				 Posted: Tue Apr 03, 2007 8:17 am    Post subject: Kolb Ultrastar W & B |
				| Does anyone know where the CG range lays on a Kolb Ultrastar?
 | What sort of rates of climb can I expect in the U-star with the
 stock Cuyuna 430 at Max gross weight?
 | Ray
 Ray:
 Got a few minutes while my Pontiac Red Aerothane is catalysing, so
 will give you my impression of the US, or a little bit of it anyhow.
 Back in the day, 1984, Homer said you could hang the US from a rafter
 at the main spar carry over tube, sit in the seat, and should be close
 to balancing.
 Most of us never went that far.  If the US is built to plans it will
 be within cg.  There was no published cg procedure for the US, during
 that early time period.  Most of us would have only gotten confused.
 Climb rate with a ULII02 is quite impressive.  It is happy to climb at
 25 mph max rate which is right on the stall.  What that max rate is, I
 do not know, but it is no slouch.
 I have no idea what max gross weight is. I weighed about 180 lbs and
 had  6 and 1 3/4 gal fuel tanks.
 It is a good little airplane, but is also early 1980 expertise.  It
 has some weak points, depending on what model of US you have, and has
 disavantages like a lot of other airplanes.  I do not have time to go
 into that now.  Maybe later.  Time to paint.
 mk III
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ John Hauck
Titus, Alabama |
				 Posted: Tue Apr 03, 2007 10:44 am    Post subject: Kolb Ultrastar W & B |
				| Did you want the climb rate before or after that Cuyuna quits
 Mike B:
 I cut my teeth on a Cuyuna ULII02 in 1984.  It was a good engine.  Did
 my first cross country flights from Gantt IAP to Woodville, FL, in
 that Ultrastar and Cuyuna.  Was one of the first UL engines to be
 equipped with CDI ignition.  Was a much better system than the next
 engine I had on the Firestar, a 447 Rotax with magneto and dual
 points.
 Have had a lot better luck with the 912 series.  Out of the engines I
 have flown, 912's, two engine outs, both my fault, both contaminated
 fuel.  The 912ULS never stopped running, ever.  Hope this new one will
 be as reliable, and I hope this pilot has learned some hard lessons to
 prevent further engine outs.  hehehe
Titus, Alabama |
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Tue Apr 03, 2007 11:17 am    Post subject: Re: Kolb Ultrastar W & B |
				Hi John,
 I would be very interested to hear more about the US and its good/bad points when you have time.
 Its encouraging to hear that the climb rate is good.
 My last Ultralight was a Lazair with about 400 fpm climb.
 I recently sold it because I wanted something that could handle a bit more wind(Headway) and stores easily.
 The Lazair cruised at 35 and the winds were typically 10-15 so it took a while to get anywhere....even when staying local.
 I figure the US will add at least 10mph to that and have a better rate of climb, plus with the short wings it will feel more sporty due to the roll rate.
 I also have a Moni which is great for going farther fast as it cruises at 90mph on 30hp and is of similar span....It's the sportscar/motor glider of the fleet.
 Ray
 Lake Elsinore, CA
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
				 Posted: Tue Apr 03, 2007 12:40 pm    Post subject: Kolb Ultrastar W & B |
  | Ray
 The Ultrastar is a good flying little airplane with a slow roll rate.
 All the Kolbs except the Fire Fly and Sling Shot are slow in roll.  If
 you want one to roll up quickly, get a Pitts.  You are in the wrong
 game.
 One improtant thing to remember flying the Kolb is not try to force
 the roll.  Gently move the stick the way you want to go, and it will
 roll.
 Weak points of the Ultrastar are:
 -Low prop.  Catches a lot of grass, weeds, rocks, or anything else it
 comes across or goes through.
 -Homer's belt redrive has a weak prop shaft bearing.  He used caged
 ball bearings.  Double tapered roller bearings would have been much
 better and given the operator a way to set bearing adjustment.
 -Has a 5 rib wing which gives good performance and reliability if kept
 withing the flight envelope Homer dicatates.
 -Wing will twist around the main spar when aileron input is too great.
 Effectively cancels out input.  No big deal though.  My old buddy that
 flew B-47's in the Air Force said that bad boy did the same thing.
 First time I heard that from him, I cracked up.
 Homer designed the Ultrastar for very slow flight.  It does that well.
