Zenith's Annoying Documentation is most likely among the bes
bretttdc(at)yahoo.com
PostPosted: Sat Mar 17, 2007 8:03 am    Post subject: Zenith's Annoying Documentation is most likely among the bes Reply with quote
The current set of plans and manual are most likely among the best in the industry. Plans and instructions on something so complex are NEVER one hundred percent correct. Most likely your plane will not be one hundred percent like the plan either. Every time I came up on a problem in the plans it turned out that it was actually a bad interpretation on my part. Often that mistake was made on an earlier part of the project. There are a few glitches in the plans. As we become better craftsman we acquire an ability to spot the glitches from a distance. Its just part of the learning curve. I have learned a lot in this process.
Brett Hanley
N858BH
99.9% complete
First flight Thursday
tommylutz(at)gmail.com
PostPosted: Sat Mar 17, 2007 11:27 am    Post subject: Zenith's Annoying Documentation is most likely among the bes Reply with quote
Perhaps you'd like to deposit some of your wisdom on the wiki....
On 3/17/07, Brett Hanley <bretttdc(at)yahoo.com (bretttdc(at)yahoo.com)> wrote:[quote] The current set of plans and manual are most likely among the best in the industry. Plans and instructions on something so complex are NEVER one hundred percent correct. Most likely your plane will not be one hundred percent like the plan either. Every time I came up on a problem in the plans it turned out that it was actually a bad interpretation on my part. Often that mistake was made on an earlier part of the project. There are a few glitches in the plans. As we become better craftsman we acquire an ability to spot the glitches from a distance. Its just part of the learning curve. I have learned a lot in this process.
Brett Hanley
N858BH
99.9% complete
[quote][b] http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com [quote][b]
