		possums(at)bellsouth.net Guest
				 Posted: Sun Mar 25, 2007 7:20 pm    Post subject: Exhaust Ball Joint Conversion Kit - anyone   using it? |
				At 10:17 PM 3/25/2007, you wrote:
 I've used them for 5 years now and have been very reliable. They do
 take some worry out of springs breaking...
 Kip
 Firestar II
 building a Waiex at the moment
 Kip
 Firestar II (born September 2000)
 Atlanta, GA
 N111KX
 The brackets are stainless steel and will cut into the bolts after a
 while. I think they finally replaced
 the old AN bolts with stainless steel. I know we did it ourselves.
 Seems like every time you
 make something better, you find a new problem. I was only able to get
 one on my plane because
 of a clearance problem with the other joint.
 But I  like them.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Mar 27, 2007 5:04 pm    Post subject: Exhaust Ball Joint Conversion Kit - anyone   using it? |
				At 03:01 PM 3/25/07 -0700, you wrote:
 CPS is selling this new "Exhaust Ball Joint Conversion Kit". It's about time for the muffler spring replacement. Anybody using this? If so, what's the verdict so far?
 John,
 I have been using them for 139 hours on the Victor 1+.  I had to cut the
 original pipe and weld in a second ball joint.  The single cylinder engine
 power impulse is quite high so I discarded the original compression spring
 and replaced them with small die springs ordered from McMaster-Carr. I
 believe the trick is get enough joint compression so that it can move/rotate
 due to thermal expansion, but not move due to power impulse.  After 139 hours
 the bolts show no wear.
 The springs I used can be seen on the bottom of:
 http://www.thirdshift.com/jack/firefly/firefly79a.html
 The best photo of the setup is shown on the bottom of:
 http://www.thirdshift.com/jack/firefly/firefly79.html
 If I had it to do over, I would use Richard Pikes method.  If one fabricated
 the end through pieces for small diameter bolts, you would end up with much
 lighter, stronger and very inexpensive clamping system than what I have.
 Jack B. Hart FF004
 Winchester, IN
