Crvsecretary(at)aol.com Guest
Posted: Sat Mar 17, 2007 8:57 am Post subject: 601 NR#4 Problems |
Hello Listers:
I'm building the right wing of my 601XL using the 15 gal. fuel tanks and wing spars made for 12 gal. tanks. I never read in the prints or photo guide the instruction to cut the bracket for NR#4 so I drilled out the rivets and removed the bracket.
What kind of trouble did I get myself into? Am I screwed?
I appreciate all responses.
As always, thank you.
Tracy Smith
Naugatuck, CT
601XL N458XL (reserved)
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Mar 17, 2007 9:13 am Post subject: Re: 601 NR#4 Problems |
You're screwed......just kidding, I couldn't resist. If you haven't closed the LE up yet I would suggest filling the hole if possible. A driven rivet would be best but I think a bolt or machine screw would suffice....You might add a little stiffener while you are at it but I don't think it matters.
I'm sure one of the more experienced guys on the group will give you other suggestions as well.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
taffy0687(at)yahoo.com Guest
Posted: Sat Mar 17, 2007 9:18 am Post subject: 601 NR#4 Problems |
Tracy,
If I were you, I'd go straight to Zenith with this question---- Fritz
Crvsecretary(at)aol.com wrote:
[quote] Hello Listers:
Tracy Smith
Naugatuck, TV dinner still cooling?
[url=http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/]Check out "Tonight's Picks"[/url] on Yahoo! TV. [quote][b]
zodierocket(at)hsfx.ca Guest
Posted: Sat Mar 17, 2007 9:21 am Post subject: 601 NR#4 Problems |
Your not screwed, Install rivets back in place of the ones you removed. Same type in same hole. The caution is that a rivet that is drilled out is not replaced, this is not acceptable. You must not leave a hole that is not filled.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com (president(at)can-zacaviation.com)
www.can-zacaviation.com
dredmoody(at)cox.net Guest
Posted: Sat Mar 17, 2007 12:03 pm Post subject: 601 NR#4 Problems |
As long as you have already drilled out the rivets, check to see if you can re-install the angle of the aft side of the spar. Do you have access to a pneumatic riveter or a squeezer with the correct inserts? If not wait until you have that done before blocking your access to both sides of the spar at that point. Even if you just set rivets back in the holes you will be fine. You'll make actual mistakes later on.... save the sweat for those episodes.
Dred
TxDave
Posted: Sat Mar 17, 2007 1:23 pm Post subject: Re: 601 NR#4 Problems |
Gee whiz! I'm looking at that big 95mm lightening hole in my spar web and am wondering how a tiny little rivet hole is going to create a problem. But then again, I would listen to Mark Townsend. He certainly is more knowledgeable than most of us amateurs on this forum.
Dave Clay
601XL scratch builder
Temple, TX
http://www.daves601xl.com
naumuk(at)alltel.net Guest
Posted: Sat Mar 17, 2007 3:41 pm Post subject: 601 NR#4 Problems |
Mark and Jon are experts through the school of hard knocks. They've made
just as many mistakes as we have, and even show them on their DVDs. (Along
with ways to minimize the loss). Very refreshing. Listen to the voice of
experience!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sat Mar 17, 2007 5:05 pm Post subject: 601 NR#4 Problems |
I may be losing it but I don't recall a lightening hole in the spar web. You don't perhaps mean the wingtip spar extension?
Dred
TxDave
Posted: Sat Mar 17, 2007 6:35 pm Post subject: Re: 601 NR#4 Problems |
Hey Dred,
There's a 95mm flanged lightening hole in the outboard end of the spar web. There is another in the tip extension. Page 6-W-3. Mark set me straight on the need to address an unfilled rivet hole in the spar web. Like I told him, this airplane building business is a continual learning process. Aren't we fortunate to have this forum?
Dave Clay
Temple, TX
Posted: Sun Mar 18, 2007 3:41 am Post subject: 601 NR#4 Problems |
I had forgotten about the other hole in the spar. I still can't "see it" in my mind's eye. I'll check that page of the drawings just to get my mind right. Do you have a rivet gun or someone close by who does? I think the mania for not leaving holes can be exaggerated at times but in the spar, I try to walk the line. In a low stress area, an unfilled hole is a lightening hole as long as there is adequate edge distance. When I have a useless hole drilled where I don't need it, I just pull a rivet in it or dimple it and set a solid countersunk one if something has to sit flush on it. That happened on the baggage deck because I didn't think far enough ahead of what I was doing.
This list bailed me out when Tom Henderson offered to cut and bend me 12 extra standard L-angles for $2 apiece. I had run out due to waste and extra use where the plans did not demand it. Zenith wanted over $7 each for them despite the material costing less than $1.70 each. I sent Tom $35 to make sure he didn't come out behind on the shipping.
Dred
planecrazydld(at)yahoo.co Guest
Posted: Sun Mar 18, 2007 4:53 am Post subject: 601 NR#4 Problems |
when you talk to Zenith, make sure that you ask to speak to an engineer. Ask him if you could use a CherryMax of the appropriate size (assuming they make them that long). Somewhere in my past I recall that CherryMax rivets are considerd a structural equivalent to AD driven rivets - I do not know if that is a figment of my imagination or not!
Edward Moody II <dredmoody(at)cox.net> wrote: [quote] As long as you have already drilled out the rivets, check to see if you can re-install the angle of the aft side of the spar. Do you have access to a pneumatic riveter or a squeezer with the correct inserts? If not wait until you have that done before blocking your access to both sides of the spar at that point. Even if you just set rivets back in the holes you will be fine. You'll make actual mistakes later on.... save the sweat for those episodes.
Dred
Posted: Sun Mar 18, 2007 4:57 am Post subject: 601 NR#4 Problems |
shear in a "shear web" with properly engineered flanged lightening holes and shear transfer across a structure that is stiffness and buckling critical is completely different. I assumed that he drilled out the holes common to the spar caps and shear web... holes in the shear web would be best "filled" - with almost anything. Holes in the cap/web structure usually "must" be filled or it becomes a locally soft area to buckling loads.
TxDave <dclaytx2(at)hotmail.com> wrote: [quote]--> Zenith-List message posted by: "TxDave"
Dave Zodiac 601XL/Corvair?
Don't be flakey. [url=http://us.rd.yahoo.com/evt=43909/*http://mobile.yahoo.com/mail]Get Yahoo! Mail for Mobile[/url] and
[url=http://us.rd.yahoo.com/evt=43909/*http://mobile.yahoo.com/mail]always stay connected[/url] to friends. [quote][b]
