jeffrey_davidson(at)earth Guest
Posted: Mon Mar 26, 2007 4:34 pm Post subject: Jabiru fuel pressure sensor hookup |
It is amazing how little things can stop me cold. I'm installing the Dynon Engine Management System (EMS) in my 601 with a Jabiru 3300A (solid lifters). I'm installing the fuel flow sensor. The Dynon sensor has a 1/8 inch NPT male thread on it. I am using the Zenith supplied 1/4 Inch inside diameter ( I know about using 3/8ths) fuel hose. Has anyone found a fitting or set of fittings that has a female 1/8th NPT on one end and a hose barb on the other? Dynon has not replied so far. Thanks …
Jeff Davidson
Posted: Mon Mar 26, 2007 4:48 pm Post subject: Jabiru fuel pressure sensor hookup |
Jeff,
i have the same setup on the sensor, I recommend you go online to Amazon pipes and fittings, you can order the npt fittings there.
juan
Posted: Mon Mar 26, 2007 5:01 pm Post subject: Jabiru fuel pressure sensor hookup |
Hi Jeff,
You can get such a fitting at nearly any hardware store. I used a couple of them made from brass for my LRI.
Paul
XL fuselage
At 04:34 PM 3/26/2007, you wrote:
Quote: | Has anyone found a fitting or set of fittings that has a female 1/8th NPT on one end and a hose barb on the other? Dynon has not replied so far. Thanks …
Jeff Davidson
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
n801bh(at)netzero.com Guest
Posted: Mon Mar 26, 2007 5:48 pm Post subject: Jabiru fuel pressure sensor hookup |
Google Earls fittings, they have EVERYTHING... The worst you have to do is get a 1/8" male fitting and add a 1/8 to 1/8 female coupler.
Ben Haas
N801BH
www.haaspowerair.com
-- Juan Vega <amyvega2005(at)earthlink.net> wrote:
--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net>
Jeff,
juan
Posted: Mon Mar 26, 2007 6:04 pm Post subject: Jabiru fuel pressure sensor hookup |
Thanks Ben. I found a 1/8th AN910 coupling that should work with a left over 1/8th to barb fitting from my fuel system installation.
Jeff
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of n801bh(at)netzero.com
Sent: Monday, March 26, 2007 9:46 PM
Subject: Re: Jabiru fuel pressure sensor hookup
Ben Haas
N801BH
Jeff,
juan
jhstarn(at)verizon.net Guest
Posted: Mon Mar 26, 2007 6:39 pm Post subject: Jabiru fuel pressure sensor hookup |
Two items in the AirCraftSpruce FREE catalog www.aircraftspruce.com might be what you're looking for. Page #113 AN840 hose nipple in brass or aluminum OR page #118 Weatherhead barb-tite. KABONG There are "plastic" adaptors...but not for fuel lines.
HRII N561FS
IF you think this info is worth saving. Hit reply, delete this: Do Not Archive and hit send.
rickpitcher
Posted: Mon Mar 26, 2007 6:57 pm Post subject: Jabiru fuel pressure sensor hookup |
NAPA has an aircraft supply store near you. Just enter your zip code at
their website
www.napaonline.com
Rick
Posted: Mon Mar 26, 2007 7:54 pm Post subject: Jabiru fuel pressure sensor hookup |
Thanks to all that responded.
Jeff Davidson
