Aileron Rigging Tip - Prevent Droopy Ailerons
Goto page 1, 2  Next
Tim Olson
PostPosted: Sun Mar 18, 2007 8:27 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Yesterday I was looking for something to do for an hour
to waste some time, and I decided to look at my ailerons.
Some old-timers in the RV-10 lifetime may remember Randy had
problems with his ailerons being rigged low, causing a reduction
in stop speed. Well, I didn't think mine were originally
rigged bad. It was strange, as sometimes I would look at the
ailerons in the hanger and the would be perfectly in-line with
the wingtips and flaps. Then other times I'd look at them
in flight and the ailerons would be low on both sides just
a small amount. I would get done flying and look at them
and they'd be fine. I didn't know what to make of it. I thought
maybe it was a lift or loading issue in-flight, but I just
didn't know for sure. Didn't concern me much because it flew
great for over 200 hours that way, but it did bug me that when
I flew with people like Vic, he could notice that kind of thing.
It's like having your fly down in public. Wink
So anyway, I centered the sticks yesterday and they were OK in the
hanger with the sticks neutral, but maybe off by a little more than
1/8" per side. So I thought I'd adjust them. I strapped the seatbelt
around the stick to keep them centered tight, and lo and behold the
ailerons were now in-line very nicely.
It was then that I realized that the small amount of travel induced
in the ailerons with the elevator movement was the entire issue.
So I used my aileron/rudder gust lock which centers the elevator and
centered the sticks. Yeehaw, there was what I was looking for!
The ailerons were now drooped about maybe 1/4" per side or
so. So it WAS the elevator control, and in-flight the elevators
are neutral. Time to adjust.
When all was said and done, I had them adjusted to be matched with
the wingtips and flaps in-flight, and I put about 2.5 hours on.
It flies the same...not sure about speed as I never really try to
fly top speed, but it looks nicer in cruise and can't hurt.
So use that tip when you're rigging your ailerons for flight, and
perhaps you'll not have to go over a year and 200 hours with
droopy tips like I did.
Tim Olson - RV-10 N104CD
jesse(at)saintaviation.co
PostPosted: Sun Mar 18, 2007 9:47 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I am sitting here wondering what could cause that. It must be the change
in angle between the stick and the bellcrank in the wing root. That
little change in angle must make enough difference that it changes the
height. I have not noticed this, but it is a good observation. Thanks
for pointing it out. It probably will give you a little bit of speed, as
Randy's did. You will be able to sleep better now knowing that, even
though you may not have measured it, you will be getting that extra knott.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
352-427-0285
Tim Olson
PostPosted: Sun Mar 18, 2007 10:05 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I pro'ly shoulda said "Wow, when I flew I noticed I had picked up an
extra 8 kts of speed!" That could have been the start of a great
hanger-flying wive's tale type story.
Jesse Saint
352-427-0285
> Tim
deutscht(at)rhwhotels.com
PostPosted: Sun Mar 18, 2007 3:40 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Tim did you do the adjustment in the bell crank to aileron rod? How
many turns did it take? One end or both equally?
Tom Deutsch #40545 FAA inspection Friday-hope to fly Saturday or Sunday.
Tim Olson
PostPosted: Sun Mar 18, 2007 4:20 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I can't say for sure how many turns. I just did it one or two
turns at a time until it got close and then a half turn whichever
way I needed. On one side I did the adjustment on both ends,
shortening the rods slightly. I found that it's nearly impossible
to remove the aft rod end to spin it, so on those I loosened the
locknut on the rod end with the inside on the belcrank disconnected
so I could move the aileron to provide access to the locknut (may
need to put the flaps down). Then I could spin the rod while
the end stayed put on the aft ends. On the forward ends, I could
just spin the rod end. It was kind of a tight work area, but
I just took my time and got it right.
PS: Good luck on your first flight!!
jjessen
PostPosted: Sun Mar 18, 2007 6:48 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Tom, good luck! Fly safe.
John J
indigoonlatigo(at)msn.com
PostPosted: Mon Mar 19, 2007 6:59 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Tim,
So what you are telling us is that when you strapped the control stick
nuetral side to side but full back elevator with the seat belt, the aileron
alignment problem was gone. But any other time with the sick not in the full
back position, the ailerons droop.
