MauleDriver(at)nc.rr.com Guest
Posted: Sat Apr 07, 2007 5:35 pm Post subject: QB Wing Fuel Tank Removal |
I'm starting work on my QB wings and trying to think through whether I
should remove the tanks to inspect, install the senders, test for leaks,
ease access for other parts, etc. Any comments?
I started removing one and immediately ran into some problems with the a
few screws not coming out easily. That alone may be a good reason to
remove, inspect, and re-install.
Thanks for comments.
dmaib@me.com
Posted: Sat Apr 07, 2007 6:23 pm Post subject: QB Wing Fuel Tank Removal |
I had problems with a few of the screws not wanting to come out, too.
Twisted the head off of one of them. The plans said to remove the
tanks, so I did. Have installed the senders, repaired a dent that I
put in one leading edge, leak checked, and they are now ready to go
back on. However, it is a little easier to finish the stall warning
system, wiring, pitot system, etc. with the tanks off. I am also
installing SafeAir1 extended range tanks, so the main tanks have to
be off for that reason.
David Maib
40559
wings
I should remove the tanks to inspect, install the senders, test for
leaks, ease access for other parts, etc. Any comments?
the a few screws not coming out easily. That alone may be a good
reason to remove, inspect, and re-install.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
dav1111(at)suddenlink.net Guest
Posted: Sun Apr 08, 2007 3:14 am Post subject: QB Wing Fuel Tank Removal |
I would strongly recommend that the QB tanks be removed and tested for leaks. I wished I had!!!
In addition, if I had it to do over again I would not have installed the stall warning as it is a waste of time and does little to help with stall warning. If you have it set right on the money and can't tell that you are way too slow you are a really bad pilot. If you have it set just a little bit high and fly a no power approach with full flaps it is going to sound off long before your wheels touch down in a full flare power off landing which can cause some passengers a little concern. Set a little low it does nothing until after you have already started recovery from a full stall.
The RV-10 stall with my IO-540 and MT prop is so predictable and recognizable in level flight that it is hard for me to understand how any reasonably competent pilot who has put the RV-10 through full flight testing would ever need the stall warning device.
In addition, unless you round off the edges of the stall warning blade you WILL catch your shirt on it and bend it which then makes it useless until the test and re-test where it needs to be bent to get it right on the money. Ask me how I know!!
Russ Daves
N710RV - First Flight 7/28/06
100+ hours and loving it
mritter509(at)msn.com Guest
Posted: Sun Apr 08, 2007 4:31 am Post subject: QB Wing Fuel Tank Removal |
I didn't remove my fuel tanks and have no problems after 90+ hours. I agree
with Russ on leaving the stall warning off. I left if off and installed an
AOA which makes every landing picture perfect. Now if you believe that I
have some ocean front property in Arizona I want to sell you.
Mark
N410MR
| Quote: | From: "Russell Daves" <dav1111(at)suddenlink.net>
Subject: Re: QB Wing Fuel Tank Removal
Date: Sun, 8 Apr 2007 06:10:01 -0500
Russ Daves
Mortgage refinance is Hot. *Terms. Get a 5.375%* fix rate. Check savings
https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h2bbb&disc=y&vers=925&s=4056&p=5117
davelammers(at)mchsi.com Guest
Posted: Sun Apr 08, 2007 7:27 am Post subject: QB Wing Fuel Tank Removal |
Hi "MauleDriver",
The plans have you remove at least the left tank for the installation of
the stall warning sensor switch. All else can be done with the tank
installed, unless of course the balloon leak test discovers a leak, then
the tank might need to be removed to locate the leak. Here is what I
would do if I were doing it again:
First, I would leak test with the tanks installed. If no leaks are
found, I would install the quantity sensors and fittings, inspect for
proper torque of the screws, and be done with the tanks, i.e.: no removal.
Secondly, the plans location of the stall warn sensor and necessity to
install an access panel is nonsense. It has been stated on this forum
before that the access panel is poorly located due to the curvature of
the wing. If you install per plans, it will oil-can. I added 3/4 x 3/4
stiffener angles and of course the longitudinal one(s) need to have the
web fluted to give the flange the proper curvature. All quite easy to
do but time consuming. However after it is all done, access to the
sensor switch (the purpose of the panel in the first place) is difficult
for all but the longest, skinniest arms with full swivel joints at the
wrists, etc. Some have opted to, or advised to, leave out the stall
horn. This is my third homebuilt aircraft and the first with any sort
of stall or AOA sensor of any kind. I thought seriously about leaving
it out. However, I plan on letting others use this aircraft. In the
event (heaven forbid) of a serious accident, I can just hear the lawyers
talking about the irresponsibility of leaving out a safety warning
device that was in the plans and recommended by the manufacturer. (It's
a real shame frivolous lawsuits have modified responsible and reasonable
behavior-but so be it).
