taffy0687(at)yahoo.com Guest
Posted: Fri Mar 16, 2007 5:58 pm Post subject: LRI gauge |
Folks,
I just ordered my LRI gauge for $11.95, they still have 715 left.(see link below).
[url=http://www.surpluscenter.com/item.asp?UID 07031616355052&item 1-1623&catname]http://www.surpluscenter.com/item.asp?UID 07031616355052&item 1-1623&catname[/url]=
I wished I'd had known about it when I had my 701, I just couldn't get use to that slow landing speed.
Thanks for the info,
Fritz 601XL, Corvair, 90/90 scratch builder
Don't get soaked. Take a[url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news] quick peek at the forecast [/url]
with the[url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news]Yahoo! Search weather shortcut.[/url] [quote][b]
dpfisher(at)scottsbluff.n Guest
Posted: Sun Mar 18, 2007 11:42 am Post subject: LRI gauge |
OK guys,
I give , if the LRI gauge is an air pressure instrument, what makes it
different from an airspeed indicator??
Dave, 701 with A-80-8 Continental
Posted: Sun Mar 18, 2007 1:10 pm Post subject: LRI gauge |
jetboy
Posted: Sun Mar 18, 2007 1:43 pm Post subject: Re: LRI gauge |
The LRI is not just ram air pressure like an ASI. Readings are derived from the difference in pressure between different surfaces in the airflow. The ports are either in the upper and lower wing surfaces or in a probe that is oriented in a similar way, and adjusted to respond at the correct angle of attack.
There is some further description at the site that supplies them, or at
http://www.ch601.org/resources/aoa/aoa.htm
I have not got one on my 701 yet, and following the discussion threads I'm still not decided on whether the instruments should be further complicated. What interests me is the difference in readings with flap / without flap, as this aspect would need to be consistent with both configurations, TO and landing, to be a reliable indicator for me.
After 170 hrs in the 701 I still find things unravel very fast at critical times and there is a lot of body language required in adjusting power / angle without time for looking at instruments or interpreting their meaning dependant on load / configuration. So I tend to favour the view, that for the 701, the seat of the pants will remain the primary indicator.
Ralph
_________________ Ralph - CH701 / 2200a |
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sun Mar 18, 2007 2:27 pm Post subject: LRI gauge |
I'll take a stab at this.
Both the ASI and the LRI are differential pressure gages, i.e., they
measure the difference in pressure between the two pressure taps on the gage.
The difference between the ASI and the LRI is in the location of the
pressure ports connected to the gage's pressure taps, and in the markings
on the face of each gage.
One ASI pressure tap is connected to the ram air port in the pitot (which
attempts to point directly into the relative wind); the other tap is
connected to the static air port which attempts to be normal to the
relative wind. If the pitot is directly into the relative wind, and the
static is normal to the relative wind, then there is a simple relationship
between the difference in pressure and the air speed. Bernoulli's law
applies here. When the pitot is not pointing into the relative wind (think
slow flight with a high angle of attack) or the static port is not normal
to the relative wind (think forward slip to a landing) then there will be
an error in the indicated air speed. That's why your Cessna 150 POH has a
table that relates indicated air speed to calibrated air speed. I think
they design the ASI so that the error is in your favor--i.e., the indicated
air speed suggests you are closer to a stall than you actually are. The
markings on the face of the ASI gage just graphically calculate the air
speed for the variation in the measured differential pressure between the
pitot and static.
The LRI pressure taps are connected to holes on two angled faces of the LRI
probe. The pressure from these two ports is related to each of the port's
angle with the relative wind. I.e., the closer a port is to directly into
the relative wind, the greater the pressure the port will see. As the angle
of the attack of the aircraft changes, the angles that each of these ports
makes with the relative wind also changes. If it is all designed and
adjusted properly, there should be a 1 to 1 relationship between the
measured differential pressure and the angle of attack. So, you can mark
the face of the LRI to indicate how close you are the critical angle of
attack, i.e., the angle of attack at stall, typically about 18 degrees.
'Hope that helps.
Terry
At 01:01 PM 3/18/2007 -0700, you wrote:
| Quote: | OK guys,
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Just starting a 601 kit
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Posted: Sun Mar 18, 2007 4:21 pm Post subject: LRI gauge |
SEE BELOW FOR MESSAGE----- IT WAS BLANK ON THE FIRST ATTEMPT---- this is the second try.
