rstone4(at)hot.rr.com Guest
Posted: Wed Mar 21, 2007 5:49 pm Post subject: Canopy latching |
Members,
My canopy will not latch unless I pull real hard on the backside and then only the left side from the pilots position will latch on the first stage only. The right side will not latch at all. Can anyone who has had this problem on the ZodiacXL tell me what the fix is.
Tracy Stone
ZodiacXL w/Jabiru 330
Harker Heights, Tx
bryanmmartin
Posted: Wed Mar 21, 2007 6:22 pm Post subject: Canopy latching |
You might try putting shims under the latch pins on the canopy rails.
what the fix is.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Wed Mar 21, 2007 6:45 pm Post subject: Canopy latching |
Bryan,
Thanks for the response, I will try that.
Tracy
marinegunner(at)gmail.com Guest
Posted: Wed Mar 21, 2007 8:11 pm Post subject: Canopy latching |
Tracy,
Here is how I fixed mine on the CH600. However, I doubt that most will even attempt such a fix on a 601 - to much work and to much change to the canopy area. Note the frame is also roll-over protection.
Each gull wing door has a simple but very effective latch. I will be able to remove gull doors and fly without them - in fact, test flight will be done both ways. High power fan tests and fairly fast taxi tests indicate that slipstream will not enter cockpit due to shape, location and size of windscreen. Ta Da, it works.
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned prior to opening/sending and uses an external firewall to help insure virus free email and attachments.
Description: |
Filesize: |
455.81 KB |
Viewed: |
415 Time(s) |
ashontz
Posted: Fri Mar 23, 2007 10:03 am Post subject: Re: Canopy latching |
Steve, do you have more pix inside and out of that canopy of yours? I want to build something similar. Maybe some details on how you built it. I like the look, kind of looks like a F4U canopy. I think I would have made the side extend down a little further. Othere than that, pretty cool. I also like the fact you have rollover protection in there too. Can you supply some pix of that arrangement as well.
marinegunner(at)gmail.com wrote: | Tracy,
Semper Fi,
Steven R. Hulland
CH 600 Taildragger
Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned prior to opening/sending and uses an external firewall to help insure virus free email and attachments. |
Gig Giacona
Posted: Fri Mar 23, 2007 10:10 am Post subject: Re: Canopy latching |
Sound like you didn't put enough bend into the frames when you installed them. I'm at this point now and haven't quite got them where I think they need to be yet. The bending method as shown in the construction manual. (3 bolts and a vise) is not the the easiest thing in the world to do.
rstone4(at)hot.rr.com wrote: | Members,
Tracy Stone
Harker Heights, Tx
601XL Under Construction
Posted: Fri Mar 23, 2007 1:23 pm Post subject: Canopy latching |
I am not sure if this is a common problem however one of the members
suggested that I shim under the striker plate and I just finished making the
shims out of aluminum 1/8 inch or 250,000. I will install tomorrow and let
all know if this fix works.
Tracy Stone
