Hole pattern
naumuk(at)alltel.net
PostPosted: Sun Mar 18, 2007 10:55 am    Post subject: Hole pattern Reply with quote
All HD/HDS People-
Do your plans show the rivet hole pattern for gusset 6-F-12-2? There isn't a pattern on mine.
Thanks.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
jpollard(at)ciaccess.com
PostPosted: Sun Mar 18, 2007 11:20 am    Post subject: Hole pattern Reply with quote
I used this pattern from the cad drawings
Here is a picture from the cad drawings of that part
Jim Pollard
Merlin Ont.
At 02:52 PM 3/18/2007, you wrote:
All HD/HDS People-
Thanks.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
 Filesize:  9.84 KB
 Viewed:  274 Time(s)
PostPosted: Sun Mar 18, 2007 11:39 am    Post subject: Hole pattern Reply with quote
Thanks, Jim. That's more than I have to work with. The inset on my print is
totally blank. No real dimensions on yours, but I can figure it out.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
PostPosted: Sun Mar 18, 2007 11:46 am    Post subject: Hole pattern Reply with quote
Thanks, Jim. I had to copy the drawing to Excel to print. No real
dimensions, but a lot more than what I had to work with.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
PostPosted: Sun Mar 18, 2007 11:50 am    Post subject: Hole pattern Reply with quote
Thanks for your responses. Amazing that plans can differ that much!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