 It will also fly 85 mph straight and level WOT with a ULII02 and a Jim
 Culver two blade wood prop 50" X 30".
 The fuselage is lightweight and it has rigid gear of thin 4130 tubing.
 Easily bent if you drop it in a foot or two, especially if the wings
 are not level and it hits on one gear.
 Frequent engine failures in a Kolb will make a damn good pilot at out
 you, especially executing successful forced landings.  In the early
 days, if you flew a lot, you had a lot of forced landings.  I am
 probably way behind the power curve on forced landings now days.
Titus, Alabama |
		jb92563
				 Posted: Tue Apr 03, 2007 3:29 pm    Post subject: Re: Kolb Ultrastar W & B |
				Dead stick landings are routine for me....glider pilot!!!
 I don't need aerobatic roll rates......just something that seems responsive instead of sluggish....in any case I hear the US is a lot of fun to fly....and that is the name of the game for me....FUN!
 Ray
Moni MotorGlider
Do Not Archive |
		JetPilot
				 Posted: Tue Apr 03, 2007 4:08 pm    Post subject: Re: Kolb Ultrastar W & B |
				 	  | John Hauck wrote: |
 mkIII |
 Can you tell us more about your fuel contamination with the 912's ?   I would like to avoid that if possible in my 912.
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
				 Posted: Tue Apr 03, 2007 4:23 pm    Post subject: Kolb Ultrastar W & B |
  | Ray
 Ray:
 There is tremendous difference flying an unpowered aircraft and a
 powered one that looses an engine and suddenly becomes unpowered.
Titus, Alabama |
		d-m-hague(at)comcast.net Guest
				 Posted: Tue Apr 03, 2007 4:27 pm    Post subject: Kolb Ultrastar W & B |
				At 07:29 PM 4/3/2007, jb92563 wrote:
  	  | Quote: | 	 		  I don't need aerobatic roll rates......just something that seems
 Aw gee, you mean I can't do fast 8 point rolls in my US???
 -Dana
 The citizens of the United States are getting the government they deserve.
 The problem is that I'm also getting the government they deserve.
				 Posted: Tue Apr 03, 2007 4:46 pm    Post subject: Kolb Ultrastar W & B |
				 	  | Quote: | 	 		  Aw gee, you mean I can't do fast 8 point rolls in my US???
 -Dana
     Dana, of course you can!!   You can do this manuever ONCE!!  And, oh
 yeah, you have to be completely vertical, pointed down.               Mike
 Welch
 Exercise your brain! Try Flexicon.
 http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07
		worrybear(at)verizon.net Guest
				 Posted: Tue Apr 03, 2007 4:57 pm    Post subject: Kolb Ultrastar W & B |
		jb92563
				 Posted: Wed Apr 04, 2007 7:49 am    Post subject: Re: Kolb Ultrastar W & B |
				My power off experience in powered aircraft is limited to the Lazair(twin engined).
 I had one engine die and the other still ran on final....simply shut the other one down to simplify things (yaw ) and proceeded to a normal landing.
 Learning to land a power craft unpowered is not much different than a glider.....a higher sink rate and perhaps flare timing due to extra weight are about the only issues and we are taught to handle that in any case.
 Its not uncommon for me to be in the landing pattern and go from 800fpm lift (Theres always a thermal in the pattern it seems) to 1200 fpm sink when I need to throw out all the spoilers, flaps and a slip to put it where I want it on the runway.
 Some gliders Ive flown are close to 1000 lbs empty, so a glider pilot is trained to accomodate and properly judge the decent rate and pattern for any eventuality, and we always put it down perfect since we can not go round the pattern.
 Im fully confident that I could land any sort of aircraft power off and put it right where I want on the runway.
 We are also used to putting gliders down in non airport environments, like between  small fields with tall trees, wires and fences.
 If a power pilot ever wants to polish your landing skills in dead stick conditions and learn how to put any aircraft right where you want it every time, then you should take some glider training....it will surely make you a better pilot and its fun.
 But I digress.....looking forward to my UltraStar flying.
 Ray
Moni MotorGlider
Do Not Archive |
		pj.ladd(at)btinternet.com Guest
				 Posted: Wed Apr 04, 2007 12:12 pm    Post subject: Kolb Ultrastar W & B |
				Dead stick landings are routine for me....glider pilot!!!>>
 Dont get too cocky Ray.  I tried telling that to a Shuttle pilot. Once!
 Cheers
 Pat
