		John Bickham
  Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
				 Posted: Fri Mar 30, 2007 1:12 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				Hello list,
 Getting close to finishing up the repairs and modifications on my Mark IIIC.  Finished cutting and fitting new Lexan yesterday.  Got some leftovers and started thinking about rudder and aileron trim tabs.  Not sure if there is a preference between aluminum or Lexan.
 Looked in the archives for sizes and angles.
 From John H, May 2000:
  	  | Quote: | 	 		  The 21.75" X 3" tab bent 30 deg is too much trim.  I will
 cut it down to 14.75" X 3" and test again.  Most likely I
 will stay  this dimension since I do not want to drill out
 anymore rivets, even though it is easy to drill the alum
 fabric rivets.  I use a 2" lip to attach the trim tab to the
 ribs on left side of rudder.
 Any pictures and descriptions would be much appreciated.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators.  There is a distinct difference that I have the greatest respect for. |
		JetPilot
				 Posted: Fri Mar 30, 2007 3:49 am    Post subject: Re: Rudder Trim tabs for MIIIC w/ 912UL |
				THe lexan looks a lot better, but it is much heavier than aluminum.   Just be careful not to get to much weight out on the end if the control surfaces, or you can induce flutter.  I used aluminum on my ailerons and elevators for this reason, its also easier to bend if you need to adjust it.
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		Paul Petty
				 Posted: Fri Mar 30, 2007 5:43 am    Post subject: Re: Rudder Trim tabs for MIIIC w/ 912UL |
				Hey John,
 Wanna race to the finish? Im shooting for easter hehehe
  _________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
				 Posted: Fri Mar 30, 2007 5:55 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
  | John Bickham
 Morning John:
 The description of my trim tab was a little confusing.
 Overall dimentions are:  14.75" X 5"
 .025 aluminum works well.  I prefer it over lexan.
 Bend a 2" lip on it 30 degrees.
 Attach to rudder ribs with aluminum fabric rivets.  I like the large
 flange heads.  I think I used three rivets per rib, and it covers
 three ribs.
 Attach trim tab to left side of rudder.
 Works great.
 PS:  Got my center section parts primed yesterday.  First time the
 spray gun has been out since I rebuilt the left wing in 2000 and 2001.
 Took me half a day to get set up.  Turned out ok despite loads of
 pollen, wind and dust.  Had to paint outside under a tent fly.  Also
 primed the gear legs which are holding up well considering some of my
 more spetacular landings.  If I am smart, and I have my doubts, I will
 wait until we have rain, which is finally forecast for this weekend,
 before I try to shoot Pontiac Red Aerothane.  Aerothane shows every
 little bit of dust, pollen, lint, and other contamination.
  _________________ John Hauck
Titus, Alabama |
				 Posted: Fri Mar 30, 2007 5:57 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
 | John Bickham
 John B:
 If you still need a photo of trim tab I will see if I can get you one.
 I have the fuselage in the basement, but the horizontal stabilizers
 are taped up to the rudder and vertical stabilizer.
 Let me know.
Titus, Alabama |
		Paul Petty
				 Posted: Fri Mar 30, 2007 11:06 am    Post subject: Re: Rudder Trim tabs for MIIIC w/ 912UL |
				Gang,
 What is the cause or source of air that requires our planes to need a trim tab on the rudder? Should I go ahead and make one for my Kolbra before it is flown for the first time?
Kolbra #12
Ms Dixie
912 UL 70" warp |
		Paul Petty
				 Posted: Fri Mar 30, 2007 11:21 am    Post subject: Re: Rudder Trim tabs for MIIIC w/ 912UL |
				Mike,
 I just re-read your post on trim tabs. You have them on your ailerons and elevators? If so can you take some photos and post to the list or send me directly?
Kolbra #12
Ms Dixie
912 UL 70" warp |
				 Posted: Fri Mar 30, 2007 12:12 pm    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
 | Paul Petty
 Paul:
 Don't worry about trim tabs until after you thoroughly test your
 airplane.  Then, before you decide on what you what to correct and
 how, make sure you fly a couple long cross country flights,
 maintaining a heading and altitude.  Your arm will tell you exactly
 what you need and how much.
 When it comes time to make a rudder trim tab, talk to John W and Mark
 G, who have been flying their Kolbras for some time.
 Roll correction can be made with Steven G's excellent tool that
 changes the angle of attack of on wing.
 Pitch correction can be made with elevator forced trim, and also flaps
 which you can adjust to give you some reflex if you have a tendancy to
 drop the nose.
 Ov e4r the last 2,500+ hours, the tang that keeps the flap handle in
 place at neutral flaps has worn approximately 1/8".  The other day I
 popped a 4130 tab behind the worn one, cut a new knotch init with a
 5/32" chain saw file, and now I have flaps that are going to be a tad
 reflexed, I hope.  That'll help bring the nose up and maybe give me a
 little more cruise speed.
Titus, Alabama |
		dhkey(at)msn.com Guest
				 Posted: Fri Mar 30, 2007 5:26 pm    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				Why does everyone have essentially the same sized trim tab the same
 direction on the rudder. It seems like something on the plane could have
 been designed differently.
				 Posted: Fri Mar 30, 2007 5:33 pm    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
 have
 David:
 It is not the airplane, it is the prop blast and the way it hits the
 tail section.
 My mkIII is trimmed perfectly with the engine shut down and no trim
 tab on the rudder.  But when the power is brought up, the nose wants
 to go left and the trim tab takes care of that.