Any way, so what would I do?
I would transfer the location of the stall warning pilot holes to near
the next to outboard rib and mount the stall warning switch on the
outboard side of that rib. This allows easy access to the switch for
maintenance through the removed wing tip. (Some will argue that the
flow is different outside the flap area-true-but that is the reason for
access-to make the fine tune adjustments).
Advantages of this entire approach:
No tank removal (if they pass leak test)
Easy access to stall warn switch.
No cutting into the wing for an access panel.
Lots of time saved for meaningful construction (or flying).
Dave Lammers
RV-6 flying
RV-10 coming along
MauleDriver wrote:
a few screws not coming out easily. That alone may be a good reason
n8vim(at)arrl.net Guest
Posted: Sun Apr 08, 2007 7:40 am Post subject: QB Wing Fuel Tank Removal |
>access panel is poorly located due to the curvature of the wing. If
I put the access panels in BOTH leading edges, since I am also using
them for access to the Safeair ER tank fuel lines, and transfer pumps.
Installing them per plans resulted in no oil canning whatsoever.
Obviously your experience is different, but I wouldn't say that they
*will* oil can, just that they might.
As always, your mileage may vary...
-Jim 40384
Dave Lammers wrote:
Hi "MauleDriver",
of the stall warning sensor switch. All else can be done with the
tank installed, unless of course the balloon leak test discovers a
leak, then the tank might need to be removed to locate the leak. Here
is what I would do if I were doing it again:
removal.
3/4 stiffener angles and of course the longitudinal one(s) need to
have the web fluted to give the flange the proper curvature. All
quite easy to do but time consuming. However after it is all done,
access to the sensor switch (the purpose of the panel in the first
place) is difficult for all but the longest, skinniest arms with full
swivel joints at the wrists, etc. Some have opted to, or advised to,
leave out the stall horn. This is my third homebuilt aircraft and the
first with any sort of stall or AOA sensor of any kind. I thought
seriously about leaving it out. However, I plan on letting others use
this aircraft. In the event (heaven forbid) of a serious accident, I
can just hear the lawyers talking about the irresponsibility of
leaving out a safety warning device that was in the plans and
recommended by the manufacturer. (It's a real shame frivolous
lawsuits have modified responsible and reasonable behavior-but so be it).
for access-to make the fine tune adjustments).
Dave Lammers
RV-6 flying
RV-10 coming along
Posted: Sun Apr 08, 2007 7:59 am Post subject: QB Wing Fuel Tank Removal |
Dave,
Do you think a fully functioning AOA instrument is a good safety warning
device and an alternative to the stall warning device supplied by Vans that
would avoid a lawsuit?
When approaching a stall in my RV-10 a nice lady inside my AOA reminds me
"angle-angle-push- push".
Mark
N410MR
| Quote: | From: Dave Lammers <davelammers(at)mchsi.com>
Date: Sun, 08 Apr 2007 10:27:55 -0500
Hi "MauleDriver",
the tank might need to be removed to locate the leak. Here is what I would
First, I would leak test with the tanks installed. If no leaks are found,
I would install the quantity sensors and fittings, inspect for proper
before that the access panel is poorly located due to the curvature of the
stiffener angles and of course the longitudinal one(s) need to have the web
fluted to give the flange the proper curvature. All quite easy to do but
time consuming. However after it is all done, access to the sensor switch
(the purpose of the panel in the first place) is difficult for all but the
longest, skinniest arms with full swivel joints at the wrists, etc. Some
have opted to, or advised to, leave out the stall horn. This is my third
homebuilt aircraft and the first with any sort of stall or AOA sensor of
any kind. I thought seriously about leaving it out. However, I plan on
letting others use this aircraft. In the event (heaven forbid) of a
serious accident, I can just hear the lawyers talking about the
irresponsibility of leaving out a safety warning device that was in the
plans and recommended by the manufacturer. (It's a real shame frivolous
I would transfer the location of the stall warning pilot holes to near the
next to outboard rib and mount the stall warning switch on the outboard
side of that rib. This allows easy access to the switch for maintenance
through the removed wing tip. (Some will argue that the flow is different
outside the flap area-true-but that is the reason for access-to make the
Dave Lammers
RV-6 flying
RV-10 coming along
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/?icid=hmtag3
dmaib@me.com
James,
I am glad to hear you say that, because I have installed the access
panels in both wings for ER tank plumbing and pump access, too.
