GA & Amateur Built Aircraft Engine Failure Rates
d-m-hague(at)comcast.net
PostPosted: Sun Mar 18, 2007 5:10 pm    Post subject: GA & Amateur Built Aircraft Engine Failure Rates Reply with quote
At 08:52 PM 3/18/2007, Steven Green wrote:
If I read Jack's study correctly, He only used "engine failures" that
resulted in a fatality and only compared GA to experimental. I doubt there
are many fatal accidents in experimentals that go unreported.
Yes, but you have to compare apples to apples. GA planes on the average
almost certainly fly more hours than experimentals. Many of these hours
are IFR, which increases the likelihood of a bat outcome from an engine
failure. Most GA planes are larger and faster than the average
experimental, so an engine failure that puts a Kolb down in a pasture might
be much in, say, a Bonanza. And, of course, ultralight accidents aren't
tracked at all by the NTSB any more (unless it's a high profile case like
the Walmart heir and/or if they decide it's an "unregistered aircraft"
rather than an "ultralight vehicle".
-Dana
The citizens of the United States are getting the government they deserve.
The problem is that I'm also getting the government they deserve.
jbhart(at)onlyinternet.ne
PostPosted: Sun Mar 18, 2007 5:35 pm    Post subject: GA & Amateur Built Aircraft Engine Failure Rates Reply with quote
At 03:20 PM 3/18/07 -0700, you wrote:
You did not take into account that almost all General Aviation engine fialures are are reported, while most ultralight - experimental engine failure go unreported.
Just looking at the NTSB numbers of REPORTED accidents with injurys is useless.
Steve,
I agree that it is possible that many ultra light vehicle and undocumented
experimental aircraft incidents are unreported. But if it is an N-numbered
aircraft, it seems to me that it would be difficult to under report an
engine failure and a fatality. I did not query the data base for injuries or
fatalities. I queried the data base for "engine failure". The number of
fatalities was listed for each query match and I totaled them up.
The point is that people who fly in N-numbered amateur aircraft appear to
have a better chance of surviving an engine failure than those who fly in
single engine piston engine GA aircraft.
Where will you find better data than the NTSB database?
Jack B. Hart FF004
Winchester, IN
possums(at)bellsouth.net
PostPosted: Sun Mar 18, 2007 9:52 pm    Post subject: GA & Amateur Built Aircraft Engine Failure Rates Reply with quote
Steven
I agree with that, but I disagree that "any and all" utralight
incidents go unreported.
In fact I get reported every 5 or 10 years in the local paper.
Sucks for me ... but....www.mdjonline.com
don't go there unless you are saved or been saved
HEY IT'S SUN & FUN .....GO FORTH & MULTIPLY.
