johngoodman
Posted: Sun Apr 01, 2007 3:34 pm Post subject: QB Wings question |
Starting my QB Wings and I've been reading through the plans. It looks like the first page that applies to Quick Build is the fuel senders and then the stall warning.
Just want to make sure I didn't miss anything that wasn't done.
dmaib@me.com
Posted: Sun Apr 01, 2007 4:22 pm Post subject: QB Wings question |
That is where we started on our QB wings. Found a couple of places
where rivets were installed that should have been left out, but no
real problems. Supposed to be a couple of empty rivet holes for the
stall warning access plate doubler to be clecoed to the skin to match
drill the corner holes. If you are using the Vans pitot tube, you may
find a rivet installed in that location also. We have come across a
couple of places where it appears holes should have been drilled in
an earlier section, but were not, nut plates that would normally be
installed in an earlier section, etc. None are a problem, but makes
reading through the plans a necessary step.
David Maib
40559
wings
On Apr 1, 2007, at 6:34 PM, johngoodman wrote:
<johngoodman(at)earthlink.net>
#40572 Empennage done, starting QB Wings
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=104359#104359
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
