tommylutz(at)gmail.com Guest
Posted: Sat Mar 31, 2007 6:18 am Post subject: Workshop Space / Shed Construction |
Ok, so I've decided against a shipping container because my neighbors don't like it and I think it won't be enough room.
I would like to put up a large shed in my backyard. I like the fabric idea, but I personally want something more permanent ( i.e. metal or wood).
I'm looking to you guys for recommendations on the following:
-width/height/length: I saw a 16'x16' shed at the local lumber store (84 lumber). Looks like enough space but not enough vertical clearance (beams going overhead ~6.5')
-get plans, buy a kit, or buy pre-fab? The shed I saw locally came with all the lumber needed, but building one from scratch may be more economical. This one was ~$2300.
-recommended manufacturer / distributors (I'm in North NJ if that makes a difference).
Thanks!
Tom
CH701 - Rudder skeleton fully clecoed
dredmoody(at)cox.net Guest
Posted: Sat Mar 31, 2007 7:02 am Post subject: Workshop Space / Shed Construction |
I'm currently working on the fuselage in a workshop room which is 15' x 20'. When I have to hang the engine mount and engine on the front, that 20' dimension is going to be a bit on the puny side of comfortable, even with the rudder off. Still at that amount of space accompanied by some juggling of bandsaw, scotchbrite lathe etc. it will work. Hindsight tells me that 25' to 30' in length would be just peachy. The 15' width has been adequate. The rafters are 8' from the floor and that's been fine too.
Dred
601XL/Jabiru/canopy
naumuk(at)alltel.net Guest
Posted: Sat Mar 31, 2007 9:44 am Post subject: Workshop Space / Shed Construction |
Tom-
Whatever you figure the minimum space you'll need, double it and you'll still come up short!
My 14x28 garanger still isn't going to do it when it comes time to do the rigging. Warned Ma I was going to have to take over the main garage for a couple of weeks and got looks that would kill. Made a compromise. Her truck gets the garanger while I'm rigging and my car sits out in the driveway.
You do what you have to!
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
bill_dom(at)yahoo.com Guest
Posted: Sat Mar 31, 2007 3:55 pm Post subject: Workshop Space / Shed Construction |
I built a shed of my own design using 2x4 lumber, plywood siding and shingle roof. It is anchored over a concrete floor. The shed size is 8x20 due to space limitations in the area of the patio where I need it. In my case, I have a one car garage that I going to be using for storing the subassemblies already made, leaving the shed only for building.
Before I started, I did lots of research and considered many options but my main issue issues with all commercially available sheds was not finding one with the exact dimension that I needed and doted with a full width frontal door, so my no compromise solution was to build it myself.
My take is that an ideal shed for building an airplane should have:
- A concrete floor.
- Have a wide front door.
- Big enough to build an airplane but small enough to fit where you want to place it
- Have good insulation (aluminum sheds are very bad at this)
My recommendation would be to buy one if it meet the characteristics above and is within your budget. Otherwise, build it yourself from scratch and save some money. Mine took 9 days of full time work to build.
William Dominguez
Zodiac 601XL Plans
Miami, Florida
Tom Lutz <tommylutz(at)gmail.com> wrote:[quote] Ok, so I've decided against a shipping container because my neighbors don't like it and I think it won't be enough [quote][b]
rgeese
Posted: Sun Apr 01, 2007 4:02 am Post subject: Re: Workshop Space / Shed Construction |
I'm, building my 601XL in a self-built (from plans) 12' by 20' wooden barn with an 8' ceiling an loft. I certainly wouldn't want to go any smaller than that. Everything was completed in the barn and moved into my garage after completion. The fuselage is still in the barn, but I am outgrowing it. I won't be able to install the engine, main gear, or rudder there. I can't complete the canopy installation either because there isn't enough headroom for the tilt. Soon I will be trading spaces with everything stored in the garage.
I have a couple hundred photos at this site:
http://rgeese.spaces.live.com/default.aspx?_c01_blogpart=myspace&_c02_owner=1&_c=blogpart
You may be able to get an idea of the space.
chuck_maggart
Posted: Mon Apr 02, 2007 7:36 am Post subject: Workshop Space / Shed Construction |
Tom, I built my 601XL in a 20'x16' shop. It was adequate for building, but I had to store the wings in my house while building the fuselage. One thing to watch is the overhead clearance when you install the canopy. It requires 9'1" height to open my canopy.
Chuck, XL/Jabiru ready for final assembly
_________________ Chuck Maggart |