David Maib
40559
wings
pumps. Installing them per plans resulted in no oil canning
whatsoever. Obviously your experience is different, but I wouldn't
say that they *will* oil can, just that they might.
-Jim 40384
Dave Lammers wrote:
Hi "MauleDriver",
installation of the stall warning sensor switch. All else can be
done with the tank installed, unless of course the balloon leak
test discovers a leak, then the tank might need to be removed to
locate the leak. Here is what I would do if I were doing it again:
for proper torque of the screws, and be done with the tanks, i.e.:
no removal.
to install an access panel is nonsense. It has been stated on this
forum before that the access panel is poorly located due to the
curvature of the wing. If you install per plans, it will oil-can.
I added 3/4 x 3/4 stiffener angles and of course the longitudinal
one(s) need to have the web fluted to give the flange the proper
curvature. All quite easy to do but time consuming. However after
it is all done, access to the sensor switch (the purpose of the
panel in the first place) is difficult for all but the longest,
third homebuilt aircraft and the first with any sort of stall or
AOA sensor of any kind. I thought seriously about leaving it out.
However, I plan on letting others use this aircraft. In the event
(It's a real shame frivolous lawsuits have modified responsible and
near the next to outboard rib and mount the stall warning switch on
the outboard side of that rib. This allows easy access to the
switch for maintenance through the removed wing tip. (Some will
argue that the flow is different outside the flap area-true-but
that is the reason for access-to make the fine tune adjustments).
Dave Lammers
RV-6 flying
RV-10 coming along
> whether I should remove the tanks to inspect, install the senders,
> test for leaks, ease access for other parts, etc. Any comments?
RV-10 #40559
rvbuilder(at)sausen.net Guest
Posted: Sun Apr 08, 2007 8:31 am Post subject: QB Wing Fuel Tank Removal |
I'm with Mark on this, and I also put a couple of rivets in those holes and installed an AoA. Considering all the big and military planes don't have a little tab out there and rely on AoA sensors I would classify this as an improvement over manufacturers design. Using differential pressure or a flying vane is much more accurate way to determine an impending stall and compensates for a myrid of environmental factors.
My 2 cents
Michael Sausen
-10 #352 Limbo
Posted: Sun Apr 08, 2007 8:38 am Post subject: QB Wing Fuel Tank Removal |
Mark,
Great question, but when you added the modifier "that would avoid a lawsuit" you made any answer conjecture at best.
Before the modifier was added, I would argue in the affirmative.
You would certainly need to prove that your substitute is as good or better than what the kit manufacturer recommended.
Difficult at best with any random group of pilots, let alone a group of folks who haven't a clue of what this is all about.
Dave Lammers
Mark Ritter wrote: [quote]--> RV10-List message posted by: "Mark Ritter" <mritter509(at)msn.com> (mritter509(at)msn.com)
Dave,
Do you think a fully functioning AOA instrument is a good safety warning device and an alternative to the stall warning device supplied by Vans that would avoid a lawsuit?
When approaching a stall in my RV-10 a nice lady inside my AOA reminds me "angle-angle-push- push".
Mark
N410MR
| Quote: | From: Dave Lammers <davelammers(at)mchsi.com> (davelammers(at)mchsi.com)
Reply-To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
--> RV10-List message posted by: Dave Lammers <davelammers(at)mchsi.com> (davelammers(at)mchsi.com)
Hi "MauleDriver",
The plans have you remove at least the left tank for the installation of the stall warning sensor switch. All else can be done with the tank installed, unless of course the balloon leak test discovers a leak, then the tank might need to be removed to locate the leak. Here is what I would do if I were doing it again:
First, I would leak test with the tanks installed. If no leaks are found, I would install the quantity sensors and fittings, inspect for proper torque of the screws, and be done with the tanks, i.e.: no removal.
Secondly, the plans location of the stall warn sensor and necessity to install an access panel is nonsense. It has been stated on this forum before that the access panel is poorly located due to the curvature of the wing. If you install per plans, it will oil-can. I added 3/4 x 3/4 stiffener angles and of course the longitudinal one(s) need to have the web fluted to give the flange the proper curvature. All quite easy to do but time consuming. However after it is all done, access to the sensor switch (the purpose of the panel in the first place) is difficult for all but the longest, skinniest arms with full swivel joints at the wrists, etc. Some have opted to, or advised to, leave out the stall horn. This is my third homebuilt aircraft and the first with any sort of stall or AOA sensor of any kind. I thought seriously about leaving it out. However, I plan on letting others use this aircraft. In the event (heaven forbid) of a serious accident, I can just hear the lawyers talking about the irresponsibility of leaving out a safety warning device that was in the plans and recommended by the manufacturer. (It's a real shame frivolous lawsuits have modified responsible and reasonable behavior-but so be it).
