		pilotpat
  Joined: 23 Dec 2006 Posts: 14 Location: Williamsport, PA
				 Posted: Thu Mar 15, 2007 3:35 pm    Post subject: AD's question for airworthy cert |
				AD's Question - I am trying to get my kitfox airworthy certificate as a ELSA and the Faa says I forgot to put in the box the latest Note AD bi - weekly in publication at the time I signed the form (8130-6) Does anyone know what this number or current publication would be?  This is a kitfox classic iv and never flew yet and I purchased it mostly built.  it has the jabiru 2200A engine ....any help or link to these would be helpful.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Pilotpat
Kitfox Classic IV
Jabiru 2200
Williamsport , PA |
		eskflyer(at)lvcisp.com Guest
				 Posted: Thu Mar 15, 2007 4:07 pm    Post subject: AD's question for airworthy cert |
				You will not have any AD's pertaining to your aircraft if i understand it
 correctly . these only apply to Certified aircraft . You will however find
 service bulletins posted by the manufacturer or kit provider .
 John Perry
 Kitfox 2 N718PD
		kirkhull(at)kc.rr.com Guest
				 Posted: Thu Mar 15, 2007 4:58 pm    Post subject: AD's question for airworthy cert |
				When the FAA ask,  you built most of the airplane and way over 51%  and
 there are no AD's on experimental aircraft.  I looked at the Faa form on the
 web (FAA.GOV) and it has changed  sence the last time I filled one out.  I
 would suggest that you lic your plane as an Experimental/armature built.
 You will still be able to fly it as a sport pilot but the plane will not be
 limited to only what a sport plane can do.  This way the pilot will be the
 limiting factor and not the plane.  There may come a time when your planes
 needs to be able to do those things ( night flight).
		84KF Guest
		dcsfoto
				 Posted: Fri Mar 16, 2007 3:56 pm    Post subject: Re: AD's question for airworthy cert |
				First the AD Biweekly changes every two weeks. Yes ADs do not apply to our type aircraft but the FAA wants that block filled in on the Form 8130-6.
 will look like "2007-06"
 S-SLA must be built from a kit, that the mfg has built and certified at least one aircraft.
 E-LSA is called the "wild west" it is what the "fat" ultralights that are not 51%
 built are using.
 S-SLA have 2" LIGHT SPORT placards.
 E-LSA has 2" EXPERIMENTAL placards that is the easy way to tell diferance.
 Go E-LSA if you  did not build the and want to get a repairmans certificate
 all you need to do is go to a short ( 2 or 3 weeks ) school and get a
 E-LSA repairmans cert.
		pilotpat
				 Posted: Fri Mar 16, 2007 5:45 pm    Post subject: Re: AD's question for airworthy cert |
				Again, can't say it enought, What a great site this is and thanks to you guys for your input.  That is exactly what I needed, so I could fill in the block.  It was more my misunderstanding than anything else , as I just thought I didnt need to enter that info,  but the DAR explained to me what it was and along with you guys giving me the site location, I was able to find it and go thru things.   Learning lots, mostly from my mistakes and you all bailing me out...Was use to just flying the cherokee and Cessna till my friend got me into this kitfox flying..  so here I am,  probably will have a new quest for you soon.  as I need to write a flight plan.  any ideas....later
Kitfox Classic IV
Jabiru 2200
Williamsport , PA |
		Clem Nichols
  Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
				 Posted: Fri Mar 16, 2007 5:53 pm    Post subject: AD's question for airworthy cert |
				Re: ELSA repairman's certificate
 All you need to get the repairman's certificate (which enables you to do the
 annual inspection on your own ELSA plane) is to successfully complete the 16
 hour course.  The 2 or 3 week course enables you to inspect and work on your
 SLSA plane.  As I understand it, anyone, certificate or not, can work on any
 experimental plane.
 Clem Nichols
		84KF Guest
				 Posted: Fri Mar 16, 2007 8:43 pm    Post subject: Re: AD's question for airworthy cert |
				E-mail users..this post is best viewed through:
 http://forums.matronics.com/viewforum.php?f=8&sid=83b6acbe5602af72d6c023eab4688518
 The following is from ..., well you should know by know...
 44794 Federal Register / Vol. 69, No. 143 / Tuesday, July 27, 2004 / Rules and Regulations
 “The FAA believes
 that the maximum take-off weight is an
 appropriate limiting parameter for lightsport
 aircraft, because it is an objective
 measure that can easily be determined
 when the aircraft configuration is
 specified.”
 44808 Federal Register / Vol. 69, No. 143 / Tuesday, July 27, 2004 / Rules and Regulations
 Operating limitations
 specified in § 91.319 for experimental
 light-sport aircraft certificated under
 § 21.191(i)(3) are more restrictive than
 the operating limitations issued to
 special light-sport aircraft.
 In ‘‘experimental certificate,’’ the word
 ‘‘experimental’’ indicates that there is
 no known standard for the design or
 production of the aircraft. Therefore, the
 FAA believes that experimental
 certificates are appropriate for kit-built
 aircraft.
