AZFlyer
Posted: Mon Mar 19, 2007 3:03 pm Post subject: OAT (Outside Air Temp. probe) location |
Hi all,
Any suggestions as to best location for OAT probe. Am thinking fuslage, but not sure of best (undisturbed location).
Looking for input...
Mike
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
bryanmmartin
Posted: Mon Mar 19, 2007 3:53 pm Post subject: OAT (Outside Air Temp. probe) location |
Someplace where the sun can't shine on it and heat from the engine
can't flow over it. Maybe under the wing root?
On Mar 19, 2007, at 7:03 PM, AZFlyer wrote:
| Quote: | Any suggestions as to best location for OAT probe. Am thinking
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Mon Mar 19, 2007 4:50 pm Post subject: OAT (Outside Air Temp. probe) location |
Hi Bryan,
I placed my OAT at the outside edge of the belly angle, right side and
fed it thru the forward foot channel from the side.
The readings seem to match my thermometer at the hangar during run up.
At least it keeps the wires out of the way.
Larry McFarland at www.macsmachine.com
Bryan Martin wrote:
<bryanmmartin(at)comcast.net>
--Bryan Martin
N61BM, CH 601 XL,
do not archive.
zodierocket(at)hsfx.ca Guest
Posted: Mon Mar 19, 2007 5:26 pm Post subject: OAT (Outside Air Temp. probe) location |
Locate on last bulkhead just below Stabilizer. 6-B-12-3
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
Posted: Mon Mar 19, 2007 5:49 pm Post subject: OAT (Outside Air Temp. probe) location |
Another good spot I have used is the NACA duct for fresh air in the
cabin.
Mark Townsend
dredmoody(at)cox.net Guest
Posted: Mon Mar 19, 2007 7:00 pm Post subject: OAT (Outside Air Temp. probe) location |
For mine, I was told that the underside of one wing, back about half of chord length would be the best place. If you go with a location on the fuselage try to keep it underneath where it will be in the shade. The bottom of the fuselage does get the exhaust stream so the wing is a better place.
Dred
jeffrey_davidson(at)earth Guest
Posted: Mon Mar 19, 2007 7:14 pm Post subject: OAT (Outside Air Temp. probe) location |
Do not archive this either, but Piper seems to be intent on placing it up high right smack in the middle of the windshield - must be about the worst place I can think of ….
Jeff D.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Edward Moody II
Sent: Monday, March 19, 2007 11:01 PM
Subject: Re: OAT (Outside Air Temp. probe) location
Dred
caspainhower(at)aep.com Guest
Posted: Tue Mar 20, 2007 6:22 am Post subject: OAT (Outside Air Temp. probe) location |
I am mounting mine in the NACA vent duct. I have seen numerous similar
installations on both certified and experimental aircraft.
Craig
N601XS, 601xl, 0-235 lyc, wiring in progress
Hi all,
but not
This e-mail message and all attachments transmitted with it from the
Nuclear Generation Group of American Electric Power are for the sole
use of the intended recipient(s) and may contain confidential and
privileged information. Any unauthorized review, use, disclosure or
distribution is prohibited. If you are not the intended recipient, please
contact the sender by reply e-mail and destroy all copies of the original
message.
