Posted: Fri Mar 30, 2007 5:06 am Post subject: Battery and CG |
I feel like I am beating a dead horse, but this does come up every once in a while. I understand that some people want to fly this plane most of the time as if it were a 2-seat airplane. As such, it does ride very close to the forward CG, especially with full tanks. However, putting another battery in the back to help this “problem”, IMHO, is very counterproductive. I realize that Van’s put the first battery back there for most likely this very reason, but with the stock setup, the airplane flies fine throughout all CG configurations (light/forward CG or heavy/aft CG). If you mount a permanent battery aft of the baggage wall and want to fly the airplane like it was designed to fly (2700lbs), you better keep your speeds up, because if you stall and get into a spin, then good luck getting out of it. Would it not be easier, when flying light, to add some ballast in the baggage area or rear seat? It certainly doesn’t make sense to have to add ballast under the cowling when you are flying heavy.
All JMHO!
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
jjessen
Posted: Fri Mar 30, 2007 5:46 am Post subject: Battery and CG |
They may have a heavier engine, but they were not saying. Something with water sloshing around, perhaps. However, you raised, once again, a horse that was on my mind, as well, when I took a look at the dual battery tray (nice job on the tray, nonetheless). I plan to go with either integrated battery backup, or something similar to Tim's setup, light and cheap. Careful with aft CG, guys. Calculate this one verrrrry carefully.
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Friday, March 30, 2007 6:06 AM
Subject: Battery and CG
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
LloydDR(at)wernerco.com Guest
Posted: Fri Mar 30, 2007 5:51 am Post subject: Battery and CG |
I want to stress to people reading this, it is a very valid point and when adding dual batteries or any weight that far aft serious thought should be considered. I agree with Jesse that the best way to add and subtract weight is a collapsible water container. This way the pilot can add weight for situations and dump it on the ramp when it is not needed and store the flat container.
What myself, John and others are talking about is making a dual battery tray to support a dual electrical system to ensure redundancy for an electrically dependant alternative engine install. What we are using for our dual batteries are PC 625 batteries. These only weigh 12-13 pounds a piece, and with the addition of the tray and dual contactors we are less than 1 pound difference of the original install made by Tim with a 925 . I made the decision to mount these at the original location of Vans battery tray because it works there for NOW. But I will stress, we have not done a weight and balance with an installed Eggenfellner package on a completed 10 yet. Mine will be the first and based on my equipage, we will make the determination for the final install location of the dual batteries, as these are the easiest items to move to balance the CG. I expect the W&B of the RV10E will be very close to matching the Lycoming install, but we will not know until I get the engine and cowl final installed.
I just wanted to put this out there, so people can make the distinction between the Eggenfellner install versus trying to do a dual install for a lycoming. We are not talking about dual 925's as this would be over 50 pounds of batteries in an aft CG location, that would be permanent. Once again we are talking dual 625's.
Dan
N289DT
Sent: Friday, March 30, 2007 9:06 AM
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Fri Mar 30, 2007 6:14 am Post subject: Battery and CG |
All understood and very important that the numbers in the end are in the CG
range. There is a requirement for two batteries and putting both of these on
the firewall could make for an even worse senario.
If I recal, we are looking at 25-26 pounds of batteries. Other than these
two mentioned locations. I do not believe there are hardpoints anywhere else
with enough strength to handle the positive and negative Gs. That is a lot
of weight. My tray added 1 pound nine onces inaddition to the batteries.
Don't want the batteries falling out of the tray and rolling to the tail of
the plane!!!!!!!!!!!!!!!!!
JOhn G
| Quote: | From: "John Jessen" <jjessen(at)rcn.com>
Subject: RE: Battery and CG
Date: Fri, 30 Mar 2007 06:46:20 -0700
John J
_____
a
battery in the back to help this "problem", IMHO, is very
counterproductive.
I realize that Van's put the first battery back there for most likely this
if
or
rear seat? It certainly doesn't make sense to have to add ballast under
the
All JMHO!