I would transfer the location of the stall warning pilot holes to near the next to outboard rib and mount the stall warning switch on the outboard side of that rib. This allows easy access to the switch for maintenance through the removed wing tip. (Some will argue that the flow is different outside the flap area-true-but that is the reason for access-to make the fine tune adjustments).
Dave Lammers
RV-6 flying
RV-10 coming along
MauleDriver wrote:
| Quote: | --> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com> (MauleDriver(at)nc.rr.com)
I'm starting work on my QB wings and trying to think through whether I should remove the tanks to inspect, install the senders, test for leaks, ease access for other parts, etc. Any comments?
I started removing one and immediately ran into some problems with the a few screws not coming out easily. That alone may be a good reason to remove, inspect, and re-install.
Need a break? Find your escape route with Live Search Maps. http://maps.live.com/?icid=hmtag3
Text inserted by Panda Platinum 2005 Internet Security:
This message has NOT been classified as spam. If it is unsolicited mail (spam), click on the following link to reclassify it: http://127.0.0.1:6083/Panda?ID=pav_45729&SPAM=true
wcurtis(at)nerv10.com Guest
Posted: Sun Apr 08, 2007 9:02 am Post subject: QB Wing Fuel Tank Removal |
Dave,
Looking at your signature, I see you are not flying yet. I don't recall any message from flying RV-10 owners that there was oil canning of this access panels. Where did you here this? I don't think they would oil can any more than the un-reinforced 0.025 wing skins to which they are attached. Just curious since I have access panels in both wings and they did not require any unusual methods to get them in good and tight in the standard location. Also access to the stall warning mechanism and the aux fuel fittings was fine from the access panel in the standard location. Your 3/4 X 3/4 stiffeners while definitely making the area stronger, may be another case of solving a problem that does not exist.
Even if I did not add the stock Van's stall warning, I would still install the access panel so you can install it at a later date, should you or the next owner change their minds.
http://wcurtis.nerv10.com/07Wings/wings45.html
William
Posted: Sun Apr 08, 2007 9:05 am Post subject: QB Wing Fuel Tank Removal |
Dave,
Even with a factory installed stall warning the trial lawyers will find
another hundred or so reasons why the builder caused the accident.
Mark
Date: Sun, 08 Apr 2007 11:39:19 -0500
Mark,
Dave Lammers
Mark Ritter wrote:
>Dave,
>Mark
>N410MR
>>Hi "MauleDriver",
>>removal.
>>Regards,
>>Dave Lammers
>>RV-6 flying
>>RV-10 coming along
>_________________________________________________________________
The average US Credit Score is 675. The cost to see yours: $0 by Experian.
http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE
Posted: Sun Apr 08, 2007 9:44 am Post subject: QB Wing Fuel Tank Removal |
Well, it looks like I'm going to remove both of them - perhaps the right
for no particular reason. However, the fact that a couple of screws
aren't coming out, I'm glad I'm finding that out now when it's
relatively easy to fix.
These are my first stripped screw heads - looks like it's time to drill
and use a screw extractor of some sort on at least one of them. I've
never done this before. Looking at an extractor in Spruce's catalog.
What are any of you using?
David Maib wrote:
installing SafeAir1 extended range tanks, so the main tanks have to be
David Maib
40559
wings
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Sun Apr 08, 2007 1:13 pm Post subject: QB Wing Fuel Tank Removal |
You might try the abrasive stuff like "Screw Grab" sold by, i.a., Avery Tools. $6.00 for half an ounce, which should last quite a while.
I'm really amazed what a difference it makes! The various covers in the fuselage had a lot of stuck, probably overtorqued, screws. I wrecked a couple and sweated a few more before starting to use Screw Grab, had no trouble afterward. Our local experts tell me that valve grinding compound is used for the same purpose, and I vaguely recall that from years ago. If I'd had some I would have tried it instead.
It may be just me, but there seems to be a big difference in quality of interchangeable driver tips. I won't buy anything but the ones Snap On sells, because they work so well for me. Their T-handle ratcheting screwdriver is also a big favorite.
Seems like most folks have a favorite stuck fastener release fluid, like WD-40, LPS-3 or whatever. The screws in my kit don't ever seem corroded, but if I start having trouble I'll use that stuff on all the screws that remain to be removed .
John Ackerman 40458 QB fuse.
