drfred(at)suddenlinkmail. Guest
Posted: Thu Mar 22, 2007 8:03 am Post subject: OAT probe location |
Where's the most common location for the OAT probe? Wing root? naca
nacelle? suggestions?
Fred Williams
40515
Wire planning for fuse.
Randy(at)abros.com Guest
Posted: Thu Mar 22, 2007 8:14 am Post subject: OAT probe location |
Don't us the naca. I have a 10 deg difference between it and the one on
the wing root filler skin. Randy
apilot2(at)gmail.com Guest
Posted: Thu Mar 22, 2007 8:19 am Post subject: OAT probe location |
Some place that engine heat can't affect it. That generally exculdes
most locations below the windshield and along the fuselage or wing
root much inside of the wheels. Many planes put it on an inspection
plate outboard of the main gear.
On 3/22/07, Fred Williams, M.D. <drfred(at)suddenlinkmail.com> wrote:
Fred Williams
40515
Tim Olson
Posted: Thu Mar 22, 2007 9:59 am Post subject: OAT probe location |
I'm with Kelly....get the OAT probe out away from the
fuselage far enough to get rid of any exhaust/engine effects.
I've flown inside open cockpit planes and there is a definite
zone of warmer air near the fuselage. Even if you can only
get out a couple feet, you'll be lots better. I went out
and put it in the bottom wing skin just next to one of
the wing access panels. That makes it accessible to hook
up and replace later too.
Kelly McMullen wrote:
> Thanks
> Fred Williams
> 40515
greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Thu Mar 22, 2007 4:51 pm Post subject: Re: OAT probe location |
I was thinking of mounting the OAT probe on the bottom of the wing tip. What do you think?
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
jim(at)CombsFive.Com Guest
Posted: Thu Mar 22, 2007 5:43 pm Post subject: OAT probe location |
Why not mount it on the inside of the bottom wing skin? Aluminum is an excellent conductor of heat. No need to expose to outside air. No drag and no source of heat.
Any reason why that should not work?
Jim Combs
N312F - Finish Kit
40192
Date: 2007/03/22 Thu PM 07:51:17 EST
Subject: Re: OAT probe location
Greg Hale rv8/rv10
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p=102373#102373
Tim Olson
Posted: Thu Mar 22, 2007 6:00 pm Post subject: OAT probe location |
Why is there no source of heat?....it would be heated by the exhaust
and engine heat just like the rest of the airframe.
That wingtip area is good, as long as you're on the bottom. As long
as you get it out on the wing a few feet though, you're doing great.
If you want to mount it on or near the fuselage though, you may
as well save on wire and just hook it up under the panel. (j/k)
jim(at)CombsFive.Com wrote:
Jim Combs N312F - Finish Kit 40192
============================================================ From:
"greghale" <ghale5224(at)aol.com> Date: 2007/03/22 Thu PM 07:51:17 EST
To: rv10-list(at)matronics.com Subject: Re: OAT probe
location
-------- Greg Hale rv8/rv10 www.nwacaptain.com
DAVELEIKAM(at)wi.rr.com Guest
Posted: Thu Mar 22, 2007 7:23 pm Post subject: OAT probe location |
I am sure the inside of the wing at least warms up in direct sunlight. I
would think the probe should be out in clear, shaded air.
Dave Leikam
40496
Van's called today, fuse, wings and finish are ready to ship!
