captainron1(at)cox.net Guest
Posted: Tue Mar 27, 2007 6:13 pm Post subject: Props and engine mount |
for all the senior Kolbers here is a question. I am about to weld in place the engine mount. I have now the option of lowering the mount a bit to reduce thrust line. I have done some measuring and it looks like I can reduce it some with a 2 inch prop clearance from the tail boom and have a max size of a 68 inch prop. I figure that at best the rubber mount would flex .5 inch which would still give me ample clearance, from the boom. Or I could of course go to a 3 inch clearance from the boom and raise the mount an inch.
I guess the best question to ask is what is the minimum prop I can use and still be on par with the best performance. I know there are some more variables I can throw into this. But some ideas from which I can work will be real good.
The next item is the angle of the mount. I am following the original mount bed angle on the assumption that Dennis Souder got it right when he figured it. Any opinions about that, shell I change it and if so why?
John H what prop size and kind are you using?
Anyone using a 4 blade?
Richard Pike
Posted: Tue Mar 27, 2007 6:21 pm Post subject: Props and engine mount |
What engine and reduction ratio?
Richard Pike
MKIII N420P (420ldpoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Tue Mar 27, 2007 6:32 pm Post subject: Props and engine mount |
| Anyone using a 4 blade? Ron Mason
Ron:
I am a Warp Drive man. Been using strickly Warp Drive since September
1993.
I have used 70 and 72 inch three blade props. Both work well. The 6
ft prop is a little noiser than the 70" prop.
I like to keep the thrust line as low as possible. The 72" prop had
3/4" tail boom clearance. Close proximity to tail boom and other
structure may increase the noise level.
I have a 70" prop waiting to be mounted on the new 912ULS.
I see no reason to change the design and attitude of the standard Kolb
engine mount. I think Homer Kolb knew what he was doing a lot better
than most of us.
As far as what prop to use for your Geo engine and redrive, I have no
idea.
PS: John W uses a 68" 3 blade Warp Drive on his Kolbra.
_________________ John Hauck
Titus, Alabama |
Posted: Tue Mar 27, 2007 11:23 pm Post subject: Props and engine mount |
"This gearbox was designed for aviation conversion of engines up to 160 h.p. It is in production since 2000. The available reduction ratios are 2.03, 2.34, 2.5. There is a German (BMW) rubber damper between the gear box and the engine. The propeller moment of inertia up to 9,000 kg/cm2. Rotax-style propeller hub, propeller shaft with a hole so it can be used with variable pitch prop or for glider towing. It is possible to use this gearbox for both (tractor and pusher) layouts, install it up, down and any degrees left or right. "
The motor is a 105-110 hp Suzuki. The above is a quote from the vendor's web site.
Ron (Arizona)
Richard Pike
biglar
Posted: Wed Mar 28, 2007 2:58 am Post subject: Props and engine mount |
I'd be interested in more info about the redrive, Ron. Who's the manufacturer, and what's his website ?? Thanks Lar.
On 3/28/07, Ron <captainron1(at)cox.net (captainron1(at)cox.net)> wrote: [quote]--> Kolb-List message posted by: Ron <captainron1(at)cox.net (captainron1(at)cox.net)>
Ron (Arizona)
---- Richard Pike < richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Wed Mar 28, 2007 6:16 am Post subject: Props and engine mount |
Anyone,
I always wondered why the plans called for 3 washers in the back and 2 in front for the 912 mount. Why not 2 in rear and 1 in front?
Can 1/16" make that much difference anyway?
John , I thought you were running a 74'' Warp.
Vic
912 UL Extra
Maine
_________________ MKIIIX040
912UL |
Posted: Wed Mar 28, 2007 6:30 am Post subject: Props and engine mount |
Ron
I don't know about that senior thing but.... I built my VW mount with two
inch clearance for a 72 inch prop. I also set the thrust line just slightly
up from being even with the bottom of the wing. I figured the wing would fly
with just a bit of up angle of attack.
My assumption is that the most efficient thrust angle would be straight back
at cruise. A thrust line pushing the plane down would not be good and having
the thrust line lifting the plane would not be as efficient as lift from the
wing.
