p.mulwitz(at)worldnet.att Guest
Posted: Wed Apr 04, 2007 6:50 am Post subject: Remote Fuel Cut Off |
All the talk about in flight fires reminded me of a discussion I
heard many years ago. It mentioned some sort of fuel tank connection
that cut off fuel flow if the wings separate from the fuselage. The
discussion involved forced landings that nearly always result in
fires because these simple devices were not installed in Wichita.
Does anybody know of a neat way to isolate the fuel tanks? This
would be handy for emergency landings and also for in flight fire situations.
Paul
XL fuselage
Gig Giacona
Posted: Wed Apr 04, 2007 8:11 am Post subject: Re: Remote Fuel Cut Off |
I geuss you could add a couple of cut off valves where the fuel lines come into the fueselage.
| p.mulwitz(at)worldnet.att wrote: | All the talk about in flight fires reminded me of a discussion I
Paul
XL fuselage
601XL Under Construction
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Apr 04, 2007 8:49 am Post subject: Re: Remote Fuel Cut Off |
If the wings separate from the aircraft the only risk of fire comes from the fuel remaining in the lines within the fuselage In my years chasing missing airplanes for the CAP the only accidents I remember where there was a post crash fire were ones where the occupants did not survive the impact. If you can maintain control of your aircraft until control is taken away from you there is a good chance that you will survive. Shedding wings and other pieces during a forced landing in rough terrain can actually help reduce the crash forces. Shutting off fuel and electrics prior to impact can help as well.
I've attached a pix of a cherokee six that crashed recently in northern Michigan. All survived albeit with injuries. The pilot put it into the woods after the engine lost power.... he used his cell phone to direct rescuers to his location.
Fly safe!
| Cherokee six crash in N. Mich |
157.01 KB |
484 Time(s) |
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
ashontz
Tim Juhl
Posted: Wed Apr 04, 2007 11:45 am Post subject: Re: Remote Fuel Cut Off |
They clipped the treetops on the way in which slowed them down a bit. The engine separated from the fuselage although it rests only a few feet away from it. The left side of the aircraft was opened up with the jaws of life so it was more intact when it came to rest. What's really incredible is the condition of the cockpit (see attachment.) There were 4 souls on board and they waited about 3 hours for rescue.
BTW - I'm not trying to offend anyone with this discussion or photos. I was involved with search and rescue for 25 years and have been an instructor for almost as long. I try to learn from such tragedies and share the lessons in the hope that others may be spared a similar fate. Personally, I've had more close calls on the highway than in the air.
| Cherokee six crash - cockpit |
137.38 KB |
450 Time(s) |
CFII
Champ L16A flying
ashontz
Posted: Wed Apr 04, 2007 11:48 am Post subject: Re: Remote Fuel Cut Off |
Ugh! How many broken limbs, particularly legs? That sounds ugly.
Good thing it didn't burst into flames. Bad enough you're stuck in there, worse you're stuck in there on fire.
People freak out over stuff like this, but it could just as easily happen in a car, maybe not the crashing through the treetops part, but being stuck in a burning car.
| Tim Juhl wrote: | They clipped the treetops on the way in which slowed them down a bit. The engine separated from the fuselage although it rests only a few feet away from it. The left side of the aircraft was opened up with the jaws of life so it was more intact when it came to rest. What's really incredible is the condition of the cockpit (see attachment.) There were 4 souls on board and they waited about 3 hours for rescue.
BTW - I'm not trying to offend anyone with this discussion or photos. I was involved with search and rescue for 25 years and have been an instructor for almost as long. I try to learn from such tragedies and share the lessons in the hope that others may be spared a similar fate. Personally, I've had more close calls on the highway than in the air. |
MaxNr(at)aol.com Guest
Posted: Wed Apr 04, 2007 3:40 pm Post subject: Remote Fuel Cut Off |
What you're looking for is called a breakaway fuel fitting. They were beginning to be installed on military aircraft late 70's. Especially helicopters. I know UH-1 Hueys had them some where on the engine deck under the engine. If you can find a hulk you can rob, its easy to get off. Need both male and female ends. Wonder what they cost new from a supplier?
They sort of look and work like an air hose coupling. Except no collar to slide. A strain on the line will cause the male and female to uncouple and will cause a shutoff. This prevents a cloud of fuel mist during the crash sequence. This cloud contacts arcing wires or hot exhaust and boom.
Another good practice is to put a loop of extra flexible fuel line at the point where wing joins fuselage. Idea is that a lot of structure can break and move without parting a taut fuel line. I like this method.
Uncle Sam gave me some formal training in crash survival design at Arizona State Univ, Tempe. DR Harry Robinson (Robertson?)was #2 man in the dept. He had a Tempe company that did research, design & mfr. of helicopter auxiliary fuel tanks. Robertson Tanks still sells to the Gvt and industry. They may be a source or reference for breakaway fuel valves. Don't ever see them AS or WagAero.
Bob from Pace,Fl
See what's free at http://www.aol.com. [quote][b]
n801bh(at)netzero.com Guest
Posted: Wed Apr 04, 2007 3:59 pm Post subject: Remote Fuel Cut Off |
This same concept has been in use on indy style and other types of racing cars for years. It is called a "dry break". When cars hit the wall or other cars the fuel lines will disconnect and the car sheds their outer componants to absorb energy. I am sure there are several vendors that carry these things. Try Earls performance fittings, or any number of other racing wharehouses. They are not that expensive either.
Ben Haas
N801BH
www.haaspowerair.com
Bob from Pace,Fl
See what's free at http://www.aol.com. | Quote: |
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
| [quote][b]
Chris Lewis
Posted: Thu Apr 05, 2007 8:10 am Post subject: Re: Remote Fuel Cut Off |
Check this out:
http://www.spectrumct.com/products/14000/dimensions/
Chris in Seattle
_________________ 750/ Zen-vair Semi-Scratch Builder
N750XT (reserved) |
