keystone(at)gci.net Guest
Posted: Thu Mar 15, 2007 8:36 am Post subject: Jury struts full of water |
I was installing the fairings on my lift struts last night. When I was drilling the jury strut I found it was full of water. I suggest you install a drain hole in your jury struts.
Bill Wilcox
N801BW
Valdez, Alaska
280 hrs
Installing lift strut fairing, fixing gas tank leak and waiting for better flying weather
Just passed CFI and FOI written
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Mar 15, 2007 3:59 pm Post subject: Re: Jury struts full of water |
Are the struts steel or aluminum? If steel it might be an idea to pour some linseed oil, tubeseal or other anti-corrosion material into them and slosh it around. Pour out the excess. Those of us who fly old airplanes have been doing that for years.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
n801bh(at)netzero.com Guest
Posted: Fri Mar 16, 2007 5:08 am Post subject: Jury struts full of water |
I guess the bigger question is, if the struts are welded up tight on each end, as mine were from the factory and the only holes in them are from the jury strut mounting area. Is it possible for that much water to get in through those little spots??
Ben Haas
N801BH
www.haaspowerair.com
-- "Tim Juhl" <juhl(at)avci.net> wrote:
--> Zenith-List message posted by: "Tim Juhl" <juhl(at)avci.net>
DO NOT ARCHIVE
______________
CFII
Champ L16A flying
Working on wings
http://forums.matronics.com/viewtopic.php?p=100876#100876
<======================== - The Zenith-Lbsp;the many List utilities such as the --> http://www.matronics.com/Navigator?Zenith-List
_-================================================sp; - NEW p;content now also available via the Web&n=======================================
pacificpainting(at)comcas Guest
Posted: Fri Mar 16, 2007 5:28 am Post subject: Jury struts full of water |
Ben,
I just looked at my struts. They are welded tight on the end that goes on the wing strut, but are open on the other end where the mounting tabs are. Can there be that much condensation collecting inside? Maybe I'll just pour them full of epoxy primer and let it run out before mounting.
Dave in Salem
Posted: Fri Mar 16, 2007 5:43 am Post subject: Jury struts full of water |
Upon further thought, My struts might be wide open on each end with no way of trapping water. I am headed to the airport right now to look. Stay tuned. <G>
Ben Haas
N801BH
www.haaspowerair================================================p;Use the Matronics List Features Navigator&nbshive Search & Download, 7-Day Browse, ======================== Same great content now also available&nbs================================================
Posted: Fri Mar 16, 2007 12:36 pm Post subject: Jury struts full of water |
I just got back from the airport and my main struts are open on each end, no way for water to collect there. The jury struts are welded on the bottom and open on top. Your idea of pouring them full of something is not a bad idea. I am guessing that Bills plane lives outside and therefore driving rain must somehow get into the jury struts. Mine has never spent the night outside so that must be why mine are dry. If we do drill a hole where is the best place so as to not create a stress riser?
Ben Haas
N801BH
-- "Dave Ruddiman" <pacificpainting(at)comcast.net> wrote:
Ben,
Dave in Salem
Posted: Fri Mar 16, 2007 2:07 pm Post subject: Jury struts full of water |
I'm wondering, how does water get in when the jury struts are mounted on the plane? Mine won't be on for awhile, but it seems like rain would have to blow pretty hard to get in the top, and there would have to be a lot of condensation to be able to pour water out. I'm not sure where to drill a drain hole or if one is really needed. Has anyone else had this problem, or is this an isolated event? Lots of questions. Does anyone have better answers?
Dave
Posted: Mon Mar 19, 2007 8:30 am Post subject: Jury struts full of water |
My 801 has probably spent 30 days out of the hanger over the last 3 years. Much of that in rainy weather. Thank goodness the water that came out was clear. This means I did a fairly good job of painting the inside of the tubes. One concern I have is, I do not keep the heat on in my hanger and it was 20 degrees when I found the water. The heat from drilling the hole melted enough water for it to pour out. There was at least 1" of water above bottom of the tubes.
I talked to Jim Frisby about this 801 and he said he had his spilt jury struts split from the frozen water. I don't know when he noticed them. He is off on a new adventure at this time.
My recommendation stands, drill a small hole in the bottom of the jury strut to allow any water that accumulates to weep out.
Bill Wilcox
N801BW
Valdez, Alaska
still installing lift strut fairings.