Rick Neilsen
Redrive VW powered MKIIIc
Posted: Wed Mar 28, 2007 6:39 am Post subject: Props and engine mount |
Vic
Vic:
1/16" will not make any difference.
I discovered many years ago the amount of engine movement with a 447
powered Firestar. Was amazed at how much the engine tilted under full
power.
I experimented with different angles of mounting the engine on the
mkIII and came to the conclusion I was wasting my time. Now I fly
with the engine as low as possible and in the standard configuration
with the hardest Lord mounts available. Travis sends these hard Lord
mounts with the mkIII kits.
72" is largest prop I have flown with.
Titus, Alabama |
by0ung(at)brigham.net Guest
Posted: Wed Mar 28, 2007 6:57 am Post subject: Props and engine mount |
reduce thrust line.
Ron
I guess it depends on what engine you will be using,,, what altitude you
will be flying at most,,, and what properties you want your plane to have.
When I called warp drive and asked for my application. I was told 68 inch 3
blade full width tips. Darrell at warp drive told me that the full width
tips were best suited for sea plane and / or high altitude applications.
I have a mark III with a 912 80 hp. field elevation is 4426 ft and density
altitudes in the summer of 6000 + or - and to fly over the mountains I go
to 8000 ft msl on a regular basis.
John H has the 912s 100 hp version. And uses a 72 inch taper tip blade.
Which warp drive told me was best suited for his plane and application.
In short, I think I would call Darrell at Warp Drive, explain your
situation, and ask for his advice. I don't think he would steer you wrong.
As for tip boom clearance,,, I think 1 1/2 to 2 inch should be ok it seems
that some are using on inch or so. The biggest problem would be involved
in how much shake the engine has during start up and shutdown.
Boyd
Posted: Wed Mar 28, 2007 11:21 am Post subject: Props and engine mount |
I think I want to stay with the 2 inch clearance that is mandated for standard airworthiness aircraft. It specifies a 2 inch clearance as a minimum. I suppose with super rigid mounts less would be safe, but I am not sure vibration was the only reason for the clearance. I've wanted a 4 blade prop for some time, I think it probably gives better thrust effect (I don't want to start up the old debate of how many blades are better). I mostly want to do it for my own gratification and to validate my theory. That is why I figure a 68" would be fine. But if it does not work out I certainly want the option of going to a larger diameter prop. I think JH probably experimented with most of that stuff, but I would want to know if there was any side by side comparisons. I think that lowering back drag from the rear engine mount supports and prop eficiency all else equal may give the best return on effort spent.
I will call the fellow at Warp Drive and see what he has to say.
Ron (Arizona)
---- boyd <by0ung(at)brigham.net> wrote:
--> Kolb-List message posted by: "boyd" <by0ung(at)brigham.net>
reduce thrust line.
Ron
in
JetPilot
Posted: Wed Mar 28, 2007 1:40 pm Post subject: Re: Props and engine mount |
Why would anyone want a 4 blade prop on a Kolb ? The climb would be horrible. With a 4 blade prop, you have less area producing a faster airstream, so IF you had a plane with a high top speed, 4 blades would make it faster.
A Kolb is so slow, that you would never see any advantage of the higher velocity from the prop. Its kind of like putting a small jet engine on a Kolb, you would have a huge amount of air velocity out of the enigne, but not that much thrust in pounds.. All that HP with a low static thrust would be wasted on a slow and draggy plane.
With a 4 bladed prop, you will be lucky if you dont lose so much thrust that the plane not only climbs horribly, but will be acutally slower than the 3 bladed prop. It looks like you have been looking at to many fast GA airplanes with 4 bladed prop, and not understanding that it just wont work well on a Kolb. But Im all for having real life testing over theory, as long as its someone else paying for the testing I look foward to seeing the results.
Kolb MK-III Xtra, 912-S |
Posted: Wed Mar 28, 2007 6:34 pm Post subject: Props and engine mount |
If I ever wanted proof that I never get what I want here it is. I did not want a debate about props. But I must say and I will not explain as I am holding out for consultation fees, that a 4 blader will be better especially in climb and throughout the range.
