fuse conduit anchor points
jaybrinkmeyer(at)yahoo.co
PostPosted: Tue Apr 03, 2007 2:46 am    Post subject: fuse conduit anchor points Reply with quote
I'm running ~1.1" conduit in the beneath the rear seats and baggage floors on
the outboard walls as several other folks have done. Two custom clamps/brackets
at the tailcone side securely hold the conduit exit points. The entry next to
the rear seats is pretty snug (RTV?).
What's acceptable practice to secure the slack middle points to the bulkheads?
Do they make adel clamps in really big sizes? Once the floors get sealed up
it's going to be difficult to change anything in the middle...
Thanks in advance for any input.
Jay
Don't get soaked. Take a quick peek at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
jwt(at)roadmapscoaching.c
PostPosted: Tue Apr 03, 2007 4:03 am    Post subject: fuse conduit anchor points Reply with quote
I used the stick on tie wrap holders. First I cleaned the area real good and
then used E6000 to make sure they stay stuck. (photo attached)
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Paint prep and LOTS of misc stuff
 Filesize:  675.03 KB
 Viewed:  294 Time(s)
wcurtis(at)nerv10.com
PostPosted: Tue Apr 03, 2007 5:16 am    Post subject: fuse conduit anchor points Reply with quote
Try these:http://terminaltown.com/Pages/Page65.htmlThe come in handy in various lighting holes.http://wcurtis.nerv10.com/07Wings/wings95h.htmlWilliamhttp://wcurtis.nerv10.com/ --> RV10-List message posted by: Jay Brinkmeyer I'm running ~1.1" conduit in the beneath the rear seats and baggage floors onthe outboard walls as several other folks have done. Two custom clamps/bracketsat the tailcone side securely hold the conduit exit points. The entry next tothe rear seats is pretty snug (RTV?). What's acceptable practice to secure the slack middle points to the bulkheads?Do they make adel clamps in really big sizes? Once the floors get sealed upit's going to be difficult to change anything in the middle...Thanks in advance for any input.Regards,Jay [quote][b]
owl40188(at)yahoo.com
PostPosted: Tue Apr 03, 2007 6:34 am    Post subject: fuse conduit anchor points Reply with quote
You need at least one more support for the wiring.
You bolt an adel clamp to one of the baggage compartment ribs to secure the wires or make an angle from sheet stock , drill a 3/4inch hole on one leg of the angle and put a snap bushing in it then rivet the angle to one of the ribs in the baggage compartment.
Niko
40188
LloydDR(at)wernerco.com
PostPosted: Tue Apr 03, 2007 6:46 am    Post subject: fuse conduit anchor points Reply with quote
Quick question to everyone regarding this. These and the other solutions that have been discussed are for running unprotected wires through the lighting holes. My question is why make it so complicated, we have installed conduit, which will protect the insulation on the wires, we have already edge finished the lighting holes, so why not run the conduit through the lighting holes and secure it with lock wire, IE drill a small hole below the opening, take a length of safety wire and lock the conduit in place?
Is this bad thinking, or are we just trying to make it more complex and spend allot of money on cool fasteners?
Dan
N289DT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis
Sent: Tuesday, April 03, 2007 9:20 AM
To: rv10-list(at)matronics.com; rv10-list(at)matronics.com
Subject: re: fuse conduit anchor points
Try these:
William
Jay
millstees(at)ameritech.ne
PostPosted: Tue Apr 03, 2007 8:04 am    Post subject: fuse conduit anchor points Reply with quote
Dan:
If you are going to wire tie a wire or conduit to a lightening hole, a good safeguard is to install another wite tie around the first tie (perpendicular to it), and between the wire and the aluminium. This creates an anti-chaffe buffer between.
Steve Mills N750SM (reserved)
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
[quote] --
PostPosted: Tue Apr 03, 2007 10:22 am    Post subject: fuse conduit anchor points Reply with quote
I have heard and used that method before on wiring, but when using the conduit with insulated wire inside isn't that enough? How many layers do you need?
Dan
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of millstees(at)ameritech.net
Sent: Tuesday, April 03, 2007 12:06 PM
Subject: RE: fuse conduit anchor points
Dan:
finishing fuselage
[quote] --