 Proposed paragraph (i)(2) addressed
 operating a light-sport aircraft that was
 assembled from an eligible kit. Proposed
 § 21.0193(e)(5) stated that the assembler
 of an aircraft, seeking certification under
 paragraph (i)(2), had to provide the
 instructions used to assemble the
 aircraft. There was no requirement in
 § 21.191(i)(2) that a person had to
 assemble the aircraft in accordance with
 the manufacturer’s assembly
 instructions. In the final rule, therefore,
 § 21.191(i)(2) now includes the
 requirement that the aircraft kit be
 assembled in accordance with the
 manufacturer’s assembly instructions
 that meet an applicable consensus
 standard.
 A commenter stated that experimental
 certificates should not be issued for
 light-sport aircraft that are not intended
 for experimental use but are intended to
 be mass-produced on production line.
 The commenter said that the FAA
 should create another status for aircraft
 whose certification falls between
 current type-certificated aircraft and
 true experimental aircraft. The FAA
 believes that the special light-sport
 aircraft certificate serves this purpose.
 aircraft.
 The same commenter noted that
 proposed § 21.191(i) would allow
 certification of aircraft carrying persons
 for compensation or hire that have never
 been shown to meet any design or
 production airworthiness standard. The
 FAA notes that these aircraft will not be
 permitted to be used for the full range
 of compensation or hire operations
 normally carried out by aircraft with
 standard airworthiness certificates.
 Operating limitations for these aircraft
 will restrict their use, as specified in
 § 91.319. The commenter also stated
 that there is no rigid conformity
 requirement for kit-built aircraft
 certificated under this section. The FAA
 disagrees and notes that an applicant
 seeking to certificate a kit-built aircraft
 under § 21.191(i)(2) must also comply
 with § 21.193(e) and provide a statement
 of compliance issued by the aircraft’s
 manufacturer that contains the
 information generally required by
 § 21.190(c). The commenter was also
 concerned that an operator of a special
 light-sport aircraft could decide to
 obtain an experimental light sport
 certificate when that operator no longer
 intends to comply with the more
 stringent operating limitations of the
 special light-sport aircraft. The
 commenter asserts that the operator
 could still engage in many of the
 operations permitted for special lightsport
 aircraft without meeting those
 more stringent limitations. The FAA
 disagrees. Operating limitations
 steve
		kitfox69(at)earthlink.net Guest
				 Posted: Sat Mar 17, 2007 1:44 am    Post subject: AD's question for airworthy cert |
				Clem,
  Just for varification, only the builder with a repairmans certificate
 issued for his plane can work on it and he cannot work on
 any other airplanes. A certified FAA A&E is the only other person who is
 authorized to work on experimental or certified aircraft.  Floyd
  	  | Quote: | 	 		   [Original Message]
  Date: 3/16/2007 9:57:17 PM
  Subject: Re: Re: AD's question for airworthy cert
 the
  	  | Quote: | 	 		   annual inspection on your own ELSA plane) is to successfully complete the
 16
  	  | Quote: | 	 		   hour course.  The 2 or 3 week course enables you to inspect and work on
 your
  	  | Quote: | 	 		   SLSA plane.  As I understand it, anyone, certificate or not, can work on
 any
 [quote] experimental plane.
  Clem Nichols
		84KF Guest
		Clem Nichols
				 Posted: Sat Mar 17, 2007 3:06 am    Post subject: AD's question for airworthy cert |
				Floyd:
 I don't know if it applies to all experimental airplanes or just to
 experimental light sport aircraft, but I was taught in the 16 hour LS1
 repairman course I attended that an ELSA "can be maintained by anybody".
 The annual condition inspection must be done by an A&P or the owner as a
 light-sport repairman with an "inspection" rating.  I can work on and do the
 annual inspection on my own ELSA, but not on someone elses.  Nor can I do
 the initial inspection in order to obtain an airworthiness certificate.  I
 don't have the time right now to try and look it up in the fed regs, but
 will try later this weekend.
 Clem
		akflyer Guest
				 Posted: Sat Mar 17, 2007 7:04 am    Post subject: Re: AD's question for airworthy cert |
				[quote="kitfox69(at)earthlink.net"]Clem,
 Not quite right...Anyone including your 5 year old kid could work on an expiremental plane.. However, only the person holding the repairmans certificate (original builder) or any A&P can sign off on the condition inspection.
		84KF Guest
				 Posted: Sat Mar 17, 2007 8:34 am    Post subject: Re: AD's question for airworthy cert |
				Gentlemen,
      Answers to who may perform maintenance and required inspections  involving ELSA, SLSA, and Amateur-built is found on page 44779 of the Final Rule. Get it from AOPA website. I would post it here, but don't want to ruffle feathers.
 Maintenance....Preventive Maintenance ... 2 different terms.
 To find the items included under 'preventive maintenance' go to FAR 43, appendix A.
 For more 'preventive maintenance'  info on SLSA, go to FAR 43.3g,
 The 'new guy' (ya, right.)
		84KF Guest
				 Posted: Sat Mar 17, 2007 8:41 am    Post subject: Re: AD's question for airworthy cert |
				BTW....."Anyone including your 5 year old kid could work on an expiremental plane.. However, only the person holding the repairmans certificate (original builder) or any A&P can sign off on the condition inspection."
 100%correct
 and...FAA AD's can, and will apply to SLSA.
 Steve
 http://84kf.blogspot.com/