Titus, Alabama |
		knowvne(at)aol.com Guest
		Ed in JXN
				 Posted: Fri Mar 30, 2007 6:42 pm    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				Hi David,
         The culprit is a combination of forces present in all single-engine
 prop-driven aircraft (and most twins), too.  They are:
         Torque:  The twisting force the engine exerts on the prop.
         Spiraling slipstream:  The 'corkscrew' effect of the airflow over
 the aircraft structure, especially the tail group.
         Gyroscopic precession:  Think of the prop as a huge gyroscope, which
 it is.
         'P' factor:  The uneven (asymmetric) loading of the prop, more
 prevalent at slow airspeeds and high angle-of-attack.
         The need for trim tabs isn't the fault of the designer.  Maybe Sir
 Isaac Newton.
         The forces most prevalent in cruise are torque and spiral
 slipstream.  A good explanation for things like this is "The Pilot's
 Handbook of Aeronautical Knowledge", AC 61-23(X?), I don't know what the
 latest version is.  You can order it from the GPO or Sporty's (sportys.com).
         For those desiring even more punishment, "Aerodynamics for Naval
 Aviators" should keep you occupied.  Recommended only for those lacking any
 type of social life.
 Ed in JXN
 MkII/503
		pj.ladd(at)btinternet.com Guest
				 Posted: Sat Mar 31, 2007 1:53 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
 Hi Ed,
 in this instance is it not the twisting motion which the engine imparts to
 the AIRFRAME not the PROP which is the force which needs correcting?
 Just a thought.
 Pat
				 Posted: Sat Mar 31, 2007 1:56 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				It seems like something on the plane could have been designed differently>>
 Hi
 you are dead right. The fin could have been built slightly offset, and some
 are,  but think of the complications in the building process and even then
 it would only be absolutely correct for one speed and/or throttle setting.
 Cheers
 Pat
		Steve Boetto
				 Posted: Sat Mar 31, 2007 3:31 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				In a message dated 3/30/2007 10:43:01 P.M. Eastern Daylight Time,  knowvne(at)aol.com writes:
 Blame Rotax
 They build the 912 so it spun the prop in the    wrong Direction....
 Mark
  Hi Mark,
  The 447 spins in the opposite direction, and guess what, the trim tab goes  on the other side.  Bryan Melborn of Custom Air mounts the same tab on  every plane and gets consistent results.
  Steve B
 See what's free at AOL.com.
		Steve Boetto
				 Posted: Sat Mar 31, 2007 3:41 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				It is interesting to look at an example of a Tail-less Pusher like a  Long-EZ and see the results. On mine with a 160 hp engine and a 64x79 pitch wide  blade prop there was almost no rudder change across idle to full power. P factor  and torque are real issues but I agree with the Kolb Masters that the main  culprit is wash on the vertical tail.
  steve b
		d-m-hague(at)comcast.net Guest
				 Posted: Sat Mar 31, 2007 3:45 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
				At 05:52 AM 3/31/2007, pat ladd wrote:
 Hi Ed,
 Newton:  Equal and opposite reaction.
                                  -Dana
 The citizens of the United States are getting the government they deserve.
 The problem is that I'm also getting the government they deserve.
				 Posted: Sat Mar 31, 2007 5:39 am    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
 differently>>
 | Hi
 | Pat
 Patrick:
 My thoughts exactly.
 I tried to get the old Kolb Company to experiement with this solution,
 off setting the leading edge of the vertical stabilizer.  They never
 got around to it and I got tired of flying 1/2 ball out of trim.
 I off set mine several times, eventually ending at 1 1/8" with very
 little improvement.  After all that drill, about three or four
 different locations, I repositioned the leading edge of the vertical
 stabilizer back to the center.
 Then I went back to the rudder trim tab which was one rib bay long.
 Tripled the length to three rib bays.  That was too much.  Cut one rib
 bay off the length and came up with the dimensions and photos I shared
 a couple days ago.  Works perfect now.
 I might add I also experimented with many different engine to airframe
 changes without success, eventually putting the engine back where
 Homer put it in the first place.
Titus, Alabama |
		JetPilot
				 Posted: Sat Mar 31, 2007 6:57 am    Post subject: Re: Rudder Trim tabs for MIIIC w/ 912UL |
				 	  | Steve Boetto wrote: |
  Hi Mark,
  Steve B
 That say a lot for Bryans building skills.  If all the trim tabs on all his planes all turn out to be the same, thats as close to perfect as you will ever get.
				 Posted: Sat Mar 31, 2007 6:09 pm    Post subject: Rudder Trim tabs for MIIIC w/ 912UL |
 Date: Sat, 31 Mar 2007 07:41:12 EDT
  	  | Quote: | 	 		  It is interesting to look at an example of a Tail-less Pusher like a
 Steve and Kolbers,
 Out of curiosity, I looked at the magnitude of the propeller torque that has
 to be resisted by the FireFly in the roll axis for level flight.  Assuming
 that under cruise conditions the engine is developing a torque of 40 foot
 pounds.  Multiplying by the belt ratio (2.7) gives 108 foot pounds torque
 that the air frame must resist.  To compensate most add trim some where in
 the roll control system.  Another possibility is that one could add weight
 to the propeller down swing wing tip to dynamically balance out the torque.
 I would have to add 108/11 or 9.82 pounds to the right wing tip to prevent
 torque roll off at cruise.  For those who are moving up the hp scale, the
 amount could easily double and triple.  I would not want to try to takeoff
 or land a FireFly with a 10 pound weight on one wing tip.
 Not practical but interesting.
 Jack B. Hart FF004
 Winchester, IN