On Apr 8, 2007, at 10:43 AM, MauleDriver wrote:
| Quote: | --> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
Well, it looks like I'm going to remove both of them - perhaps the right for no particular reason. However, the fact that a couple of screws aren't coming out, I'm glad I'm finding that out now when it's relatively easy to fix.
These are my first stripped screw heads - looks like it's time to drill and use a screw extractor of some sort on at least one of them. I've never done this before. Looking at an extractor in Spruce's catalog. What are any of you using?
AV8ORJWC
Posted: Sun Apr 08, 2007 2:25 pm Post subject: QB Wing Fuel Tank Removal |
Lapping compound “Clover” is used by Machine shops to set valves. We use it in the airline industry to remove overtorqued fasteners. One drop on the head. It is water soluble too.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Ackerman
Sent: Sunday, April 08, 2007 2:13 PM
[quote] [b]
Jim Berry
Posted: Sun Apr 08, 2007 6:45 pm Post subject: Re: QB Wing Fuel Tank Removal |
For removing stuck fasteners start with a drop of lapping compound and a good screwdriver, like a Klein available in the Electrical dept. at Home Depot. Cheaper and easier to find than Snap-On. If that doesn't work get a set of Alden Drillout Extractors, also from Home Depot. These were recommended in Light Plane Maintenance a while back, and they are amazing. When I follow the Alden instructions, their extractors have never failed to work.
Jim Berry
40482 Finishing
AV8ORJWC
Posted: Sun Apr 08, 2007 7:09 pm Post subject: QB Wing Fuel Tank Removal |
When negligence in the use of the dull screwdriver or too little down
force, we resort to a #30 drill bit and then apply a Snap-On 1/8"
extractor. The truck comes four times a week with a lifetime
replacement policy. We keep a second extractor in our tool box, and set
the other one for replacement.
That said, it takes about 100 screw heads to wear out the Snap-On. With
practice you can tell quickly that you are about to strip the head.
Sharp edges on the Phillips and the correct point size make a big
difference.
For many builders, these techniques will not be needed till down the
road when corrosion seals the threads or the head. Most GA hardware is
stripped by using the wrong tip size or not paying attention.
A teaspoon of lapping compound and a little water in a plastic bottle go
a LONG way.
Posted: Sun Apr 08, 2007 7:32 pm Post subject: QB Wing Fuel Tank Removal |
I THINK YOU ARE MISUNDERSTING WHAT SHE IS TELLING YOU...SHE IS SIMPLY SAYING
YOU ARE A SQUARE TYPE OF GUY. tHE PUSH , PUSH PART IS BETTER LEFT OFFLINE.
DO NOT ARCHIVE
| Quote: | From: "Mark Ritter" <mritter509(at)msn.com>
Date: Sun, 08 Apr 2007 10:58:56 -0500
Dave,
Mark
N410MR
>Hi "MauleDriver",
>Regards,
>Dave Lammers
>RV-6 flying
>RV-10 coming along
flywrights(at)yahoo.com Guest
Posted: Mon Apr 09, 2007 5:31 pm Post subject: QB Wing Fuel Tank Removal |
Dave,
You made an important distinction that shouldn't go unheeded. First, we have a kit manufacturer, and then we have an airplane manufacturer. Everyone, please feel free to manufacture your own airplane with pieces provided by the kit manufacturer, whether that airplane includes a stall warning tab or an AoA system. The kit manufacturer is saving you time and money; you get to adjust to suit your desires.
I'm no lawyer, but I do believe that the airplane manufacturer will always bear more liability than the kit manufacturer, especially if the airplane manufacturer strays from the kit manufacturer's design.
Rob Wright
#392
stuck trying to decently spray the interior
Tim Olson
Posted: Thu Apr 12, 2007 8:33 am Post subject: QB Wing Fuel Tank Removal |
Sorry so late to reply. Just got back from Vaca with
almost 500 emails to catch up on.
I can report that this access hatch will almost certainly
be an oil-canning problem for many/most builders. I had to
add stiffners in both directions around my access hole
too. Not a big deal, but just make sure when you buy a kit
section to buy a couple of 6 or 8' lengths of aluminum
angle for things like this. I'm not unhappy with the stall
switch. I personally wouldn't need the voice warning on an
AOA, as the EFIS already calls out "Stall" for you. When
the system is set up right, it can fairly accurately read
a stall warning within 2-3kts of actual stall speed. I leave
mine set slightly higher, and it is calculated based on
G-loading and such. But the buzzer is still there...not
so much a necessity, but an option.
William Curtis wrote:
<wcurtis(at)nerv10.com>
Dave,
William http://wcurtis.nerv10.com/