Jesse Saint
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Posted: Fri Mar 30, 2007 7:04 am Post subject: Battery and CG |
It is not that we are not saying anything about the weight, rather no one has one on the plane yet and can discuss the true weights. Can anyone tell me the Firewall forward weight of a Lycoming with everything installed? No? Not even with more than 70 flying? SO how do you expect their to be a published number of a FWF weight of an engine that has not been installed yet? Exactly, but what Eggenfellner has done is come up with a new methodology of weighing each and every FWF package, including the prop before shipping, so every builder will now what it weighs, including all fluids. I will gladly post this number for all concerned to review, once I receive my engine package.
I would challenge the Lycoming users/ nay Sayers claiming Eggenfellner has a higher weight, to do the same thing with a complete FWF/ Prop combo of an RV10 to post their results as well, before making such a blanket statement. Lets keep in mind there is a whole bigger weight issue of a IO540 versus an IO360.
Dan
N289DT
RV10E
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen
Sent: Friday, March 30, 2007 9:46 AM
John J
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
jjessen
Posted: Fri Mar 30, 2007 8:04 am Post subject: Battery and CG |
Dan, I was not trying to get into any type of engine discussion. You guys were being cute about not raising the engine debate, so I thought I'd be cute back, water sloshing and all that. We all knew you were talking about the Eggenfeller, and more power to you! I'm not a nay sayer, I just wondered aloud if you had a reason for more weight in the back, for, like Jesse, I was concerned about aft CG. I now know that you and John are using lighter batteries, as you've explained. I, too, would like to know how much everything weighs up front, in the panel, behind the panel. Very important to know this stuff. Nice to know Eggenfeller is weighing his stuff. I'll weigh mine when the time comes and post it on my site. On we go.
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lloyd, Daniel R.
Sent: Friday, March 30, 2007 8:04 AM
Dan
N289DT
RV10E
John J
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
james.k.hovis(at)gmail.co Guest
Posted: Fri Mar 30, 2007 8:48 am Post subject: Battery and CG |
Dan,
It's simple, get your empty weight (with coolant) and compare to the
Lyc installations. I can't find it right now (thought Tim had a link
to it), but IIRC, the IO540 weighs dry around 400 to 450 lbs. Now the
dry Subie engine may not weigh as much as the Lyc, but look at the
other things you'll need to run: Radiator, coolant tubing, couple
gallons of coolant, radiator ducting (especially if you're using a
P-51 style scoop, but that's cool!), different engine mount (may be
lighter than the Lyc?) and a reduction unit. All of that leads to the
general comment that any automotive conversion weigh more than a
standard aircraft engine when the ready to run configurations are
compared. Remember the Lyc is designed from the get-go to deliver a
high percentage of its rated power for extended periods, be reliable,
and be as light weight as possible. Car engines just aren't designed
for the same parameters. Plus, the RV-10 was designed around specific
engine installations.
Please don't get me wrong, the trade-off of maybe 50 to 100 lbs loss
of useful load by going to an auto conversion may reap long-term
benefits - fuel cost savings and future overhaul costs. Remember too
that proper balancing is VERY important. The -10 is designed with the
tail surfaces set a specific distance from the wing and with specific
surface areas. This is to give good control authority and keep the
airplane flying stably over it's designed operating speeds. If your
empty CG results in having a full-load CG near or forward of the
designed limit will make it extremely difficult for the tail to lift
the nose wheel off the ground and to maintain level flight. CG at or
aft of the aft limit is just suicide, your control will be UNSTABLE!.
Now, for a whole host of reasons previously discussed, if your empty
weight ends up being say 1,650 lbs, don't assume you can just up the
gross weight spec
to 2,830 lbs to keep the Van's published 1,180 lbs of useful load
without getting a SERIOUS engineering analysis. And keep away from the
published Vne.
I'm not trying to discourage you from doing the Subie installation.
In fact I'm waiting to see how it turns out. But remember, one reason
for buying a Van's airplane is that they did the extensive engineering
legwork to determine a "good" combination of airframe and engine to
perform a specific mission. Whenever someone deviates from that
original design work, you are getting into unknown territory and you
should get serious analysis and advice from professionals so that you
can keep safe and within established aircraft standards.
Let me know how the installation goes (irt empty weight) and how well
it performs in flight!
Kevin Hovis.
