tommylutz(at)gmail.com Guest
Posted: Mon Mar 19, 2007 8:53 am Post subject: Clamp Types |
Does it matter what type of spring-loaded clamps I use? I assume Zinc alloy is better than steel for this work. Can someone please check this page (http://www.aircraftspruce.com/menus/to/clampingtools.html ) and tell me what clamps, if any, to avoid?
Thanks in advance,
Tom
Jaybannist(at)cs.com Guest
Posted: Mon Mar 19, 2007 9:15 am Post subject: Clamp Types |
Tom,
I have found that most spring-loaded clamps are only good for situations where they are expected to be about as effective as the clamping you would get between your thumb and forefinger. This is not a put-down. There are plenty of situations where they are useful and handy. The same goes for those plastic, squeeze ratchet types. Because of the relatively low pressures and short-term use, I don't think the type of metal is critical.
If you need really tight, secure clamping, use vice-grip types or screw types.
Jay in Dallas
Gig Giacona
Posted: Mon Mar 19, 2007 1:10 pm Post subject: Re: Clamp Types |
I have about 8 of these (SPRING TENSION CLAMP AT542), several quick grip bar claps from Home Depot and 4 of the clamps that are kind of like plyers but have the bolt to adjust grip.
But the ones I use the most, are the little clips that have the rubber ends and they are perfect for holding a skin in place while drilling.
[quote="tommylutz(at)gmail.com"]Does it matter what type of spring-loaded clamps I use? I assume Zinc alloy is better than steel for this work. Can someone please check this page (http://www.aircraftspruce.com/menus/to/clampingtools.html ) and tell me what clamps, if any, to avoid?
Thanks in advance,
Tom
601XL Under Construction
vgstol(at)bigpond.net.au Guest
Posted: Mon Mar 19, 2007 1:33 pm Post subject: Clamp Types |
Good stuff Tom - I like your style.
JG
Posted: Mon Mar 19, 2007 1:35 pm Post subject: Clamp Types |
Sorry about that last post - clicked on the wrong name - bifocals are a pain....
Do not archive.
JG
planecrazydld(at)yahoo.co Guest