We shall see stay tuned, mmm unless I run out of money first. I will borrow a 3 blader from whoever, whenever install it on my flyer and will do both time to climb and cruise. That is the only way to do it. Maybe next year at Monument V we can test it.
,Ron (Arizona)
---- JetPilot <orcabonita(at)hotmail.com> wrote:
--> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com>
JetPilot
Posted: Thu Mar 29, 2007 8:43 am Post subject: Re: Props and engine mount |
| captainron1(at)cox.net wrote: | If I ever wanted proof that I never get what I want here it is. I did not want a debate about props. |
Hahaha,
That was just an irresistable subject I just bought a 3 blade warp to replace my 3 blade Kiev, so that 4 blade had better not perform better ! What engine do you have, and are you going to get the Warp Drive 4 blade ?
I went to the war drive, because the Kiev is so light is scares me to use it. On a pusher if anything goes through it from the engine, it will explode into a million peices. I also had an airline inspector look at it ( he also flys ultralights ) and he was worried about how light the hub was, and if it would hold up over time. I think a Kiev would be perfect for a 2 stroke engine, but I just dont trust it on a 912 - S.
Richard Pike
Posted: Thu Mar 29, 2007 9:08 am Post subject: Props and engine mount |
I borrowed a 3 blade Kiev from a friend, size and shape optimized for an
HKS, 2 seat CGS Hawk, and mounted it on the Kolb with 582, B box, similar
reduction ratio. Compared against a 68" two blade Ivo, the Ivo gave better
results. Details in the archives.
Richard Pike
Kingsport, TN 3TN0
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Mar 29, 2007 10:07 am Post subject: Re: Props and engine mount |
Knowing a fair bit about props I though that i would mention that
more blades increase the thrust but reduce the top end.
So if you want more low end thrust as in a climb optimized prop then go for the extra blade, but if you are lacking top end speed the the 4th blade will slow you even more than the 3 blade.
Ray
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Posted: Thu Mar 29, 2007 10:12 am Post subject: Props and engine mount |
I was looking at that wood prop in 4 blades, I forget the name Kentucky props or something like that. Seemed fairly reasonable price wise for a starter prop.
Ron (Arizona)
| Quote: | If I ever wanted proof that I never get what I want here it is. I did not want a debate about props.
Hahaha,
http://forums.matronics.com/viewtopic.php?p=103682#103682
kugelair.com
HShack(at)aol.com Guest
Posted: Thu Mar 29, 2007 7:25 pm Post subject: Props and engine mount |
In a message dated 3/29/2007 12:46:02 PM Eastern Daylight Time, orcabonita(at)hotmail.com writes:
| Quote: | | I think a Kiev would be perfect for a 2 stroke engine, but I just dont trust it on a 912 - S. |
Robert Broadwell of the Trenton Flyers has a 3 blade Kiev on a Mk III with 912S; no problems in approx. 300 hrs. & over 900 water landings, shows no wear.
I have one on my FSII; it replaced a Warp 3 blade. It's quieter than the Warp, I like the scimitar shape & the bronze leading edge. I think it is much easier on the gearbox.
To each his own.....
Howard Shackleford
FS II
SC
See what's free at AOL.com.
JetPilot
Posted: Fri Mar 30, 2007 4:28 am Post subject: Re: Props and engine mount |
| HShack(at)aol.com wrote: |
Howard Shackleford
FS II
SC
What kind of engine do you have on your FS II ? Did you notice any differences in the performance between the Warp and the Kiev ?
Posted: Sun Apr 01, 2007 5:55 pm Post subject: Props and engine mount |
In a message dated 3/30/2007 8:29:58 AM Eastern Daylight Time, orcabonita(at)hotmail.com writes:
| Quote: | | What kind of engine do you have on your FS II ? Did you notice any differences in the performance between the Warp and the Kiev ? |
I have a 503DCDI. I expected better performance because it "looks" like a more efficient shape, but no performance increase. Lighter, quieter, better looking.
Howard Shackleford
FS II
SC
