rmallett(at)tampabay.rr.c Guest
Posted: Wed Mar 28, 2007 11:03 am Post subject: 601HD wings modified to 23' |
Hi All,
I have a partially completed 601HD kit. The first owner ordered modified 23' wings instead of the original 27' wings.
It is important when completed this kit comply with LSA requirements. Personnel at Zenith feel there will not
be a problem but to lessen concern vortex generators could be added to the wings lowering the stall speed
by 4 to 6 mph (conservative estimate). Any thoughts to assure LSA compliance especially as it relates
to stall or cruise speeds would be greatly appreciated.
Ray
n801bh(at)netzero.com Guest
Posted: Wed Mar 28, 2007 12:36 pm Post subject: 601HD wings modified to 23' |
Clipping the wings 5 feet will have a huge impact on stall speeds. IMHO
Ben Haas
N801BH
www.haaspowerair.com
-- "ray" <rmallett(at)tampabay.rr.com> wrote:
Hi All,
Ray
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
rickpitcher
Posted: Wed Mar 28, 2007 1:08 pm Post subject: 601HD wings modified to 23' |
Gig Giacona
Posted: Wed Mar 28, 2007 1:15 pm Post subject: Re: 601HD wings modified to 23' |
That basically makes it an HDS. The Zenith site says the HDS has a stall speed at 1050 lbs of 54mph and a top speed of 150mph.
http://www.zenithair.com/zodiac/601-hds.html
The top speed isn't a problem because even if the plane can do it you could adjust the prop so it can't.
The LSA max stall speed is 50 mph. Can you shave off 4 mph with vortex generators? I don't know. But remember that stall speed is at 1050 lbs. that is awful low compared to the XL.
601XL Under Construction
rickpitcher
Posted: Wed Mar 28, 2007 1:53 pm Post subject: 601HD wings modified to 23' |
Gig Giacona
Posted: Wed Mar 28, 2007 4:10 pm Post subject: Re: 601HD wings modified to 23' |
Rick, neither of you posts to this thread can be read in the web forum.
naumuk(at)alltel.net Guest
Posted: Wed Mar 28, 2007 4:16 pm Post subject: 601HD wings modified to 23' |
Ray-
Look in the archives. Unfortunately, LSA figures have to be attained as the plane was originally designed. As I understand it, you can't use VGs to bring an airframe into LSA requirements.
I would suggest contacting EAA or (Gulp) the FAA for a final word.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
rickpitcher
Posted: Wed Mar 28, 2007 5:28 pm Post subject: Re: 601HD wings modified to 23' |
Hi Ray.
I'm glad to see someone trying this. I have an HD that I'm quite pleased
with, but I've considered clipping a couple feet off each wingtip for higher
cruise. That fat HD wing is REAL draggy at 115 MPH (cruise with Jabiru 3300
(at) 108 hp). I hesitate to clip the wings because I don't want to loose too
much of the excellent slow speed with the existing wings.
According to the Zenith specs, the HD stalls at 44 mph. The LSA rules say
max stall speed is 51 MPH
http://sportpilot.org/learn/final_rule_synopsis.html so I'm inclined to
believe you might be OK even without the vortex generators.
Please keep us posted with your results once you get into your flight
testing.
Rick
http://www.lightflyers.com/birthday
rickpitcher
Posted: Wed Mar 28, 2007 5:29 pm Post subject: Re: 601HD wings modified to 23' |
| Gig Giacona wrote: | That basically makes it an HDS. The Zenith site says the HDS has a stall speed at 1050 lbs of 54mph and a top speed of 150mph.
The LSA max stall speed is 50 mph. Can you shave off 4 mph with vortex generators? I don't know. But remember that stall speed is at 1050 lbs. that is awful low compared to the XL. |
The span would be the same as the HDS: 23'. But the total surface area will
be greater than the HDS's 98'ft (compared to 130'ft for the stock HD).
The HD wing is a constant chord at 58" instead of the taper from 58" at the
root to 34" at the tip, so a clip-wing HD will have more surface area than
HDS , hence a lower stall speed than the 54mph of the HDS.
I'm not an engineer, just a mechanic... so anyone who has a better
understanding of the math involved can feel free to correct my aerodynamic
assumptions.
Interesting idea, I'll be anxious to see how it plays out.
Rick
rickpitcher
Posted: Wed Mar 28, 2007 5:35 pm Post subject: Re: 601HD wings modified to 23' |
| Gig Giacona wrote: | | Rick, neither of you posts to this thread can be read in the web forum. |
Thanks Gig. I'll repost from the Web-based site.
Rick
rickpitcher
Posted: Wed Mar 28, 2007 5:53 pm Post subject: Re: 601HD wings modified to 23' |
[quote="naumuk(at)alltel.net"]Ray-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
I don't think that's correct Bill.