On 3/30/07, Lloyd, Daniel R. <LloydDR(at)wernerco.com> wrote:
| Quote: | It is not that we are not saying anything about the weight, rather no
Dan
N289DT
RV10E
_____
verrrrry carefully.
John J
_____
another battery in the back to help this "problem", IMHO, is very
counterproductive. I realize that Van's put the first battery back
certainly doesn't make sense to have to add ballast under the cowling
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics
Posted: Fri Mar 30, 2007 8:57 am Post subject: Battery and CG |
I apologize if my comments were taken that way, I was trying to stress we did not add any weight, or at least less than a pound, what we did was split the weight between two 625's instead of a single 900 series like others are using.
If my comments came across as harsh I did not mean them too, and that is usually what is lacking in an email environment is the laughing person at the key board!
Dan
Sent: Friday, March 30, 2007 12:04 PM
John J
Dan
N289DT
RV10E
John J
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Tim Olson
Posted: Fri Mar 30, 2007 9:27 am Post subject: Battery and CG |
The people that know me well know that if I'm typing away at
the keyboard, I'm almost always chuckling away while I do it.
So forgive me in advance, but take anything I say that could be
misconstrued as an attack as a feeble attempt at humor.
Lloyd, Daniel R. wrote:
| Quote: | I apologize if my comments were taken that way, I was trying to stress
at the key board!
Dan
Posted: Fri Mar 30, 2007 9:57 am Post subject: Battery and CG |
And that is the point I was trying to make, that the Total weight FWF of
any engine for the RV10 is unknown, and at this time we currently do not
know any of the numbers.
What we do know is that on the Subaru side all FWF packages will be
weighed complete, with coolant radiators and prop. And my point was that
I would like to know what a wet weight with accessories, oil coolers,
hoses and prop, and wiring/probes etc a Lycoming weighs. I have the dry
weights of the engine and some accessories, but not as a complete
package for the Lycoming so it is a mute point on weight comparison
until someone does the work necessary to unbolt a complete install and
weigh it as installed.
Conversely to the smaller RV's that install the H6 and have to worry
about to much weight, I am worried about to little weight forward. I
would like nothing more than to come out with the same distribution of
weight across the gear as the Lycoming install but I do not think it
will happen, instead I will have to move the batteries forward to offset
to little engine weight, but time will tell, and that was my point. No,
and I stress no known RV10's are flying with the Eggenfellner package
yet, so anything we are saying is pure conjecture. Now in the next
several weeks I will be able to post to everyone what it weighs when it
got here and what it does to the W&B tables, but until I have it
completely installed we are just making best guesses. I guarantee I will
not fly with the CG anywhere near aft because I will be very worried
about stall recovery, matter of fact if the weight is much different
than the average RV10 install I will ballast/ move things to better
match what is the norm so I can replicate the flight parameters of the
"standard" builders plane...oh wait they are all different because we
each can do our own thing, right? (Here is an example of that poor
attempt at humor)
No offense intended just light hearted banter.
Dan
N289DT
rvbuilder(at)sausen.net Guest
Posted: Fri Mar 30, 2007 10:38 am Post subject: Battery and CG |
Interesting proposition. Shouldn't be too hard for someone that is prior to the FWF to weigh all the standard components for a Lyc FWF before they hang them. I would offer but at my current rate JC might beat me.
Michael
Posted: Fri Mar 30, 2007 11:38 am Post subject: Battery and CG |
What is appearent however is your enthusiasm at being the person at the head
of the calvary. You are proud and excited, obviously you see the light at
the end of the tunnel. Keep pluggin away.
get back to work!!!
| Quote: | From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Date: Fri, 30 Mar 2007 12:57:00 -0400
at the key board!
Dan
_____
John J
_____
R.
Dan
N289DT
RV10E
_____
verrrrry carefully.
John J
_____
All JMHO!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
speckter(at)comcast.net Guest
Posted: Fri Mar 30, 2007 12:50 pm Post subject: Battery and CG |
I appreciate your sense of humor through all of this. Experimenting is what
homebuilding is all about. Talk to all who are concerned and make sure you
have addressed the issues they raise, then forge forward. Ain't the
freedom great.
Gary
41274
