they rated high enough current?  Maybe even use two in
 parallel for safety?  Couple that with a good main line 28 VDC 100 amp
 contactor (or less maybe), and you could then easily adapt that right
 into the rest of the existing Russian designed circuitry.
 Thanks Hans.  Great thought.
 Mark Bitterlich
		rogerbyak(at)yahoo.com Guest
				 Posted: Fri Mar 16, 2007 7:11 pm    Post subject: A possible suggestion |
				Is there any specific operating procedure in the Pilots Manual concerning this practice?
   This is well "beyond me" and my understanding of the systems, but why has it been a common practice to tie wire the generator switch in the closed position on CJ's delivered by some west coasters?; with some advice that if the switch were opened, it would result in failure of the generator?  rb
 "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil> wrote:
   [quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E"
 Mark
 -----Original  Message-----
 [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of David McGirt
 Sent: Wednesday, March 14, 2007 19:40
 To: yak-list(at)matronics.com
 --> Yak-List message posted by: "David McGirt"
 Mark,
 Alternator..
 help all..
 David