From http://sportpilot.org/learn/final_rule_synopsis.html
"The FAA defines a light-sport aircraft as an aircraft, other than a helicopter or powered-lift that, since its original certification, has continued to meet the following: " <snip>
If the plane hasn't been issued an airwothiness certificate yet you're "good to go". If a plane was previously certified with numbers outside the LSA realm, then you can't re-register the same plane with different numbers (speeds weight, etc) in order to "pencil whip" it into compliance.
Rick
Gig Giacona
Posted: Thu Mar 29, 2007 5:24 am Post subject: Re: 601HD wings modified to 23' |
| rickpitcher wrote: | | Gig Giacona wrote: | That basically makes it an HDS. The Zenith site says the HDS has a stall speed at 1050 lbs of 54mph and a top speed of 150mph.
assumptions.
Rick |
Please note that the original poster said, "The first owner ordered modified 23' wings instead of the original 27' wings." He didn't say anything about cliping the wings. I wasn't aware that Zenith ever offered a shorter wing option other than the HDS wing.
Gig Giacona
Posted: Thu Mar 29, 2007 6:07 am Post subject: Re: 601HD wings modified to 23' |
This is an unfinshed kit so the design issue doesn't really apply. When he finishes it he can call it the SuperDuper LSA Special and not mention either Zenith nor 601.
| naumuk(at)alltel.net wrote: | Ray-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Thu Mar 29, 2007 9:53 am Post subject: 601HD wings modified to 23' |
Gig,
The vortex generators would lower the stall speed, but each individual
HDS has to be sorted out on its own stall speed. Some will be slower
and some faster, depending a lot on prop pitch, engine, weight and
fairings present. Too many factors to make a single stall speed fits
all envelope.
Some will make SLA and others won't.
Larry McFarland
Gig Giacona wrote:
> assumptions.
> Rick
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103636#103636
klaus(at)utdallas.edu Guest
Posted: Thu Mar 29, 2007 1:32 pm Post subject: 601HD wings modified to 23' |
Hi Ray,
You may want to do the following. First, you can install
vortex generators, if you are so inclined. This is a quick thing to do.
Then, if that does not suffices, you may want to
look into the wing root fairings I have designed, seen at
http://www.utdallas.edu/~klaus/Airplane/wing_root_fairing.html
With those fairings, you surely will satisfy the LSA requirements,
for the following reasons. For my HDS, the fairings reduced the
stall speed at 1020 lbs from 50 KIAS to 42 kts KIAS, which translates
to 58 mph versus 48 mph. My guess is that a 1,100 lbs, which effectively
is the gross limit for my plane due to CG limitations, I would satisfy LSA.
Your clipped wing HD has substantially more wing area than the HDS
since the wing does not taper. Hence, stall speed will be even lower.
BTW, do not worry about top speed going beyond the LSA requirement.
With all the design improvements, my HDS has top speed somewhere
around 132 mph, single pilot, 3,000 ft altitude.
This is with the 80 hp Rotax 912 UL and
with the propeller pitched so that, in level flight, wide open throttle
produces
5,400 rpm.
Best wishes,
Klaus
Klaus Truemper
Professor Emeritus of Computer Science
University of Texas at Dallas
Erik Jonsson School of Engineering and
Computer Science EC31
P.O. Box 830688
Richardson, TX 75083-0688
(972) 883-2712
vgstol(at)bigpond.net.au Guest
Posted: Thu Mar 29, 2007 2:27 pm Post subject: 601HD wings modified to 23' |
What excellent work Klaus! That's really interesting and significant results.......
Tailwinds always,
JG
rickpitcher
Posted: Thu Mar 29, 2007 2:50 pm Post subject: Re: 601HD wings modified to 23' |
[quote="Gig Giacona
Please note that the original poster said, "The first owner ordered modified 23' wings instead of the original 27' wings." He didn't say anything about cliping the wings. I wasn't aware that Zenith ever offered a shorter wing option other than the HDS wing.[/quote]
Ahhh... I see. Good point Gig.
The title "601HD wings modified to 23'" had me thinking that these were HD wings modified to 23'. I figured the "modified" part meant that they were clipped.
This was discussed on http://groups.yahoo.com/group/601_HD-HDS/
a few months ago. I had talked to one of the ZAC guys (Sebastion?) about doing exactlty that: clipping about 2' from the outboard tip of the HD wing, clipping off the outboard panel and ending the wing at the end of the aileron.
Ray, are the ribs all the same size, or are there pairs of progressively smaller ribs as the planform goes outboard?
Rick
601zv(at)ritternet.com Guest
Posted: Thu Mar 29, 2007 3:09 pm Post subject: 601HD wings modified to 23' |
DITTO! I'm rethinking my planed XL fairings!
Do not archive.
Posted: Thu Mar 29, 2007 4:18 pm Post subject: 601HD wings modified to 23' |
Gig-
I can't say you're right, but I think you're wrong. EAA said NO.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
