alnanarthur(at)sbcglobal. Guest
Posted: Fri Mar 16, 2007 7:37 am Post subject: 912ULS heavy duty starter ? |
List,
I have a Kitfox 5 with an early 912ULS engine which does not have the
heavy duty starter.
Can anyone tell me the dimensions of the heavy duty starter.
I have only about 1/2 in. clearance between the back of my present
starter and one of the
engine mount tubes.
Allan Arthur
Kitfox 5, N40AA
Rotax 912ULS, Warpdrive 3 blade
Byron Airport, CA (C83) Hanger C8
clint_bazzill(at)hotmail. Guest
Posted: Fri Mar 16, 2007 9:02 am Post subject: 912ULS heavy duty starter ? |
The only thing that the heavy duty starter does is turn the engine faster.
If you have a good starting procedure its a waste of money. Clint Half
Moon Bay
Subject: 912ULS heavy duty starter ?
Date: Fri, 16 Mar 2007 08:38:19 -0700
List,
I have a Kitfox 5 with an early 912ULS engine which does not have the heavy
duty starter.
I have only about 1/2 in. clearance between the back of my present starter
and one of the
engine mount tubes.
Allan Arthur
Kitfox 5, N40AA
Get a FREE Web site, company branded e-mail and more from Microsoft Office
rjdaugh
Posted: Fri Mar 16, 2007 11:27 am Post subject: 912ULS heavy duty starter ? |
Allan,
I had to modify (Actually Skystar did it for me!) my motor mount in order to
use the heavy duty starter. I suspect that you will need the modification.
In the absence of other problems, I think you should consider Clint's
advice.
Randy Series 5/7 912S
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Posted: Sat Mar 17, 2007 7:29 am Post subject: 912ULS heavy duty starter ? |
Clint, Randy and all,
Thanks for your reply. I have been using Clint's starting procedure
with success for some time but slowly
over some months it has been getting harder and harder to start.
When cranking with ignition switches on, it seems to fire once and
then the prop abruptly stops and unless
I release the starter, it continues cranking and then repeats this
several times. Then the carbs start to
overflow due to the shaking and the engine appears to be flooded.
I'm concerned that I may have a worn or defective sprag clutch. If
that is the case I'll have to pull the
engine and have it repaired ( big $$$ ). Then, I might as well go
for the heavy duty starter.
Maybe John Mcbean can modify my engine mount, or maybe a Series 7
engine mount might fit.
On Mar 16, 2007, at 12:28 PM, Randy Daughenbaugh wrote:
<rjdaugh(at)rapidnet.com>
Allan,
order to
modification.
advice.
