		jpspencer(at)cableone.net Guest
				 Posted: Tue Mar 20, 2007 9:10 am    Post subject: 912 carb sync |
				Anybody besides me have problems with  getting/keeping the carbs synched on their 912. I have the standard  issue 701 throttle arrangement currently but have tried about a half dozen  different setups and have had problems with all of them. The main trouble seems  to be with the off center torque tube actuator which requires a longer cable to  the left carb resulting in a bunch more cable slop on that side. Tried  controlling the left carb off the left side and had problems with that  too.Believe it would be a lot better if could control the carbs from  a firewall center position with equal length cables, and some sort of  "slider" arrangement instead of the torque tube. That would also eliminate  the vertical s turn in the cable required by the stock setup. Anybody got a  "quick easy cheap" fix.
  Joe
  The green one on utube
  85 hours
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dirkslabbert(at)telkomsa. Guest
				 Posted: Tue Mar 20, 2007 10:52 am    Post subject: 912 carb sync |
				Hallo green one, seen your video, amazing ! is that  a 80 hp 912!?
  I have a different throttle setup, if you are  interested, will send a pic.
  All the best,
  Dirk.
  [quote]   ---
		zsmith3rd(at)earthlink.ne Guest
				 Posted: Tue Mar 20, 2007 11:01 am    Post subject: 912 carb sync |
				Joe,
 Separate email headed your way to youe email address.
 Zed/912/701/etc
				 Posted: Tue Mar 20, 2007 12:05 pm    Post subject: 912 carb sync |
				Joe,
 I had that same problem with my Subaru and dual Bing carburetors.  I
 went with a single .065 music wire push-pull wire in a cable casing and
 linked
 the carbs together solidly so that they hit stops each end of travel at
 the same time.  Now the throttle acts like one on any Cessna / Piper.
 Suggest you go solid rather than cables and remove the springs on the
 carb linkage arms if you still have them.
 Larry McFarland at www.macsmachine.com
 jpspencer(at)cableone.net wrote:
  	  | Quote: | 	 		   Anybody besides me have problems with getting/keeping the carbs
  Joe
  85 hours
		klaus(at)utdallas.edu Guest
				 Posted: Tue Mar 20, 2007 2:22 pm    Post subject: 912 carb sync |
				Hi,
 The carb sync problem can be solved by doing away with the cables and
 instead
 using rods. Rods give positive control, do not require springs, and have
 been working reliably for more than 1000 hrs over more than 10 years.
 The details are on the website
 www.utdallas.edu/~klaus/Airplane/linkage_carburetors.html
 Happy flying,
 Klaus Truemper
 Klaus Truemper
 Professor Emeritus of Computer Science
 University of Texas at Dallas
 Erik Jonsson School of Engineering and
   Computer Science EC31
 P.O. Box 830688
 Richardson, TX 75083-0688
 (972) 883-2712
		ricklach
  Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
				 Posted: Wed Mar 21, 2007 8:45 am    Post subject: Re: 912 carb sync |
				Hi Klaus,
 Your rod design looks very solid and dependable. But I have a question for you. Have you seen any issues with your rod set-up when the engine torques in the airframe. Like RPM changes.
 Looking forward to your comments.
 Rick
				 Posted: Wed Mar 21, 2007 11:14 am    Post subject: 912 carb sync |
				Hi Rick,
 Joe Spencer sent an email with the same concern about synchronization
 via rods when the engine moves a abit.
 Here is the analysis of that aspect:
 Altogether, any engine movement is very small
 since the motor mounts are so stiff.
 But suppose the propeller pulls the engine foward a bit,
 or a power reduction has the engine move backward a bit.
 Then this effect occurs on both sides, and thus the
 throttle settings remain synchronized.  The same conclusion
 applies if the engine rotates a bit on the longitudinal axis
 due to engine torque. It that case, both throttles are
 again affected the same way.
 In fact, we have never noticed
 any unbalanced behavior because of power setting or whatever
 else might make the engine move a bit.
 It would be different if, looking from the top down on the
 engine, the engine would rotated in the mount. But I cannot
 see why the engine or propeller forces
 would ever cause such a rotation.
 More important is the vibration that constantly shakes
 the rods. I was initially concerned that this would wear out
 the rod ends and thus lead to imprecise positions of the
 throttle. After more than 1000 hours, there is a tiny amount
 of play, of no concern so far. There is NO safety issue since
 a large washer is outside the rod end so that even a failure
 of the rod end cannot result in the rod disconnecting from the
 carburetor.
 My friend Mel Asberry, the expert builder, and I
 came up with the rod idea AFTER we had installed the cables.
 We never got them to work right and decided to go to rods.
 This has been an excellent choice. Once the carburetors
 are carefully synchronized, they stay that way and never need
 any adjustment.
  	  | Quote: | 	 		  From a safety standpoint I never liked the cable setup
 to begin with. If one cable disconnects, that side goes to
 full throttle due to the spring. Yet the other side stays
 at whatever setting you have,
 and the engine is extremely unbalanced
 in the power output of the cylinders. This has got to be
 extremely dangerous. The rods, with their positive control,
 completely avoid that problem.
 Happy Flying,
 Klaus Truemper
 Klaus Truemper
 P.O. Box 830688
 (972) 883-2712
				 Posted: Thu Mar 22, 2007 5:17 pm    Post subject: 912 carb sync |
				Thanks guys for the replies on the carb sync  problem. Think I will try Klaus' push/pull rod setup. Will report.
  Joe
