jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Mon Mar 26, 2007 12:53 pm Post subject: Floats |
[quote="Steve Boetto"]In a message dated 3/24/2007 9:09:12 A.M. Steve Boetto
Firefly 007 on Floats
Steve, I was wondering how an Ultrastar compares to your Firefly in terms of its capability to use floats?
I will soon have acquired an Ultrastar with the Cuyuna 35 hp engine and want to put floats on it.
How light should my floats be to get a satisfactory performance with the 35 HP or is it even doeable?
I realize the low prop and spray will be a concern for me so I was thinking of a bigger single main body style float with the two midwing outriggers.
Perhaps dual floats with a good spray deflector near the prop area might work as well.
Any suggestions?
Ray
Lake Elsinore, CA
jb92563
Posted: Mon Mar 26, 2007 1:19 pm Post subject: Re: newbie |
Im also a newbie to the Kolb list.....with my impending acquisition of a Kolb Ultrastar next month.
My background is gliders(HP-11), Motor Glider(Moni), Paragliders(P43), and a Lazair.....I wont bore you with all the good reasons to fly all that other stuff.
Diversity is great and each form of aviation is a personal choice for the environment and condition of the pilot....a time and place for every occasion.
Now Im onto a Kolb Ultrastar, because:
- it can handle more wind than the Lazair.
- Its a part 103 Ultralight.
- Does not burn to much gas.
- I can paint it up to look great.
- It will actually make headway in a 30mph wind.
- Im hoping I can flyit from the lake with floats.
- its going to be fun and easy to tinker with.
- I can get a good wind in my hair flight with it.
- I can take off from fairly rough airstips/meadows/beach/sandbar strips with it.
- I can keep it in my backyard and trailer it where ever.
- It just looks and sounds like a blast to fly.
- Ive always admired the Kolbs design and really wanted
to have one of my own.
Ray
Lake Elsinore, CA
Steve Boetto
Posted: Mon Mar 26, 2007 2:35 pm Post subject: newbie |
In a message dated 3/26/2007 4:20:12 P.M. Eastern Standard Time, jb92563(at)yahoo.com writes:
Ray
Lake Elsinore, CA
Ray,
I would seriously consider a Firefly. There are always good used ones out there.
US Points to consider:
Prop issue
Tall mount config required
Very thin wall tubing in a wet environment
I don't know if you can fold the US with Floats
More HP on the FF
More up to date engine on the FF
If you go with the US I will try answer what I can but I have no direct experiance.
steve b
AOL now offertle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
jb92563
Posted: Wed Mar 28, 2007 7:18 am Post subject: Re: newbie |
Hi Steve,
Interesting points you mentioned.
What do you mean by VERY thinwalled tubing in a wet environment?
Are you talking about the welded structure of the US?
Is the FF welded structure of thicker tubing?
Its Crome-Molly tubing on the US as far as I know from my friend.
I assume those floats are ~29lbs each right?
and you can use the parachute allowance? meaning that you do not have a parachute but floats instead?
Pardon all the questions from a newbie, but my other aircraft are experimental category and I dont know about all the ins/out of the Part 103 category.
I dont think the FF is in my budget right now...the US Im getting is only 3K with a trailer, 2 Cuyuna 430's a 2 blade and 3 blade prop.
The wing has a 6" tear in the covering that I need to repair and is otherwise in decent corrosion free condition.
Ray
Steve Boetto
Posted: Wed Mar 28, 2007 9:48 am Post subject: newbie |
Hi Ray,
According to TNK the Ultrastars were typically .028 wall chrome moly. Some early FF were also .028. All of the later FF's are either 50/50 .028 and .035 or all .035. My comment in regard to Very thin wall tubing was directed at the concern for where you attach loads and also the issue of internal rust from years of age. The configuration I saw years ago placed loads on the front of the cage. I do not believe it was designed for that. The Ultrastar looks to be challenging for float mounting.
If you have a BRS that weighs less than 24 lbs you can use the overage but the chute has to be on.
Part 103 gives you up to 60 lbs total for the floats but if your floats weigh less you cannot keep the extra and it does not apply to the mounting gear or spreader bars. This is not much of a factor though because you will have a hard time finding floats that weigh less than 30 lbs each.
Good luck on your project.
Steve
AOL not AOL.com.
