captainron1(at)cox.net Guest
Posted: Wed Mar 21, 2007 5:52 pm Post subject: Fuel pump complication |
I hope that with the tremendous talent we have here some of you can help me solve a problem I didn't even know I had till two days ago. As most of you know I am in the process of installing a 1.3 liter Suzuki motor in my Kolb M3X. Well I had the fuel tanks fabricated and I have them installed, however on the other list that I am on dealing just with this engine, there was just some posting about how the fuel pump on the Suzuki is inside the fuel tank, and just to increase the problem it needs to be in there for the fuel to cool it off during its operation. How much of it is factual I am not sure, but I know for a fact that the pump in the car is inside the fuel tank. So the question is what other external pumps can I use on the Suzuki 1.3 16 valves DOHC. I just beginning to see the end of the project just to have this come up.
Thanks in advance
Ron
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Wed Mar 21, 2007 10:24 pm Post subject: Re: Fuel pump complication |
Most fuel pumps that are installed inside the tank are designed to use the surrounding liquid as coolant. You'll have to fing out what fuel pressure the injection system needs to operate correctly if you plan on using a aftermarket external pump.
_________________ Scott
www.ill-EagleAviation.com
do not archive |
herbgh
Posted: Thu Mar 22, 2007 6:37 am Post subject: Fuel pump complication |
Scott
The ones I have had apart are totally flooded by the fuel.. brushes
and all.. The pump would not be cooled otherwise if the tank was low on
fuel.. '
Herb
On Wed, 21 Mar 2007 23:24:31 -0700 "icrashrc" <icrashrc(at)aol.com> writes:
Scott
http://forums.matronics.com/viewtopic.php?p=102256#102256
Paul Petty
Posted: Thu Mar 22, 2007 6:54 am Post subject: Re: Fuel pump complication |
Ron,
I will see if we offer an external pump that puts out 50-60 psi for you once you find out the requirements. Here is something to think about tho. High pressure fuel injection systems in cars/trucks have some sort of inertia switch in the eletrical circut to the pump. This is a saftey item in the event the fuel line is severd in a crash.These pumps move ALOT of fuel when not restricted! Ford has a frame mounted high pressure pump that is pretty light weight.
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
Posted: Thu Mar 22, 2007 8:22 am Post subject: Fuel pump complication |
Yes exactly, I found an after market pump that does about 41 PSI, but now I need to get the working pressure for the Suzi FI.
Ron
---- icrashrc <icrashrc(at)aol.com> wrote:
--> Kolb-List message posted by: "icrashrc" <icrashrc(at)aol.com>
Scott
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Thu Mar 22, 2007 8:24 am Post subject: Re: Fuel pump complication |
Ron,
I'm converting a 1.3L Zuki also. I'm using a Holley Fuel Pump. P/N 512-105.
You could also use P/N 12-920 or 12-927
I think those are the correct part no's.
If you look at Summit Racing summitracing.com they have other external pumps that meet our requirements.
Keep in touch, Good Luck
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
Posted: Thu Mar 22, 2007 9:42 am Post subject: Fuel pump complication |
Hi Paul
A fellow name Jeron from Raven Redrives just answered my question. He essntially said that the engine needs around 30 psi at the FI rail and that the pump in the link provided would work, and so would also an E-2000 fuel pump which is what he is uses on his conversions.
Ron
"Factory pump in tank is 60PSI if I remember correctly. Excess flow just
returns back to tank via pressure regulator over flow port. Fuel rail runs
at about 30PSI. Pump shown in link should work fine- price is OK about the
same as the E2000 we get at Autozone stores which is the one shown in our
manual. Jeron "
---- Paul Petty <paulpetty(at)myway.com> wrote:
Ron,
Paul Petty
Kolbra #12
Ms Dixie
Final assembly!
http://forums.matronics.com/viewtopic.php?p=102297#102297
Posted: Thu Mar 22, 2007 9:44 am Post subject: Fuel pump complication |
See my post to Paul P.
Jeron says that the one in the link is good.
Ron
---- Michael Sharp <kolbdriver(at)mlsharp.com> wrote:
--> Kolb-List message posted by: "Michael Sharp" <kolbdriver(at)mlsharp.com>
Ron,
Mark Twain,
Roughing it' 1886
http://forums.matronics.com/viewtopic.php?p=102312#102312
d-m-hague(at)comcast.net Guest
Posted: Thu Mar 22, 2007 1:58 pm Post subject: Fuel pump complication |
At 09:50 PM 3/21/2007, Ron wrote:
Quote: | ...the fuel pump on the Suzuki is inside the fuel tank, and just to
during its operation. How much of it is factual I am not sure...
It's correct. Furthermore you have to be careful on cars with in-tank
pumps to be careful not to run out of gas as that's a good way to fry the
pump (don't ask me how I know, but the fuel tank on a Fiero is a BITCH to
R&R). Another reason for the in-tank pump is that it prevents vapor lock
problems on the suction side, since the fuel in the lines is always under
positive pressure. Something to think about... is it impossible to put the
pump in the tank?
-Dana
The citizens of the United States are getting the government they deserve.
The problem is that I'm also getting the government they deserve.
biglar
Posted: Thu Mar 22, 2007 3:04 pm Post subject: Fuel pump complication |
I use a pair of Walbro pumps on Vamoose, in conjunction with a fuel pressure regulator. These are designed to run outside of the tank, and are much simpler to install. They'll put out whatever pressure you need, but need to be exercised once in a while. I've had a couple of them gum up from sitting so long while I fiddled with the reduction drive. Lar.
On 3/22/07, Paul Petty <paulpetty(at)myway.com (paulpetty(at)myway.com)> wrote: [quote]--> Kolb-List message posted by: "Paul Petty" <paulpetty(at)myway.com (paulpetty(at)myway.com)>
Ron,
Paul Petty
Kolbra #12
Ms Dixie
Final assembly!
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Thu Mar 22, 2007 4:51 pm Post subject: Fuel pump complication |
I suppose if I knew about that little piece of data before I had those tanks built I would have it installed, or designed an access cover and the plumbing for the pump inside. Now I can still do it but truth is its too much trouble and its just as easy to keep the fuel pump outside the tank and at a low point below the tank. There are some advantages for it to be outside the tank one of them is easy access and easy inspection. So after considering all the things that have been said here, I just as well keep the pump outside.
There are some other things I need to deal with now, as I understand standard fuel lines are 1/8 or so and all my fittings are 5/8 so, now gotta do reductions. If I wasn't really wanting to get this machine up and flying sometime in this life time I guess I'd be screwing around with it to get it perfect, alas life is too short.
Ron (Arizona)
pump in the tank?
-Dana