The best that I can figure it is that the bushing reciever in the column is
not parallel to the holes in the fork which hold the aileron pushrod. Or, it
could be that the holes in the fork at the end of the tube which allows you
to tie the right and left sticks together is not perpendicular to the long
axis of the tube itself.
In other words, then the stick goes full forward to full back, this
translates into aileron movement even when the stick stays nuetral side to
side. The bottom of WD 1011 (R) (L) column travel is on a different arc then
your stick grip.
Am I understanding this correctly?
If so, did you just put the stick in slightly down elevator(Cruise position)
and then adjust the ailerons to their nuetral position.
So now with this adjustment, when the stick goes full back as in directly
before a slow speed stall, what do the ailerons do? A slight droop would be
okay only as long as flaps are down, but if no flaps are not deployed, this
would be a bad position to enter into a stall because the wing tip would
stall first before the in board portion of the wing did.
I think reflex would be slightly safer.
JOhn G.
Subject: Aileron Rigging Tip - Prevent Droopy Ailerons
Date: Sun, 18 Mar 2007 11:27:40 -0500
Tim Olson
PostPosted: Mon Mar 19, 2007 7:28 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Don't make too big a deal of it John...it's not worth too
much investigation into the linkages and how exactly they
deflect and affect eachother. It isn't ONLY in full-aft-stick
that this changes, it's just a very slight progressive change
in the aileron alignment that affects them both equally with
increasing up elevator. I didn't check it with full-forward
stick to see if the alignment changes there too.
It's not a design defect, a big gotcha, or anything like that.
And I seriously doubt the deflection is big enough to be
a big safety problem too. It's just an effect of what
happens with the elevator/stick/ailerons all connected together.
For this alignment, I kept the elevator perfectly neutral
as I mentioned in the previous email, and then I aligned the
ailerons. Then in cruise I looked out and they looked
basically the same. So in cruise, my elevator was also
neutral. I assure you, in flight, the RV-10 is very pitch
sensitive and I seriously doubt you'll EVER put enough
elevator into ANY maneuver with the RV-10 to cause you any
heartache with the mis-alignment. It's simply an alignment
that you must do properly if you want them not to droop
in cruise. Your actual stick movement at both high and low
airspeeds is very tiny in the RV-10. I have never had to
worry about fat people's legs getting in the way, for
instance...you don't need that much elevator even on an
extremely twitchy turbulent approach. And I can almost
guarantee that you'll never use a HUGE portion of the available
up-elevator travel that you have...you'd rip the wings off.
You only use that much travel on landing rollout to slow the
plane.
No, go grab your rivet gun (or dental drill) and do
something to take your mind off this. Wink
John Gonzalez wrote:
Tim,
aileron alignment problem was gone. But any other time with the sick not
in the full back position, the ailerons droop.
is not parallel to the holes in the fork which hold the aileron pushrod.
Or, it could be that the holes in the fork at the end of the tube which
allows you to tie the right and left sticks together is not
perpendicular to the long axis of the tube itself.
to side. The bottom of WD 1011 (R) (L) column travel is on a different
arc then your stick grip.
position) and then adjust the ailerons to their nuetral position.
directly before a slow speed stall, what do the ailerons do? A slight
droop would be okay only as long as flaps are down, but if no flaps are
not deployed, this would be a bad position to enter into a stall because
the wing tip would stall first before the in board portion of the wing did.
JOhn G.
> From: Tim Olson <Tim(at)MyRV10.com>
> Tim
PostPosted: Mon Mar 19, 2007 7:51 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I had a 7 am patient and they cancelled over the weekend so I am in to the
office early with nothing to do.
JOhn G.
Subject: Re: Aileron Rigging Tip - Prevent Droopy Ailerons
Date: Mon, 19 Mar 2007 10:27:39 -0500
plane.
>Tim,
>allows you to tie the right and left sticks together is not perpendicular
>be okay only as long as flaps are down, but if no flaps are not deployed,
>this would be a bad position to enter into a stall because the wing tip
>JOhn G.
>>Tim
Randy(at)abros.com
PostPosted: Mon Mar 19, 2007 8:11 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I have been watching this post with interest. I just wanted to chime in
on how I made my adj. It was obvious that in level flight, calm air and
auto pilot on that my ailerons were down about 1/4" on each side. I
made the adjustment to them and lined them up per the book. Then I few
several hours looking at the alignment. I noticed that ailerons in
flight were down again about 1/16 to and 1/8". Well if you look at the
flaps and how full up is determined it is by the rear spar doubler. If
you have the flaps full up and then lift slightly on the outboard
trailing edge you will get a slight deflection up. This is because the
flaps on the outboard end (next to the aileron) does not have a stop
except the rear spar. I lifted the ailerons some more and that is how it
has been set for the last 80 hours or so.