Steve Boetto
Posted: Wed Mar 28, 2007 9:57 am Post subject: newbie |
Ray
Also wanted to mention that the key here is to keep your mounting hardware lighter than your existing gear legs, tires, wheels and brakes. It is easy to do on the FF and you actually end up with a little extra weight loss to play with. On a Firefly you need to keep it simple and drop the frills and add BRS to stay in weight in a Float configuration.
Steve
AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
JetPilot
Posted: Wed Mar 28, 2007 10:42 am Post subject: Re: newbie |
I would defintely go for the Firefly, its an updated and improved design... If you cannot afford it, then it will have to be the older ultrastar, but they are old and I would check for rust, corrosion, etc. very carefully.
Why are you so worried about weight ? The ultrastar and the firefly are 103 airplanes, I dont think anyone is going to come out and weigh you on the lake or grass field to see if you are 5 pounds over or not. Dont get too anal about the weight. If I needed a chute, and it put me 5 pounds over weight, i would sure as hell put it on. Maybe some guys would feel good about getting killed "legally" after a structural failure because they were not 5 pounds over weight, but not me. I would put on a BRS, period. If my 103 plane needed something to make it safer, whatever it may be, I would sure as heck put it on and not worry about 5 or 10 pounds that will never make any difference to anyone.
Kolb MK-III Xtra, 912-S |
jb92563
Posted: Wed Mar 28, 2007 10:51 am Post subject: Re: newbie |
I just want to keep it light so I get decent performance with floats on an US with Cuyuna 430.
I plan on WEARING my chute, as I'd rather not be in the seat with the engine and wings behind or above my head if I crash.
I'll take my chances with the tree branches....LOL (No rhyming intended)
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
knowvne(at)aol.com Guest
Posted: Wed Mar 28, 2007 11:45 am Post subject: newbie |
The weight of the BRS or any other recover system is a NON issue for
part 103........
Your legal with or without it regardless of its weight... Put one on
the plane...
ยง103.1 Applicability.
This part prescribes rules governing the operation of ultralight
vehicles in the United States.
For the purposes of this part, an ultralight vehicle is a vehicle
that:
(a) Is used or intended to be used for manned operation in the air by
a single occupant;
(b) Is used or intended to be used for recreation or sport purposes
only;
(c) Does not have any U.S. or foreign airworthiness certificate; and
(d) If unpowered, weighs less than 155 pounds; or
(e) If powered:
(1) Weighs less than 254 pounds empty weight, excluding floats and
safety devices
which are intended for deployment in a potentially catastrophic
situation;
(2) Has a fuel capacity not exceeding 5 U.S. gallons;
(3) Is not capable of more than 55 knots calibrated airspeed at full
power in level flight; and
(4) Has a power-off stall speed which does not exceed 24 knots
calibrated airspeed.
Mark
are 103
airplanes,
about
would
killed
over weight,
something to
not worry
from AOL at AOL.com.
=0
Steve Boetto
Posted: Wed Mar 28, 2007 12:02 pm Post subject: newbie |
In a message dated 3/28/2007 1:43:37 P.M. Eastern Standard Time, orcabonita(at)hotmail.com writes:
Hi Mike,
The issue with weight is important to me for several reasons,
At times I put my FF on display at the Kolb Booth And it should be legal at that time
The BRS is a non issue because the one I am using weighs less than 24 lbs. You do not get the 24 lbs if it is not on the plane. If yours for example weighed 15 lbs then you get the extra 9 lbs free to use.
I also like the personal challenge to play by the rules and win.
Probably most important though is that a Legal Firefly on Floats with a pilot that weighs less than 180 lbs really performs.
If I was interested in traveling greater distances I would register EAB.
Steve B
See what's free at AOL.com.
Steve Boetto
Posted: Wed Mar 28, 2007 12:06 pm Post subject: newbie |
Mark, I see you beat me to the Punch, Well said, a BRS is a Win Win, except on the checkbook
steve
russ(at)rkiphoto.com Guest
Posted: Wed Mar 28, 2007 2:50 pm Post subject: newbie |
Ray
You might want to do some re-thinking.
I doubt you'd be able to get out of a Kolb in time, if something
suddenly happened, esp at a low altitude.
I've done some jumping, but never had the luxury of flying a chute-
equipped aircraft. I consider it a HUGE advantage.
You could deploy it in a second or less if you had to. If a wing
folds do you want to try opening a door & getting out in anything
like that time?
If the price were double or even triple I'd still buy a BRS. My life
is worth it to me.
FWIW
intended)
Ray
http://forums.matronics.com/viewtopic.php?p=103487#103487