Big Gee <taffy0687(at)yahoo.com> wrote:
[quote] Dave,
I think you'll find the link below very informative.
Fritz
http://www.liftreserve.com/
Dave and Pam Fisher <dpfisher(at)scottsbluff.net> wrote:
| Quote: | --> Zenith-List message posted by: Dave and Pam Fisher
OK guys,
Dave, 701 with A-80-8 href="http://answers.yahoo.com/dir/index;_ylc=X3oDMTFvbGNhMGE3BF9TAzM5NjU0NTEwOARfcwMzOTY1NDUxMDMEc2VjA21haWxfdGFnbGluZQRzbGsDbWFpbF90YWcx?link=ask&sid=396546091">great tips from Yahoo! Answers users.
grs-pms(at)comcast.net Guest
Posted: Sun Mar 18, 2007 5:21 pm Post subject: LRI gauge |
The air speed indicator measures the pressure difference between the free
stream and the static source, which (ideally)
is not affected by speed. This difference is, however, affected by the
density of the air, so true airspeed varies from indicated airspeed with
temperature and altitude. The LRI measures differential pressure between a
pair of ports with different alignments to the free stream. This pressure
varies with angle of attack, hence with varying lift coefficients. This
difference does not vary with density, so the lift reserve or stall margin
is accurately indicated at every temperature, altitude and aircraft weight,
once the LRI is properly calibrated.
George
Posted: Mon Mar 19, 2007 8:31 pm Post subject: LRI gauge |
Hi,
Thanks for the explanations everyone - makes sense now!!
Dave, 701, do not archive
jd(at)lawsonimaging.ca Guest
Posted: Tue Mar 20, 2007 1:34 pm Post subject: lri gauge |
Greetings...
Thanks to advice on this list, I just received a Dwyer 5000
gage from
Surplus Center. Thanks for passing that tidbit along!
Question: is there a trick to disassembling the gage to
replace (or
cover) the stock face with the new LRI face. And thanks,
too, to the
lister who posted the nice colour faceplate files!
john butterfield wrote:
hi list
i looked up doug naylor's suggestion and ordered a
guage at 12.00 plus shipping. a total of about 22.00.
a really good deal.
i also have the probe from from scott laughlin and its
a fine piece of work. for about 85.00 you can have a
first rate aoa system totally self sufficient from
electric power. again, please look into this system
as it will make your flying easier and may save your
life
thanks for the tip doug
john butterfield
601XL, corvair
torrance, ca
Regards, J.
flying: Zenith STOL CH701/912 C-IGGY, 350 hrs.
building: Sonex #325, Jabiru 3300/6, 85% completed
J. Davis, M.Sc. (computer science)
*NIX consulting, SysAdmin
email: jd at lawsonimaging.ca
voice: 519.289.1527 http://www.cleco.ca
c/o Brandywine Aviation 5507 Irish Dr., Appin, ON
N42 47.33 W081 36.50 31/13 2000+ x 60', elev: 740'
To most people the sky is the limit.
To those who love aviation, the sky is home.
Improve your performance by improving your attitude.
dbortol
Posted: Tue Mar 20, 2007 2:05 pm Post subject: lri gauge |
It's very easy, but it will be tight the first time. Hold the body of
the gauge in one hand. Palm the face of the gauge with the other hand
and rotate to the left.
On 3/20/07, j. davis <jd(at)lawsonimaging.ca> wrote:
Greetings...
gage from
replace (or
too, to the
<jdbutterfield(at)yahoo.com>
> hi list
> a really good deal.
> life
> john butterfield
> 601XL, corvair
> torrance, ca
Regards, J.
Posted: Tue Mar 20, 2007 3:15 pm Post subject: lri gauge |
Thanks! Worked like a charm. I used a couple of non-skid
mats I had
lying around. One to hold the gage, the other to turn the bezel.
Thanks also to 'CH701 (701stol)', who responded to me
personally!
Now: has anyone calibrated the needle? My panel is at an
angle, and the needle
doesn't quite 'zero'. My guess is that the two little
phillips head screws
at twelve o'clock will adjust the pressure on the diaphragm,
but I'm
just guessing. There's also a brass nut dead centre...
Dino wrote:
> Greetings...
> gage from
> replace (or
> too, to the
> > hi list
> > a really good deal.
> > life
> > john butterfield
> > 601XL, corvair
> > torrance, ca
> Regards, J.
Regards, J.
Winners do what losers don't want to do.