I had a talk with a Bonanza driver one day and he said that raising the
ailerons on a Bonanza was an old speed trick. The 10 has a limit to this
because the forward edge will be deeper in the slip stream the more you
raise the trailing edge. Randy 40006
LloydDR(at)wernerco.com
PostPosted: Mon Mar 19, 2007 8:32 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
You should be priming your battery tray and figuring out the Andair
fittings then...
Dan
N289DT
Tim Olson
PostPosted: Mon Mar 19, 2007 8:33 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
That's a good observation on the flap stop...it's that huge doubler
that you're talking about I'm sure.
So the biggest point you're making, if I'm not mistaken is, when
you adjust the ailerons up, do a quick doublecheck to make sure
that even when you apply some up pressure on them, the nose of
the aileron doesn't dip down into the slipstream, right? And,
if you adjust them to be perfectly inline, you probably won't have
that problem, but if you try to give them some "reflex" to reduce
drag, you may have that issue.
Did I get it right?
Randy(at)abros.com
PostPosted: Mon Mar 19, 2007 8:49 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
PERFECT TIM. That is why you are the GRAND MASTER. Later, Randy
PostPosted: Mon Mar 19, 2007 8:56 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Already done my friend.
Going to fed ex, break between patients, to send back my control stick and
base.
john
[quote]From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Subject: RE: Aileron Rigging Tip - Prevent Droopy Ailerons
Date: Mon, 19 Mar 2007 12:25:38 -0400
fittings then...
Dan
N289DT
scottmschmidt(at)yahoo.co
PostPosted: Mon Mar 19, 2007 9:32 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
This is pretty interesting. When I set up my ailerons they were set perfectly even with my flaps. But in-flight I have noticed that my ailerons are down 1/4" from my flaps. I have been leary of raising them but sounds like that is what I should do. If I do this though they will be a little higher than the flaps on the ground.
Pretty amazing threre is that much of low pressure that is pulling up the flaps that much.
Tim Olson <Tim(at)MyRV10.com> wrote:
[quote]--> RV10-List message posted by: Tim Olson
Did I get it right?
Randy DeBauw wrote:
[quote] --> RV10-List message posted by: "Randy DeBauw"
Tim Olson
PostPosted: Mon Mar 19, 2007 10:07 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
No, it's not low pressure from what I can tell. It's just that the
jig, or whatever was used during the initial setup sets them to
even but at a setting where you've got aft stick (up elevator) put in.
I think probably many people (including myself) probably didn't pay
attention to the elevator position during the rigging...that's all.
And we're all ending up 1/4" low. It could just be the jig sets
them that way by accident.
Scott Schmidt wrote:
[quote] This is pretty interesting. When I set up my ailerons they were set
Did I get it right?
chime in
air and
I few
at the
doubler. If
because the
how it
raising the
to this
more you
jjessen
PostPosted: Mon Mar 19, 2007 11:00 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Anyone talk to Van's about this yet? May be a good topic for a bulletin
from them to the -10 builders.
Randy(at)abros.com
PostPosted: Mon Mar 19, 2007 11:04 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I talked with Ken Kruger before my adjustments. He pointed out that the
leading edge will be dropping as the trialing edge is lifted. Randy
GRANSCOTT(at)AOL.COM
PostPosted: Mon Mar 19, 2007 11:38 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Has anyone tried the 3M tape that Art Matheson sells to cover the lower/upper gaps? I can't remember the tape number but a company in Chicago sell it by the roll, and as experimentals one can try it?
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
Tim Olson
PostPosted: Mon Mar 19, 2007 11:45 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I think it's way too minor for a service bulletin.
I went 200+ hours before I fixed it. It would be
nice to have perhaps better notes in the plans about
aligning it, but we all know how well those ideas
are received. It's not really a safety issue either.
I think the best we can hope for is that eventually we
can educate people by these types of forums. For the
people who don't participate online....well....maybe
we'll recognize their planes by their ailerons.
Goto page 1, 2  Next
Page 1 of 2
