Speedy11(at)aol.com Guest
Posted: Mon Feb 06, 2006 11:15 pm Post subject: 24v lamps in 14v system |
In a message dated 02/06/06 3:08:26 AM Eastern Standard Time,
aeroelectric-list-digest(at)matronics.com writes:
| Quote: | Listers,
I have a question for you.
I have a 12V electrical system with two batteries and one alternator. I
would like to power 24V position lights. What must I do to accomplish that?
Is there a 12V to 24V step up device that can be installed to power only
those lights? I don't want to change the entire system to 24V.
Stan Sutterfield
Have you considered changing the light bulbs in
the position light fixtures? They're generally
available in both 12 and 24 volt versions.
The LED position lights are not available in 12V - only 24V.
Is there a way to convert 12V to 24V so as to power the lights?
Stan Sutterfield
flmike2001(at)yahoo.com Guest
Posted: Tue Feb 07, 2006 8:40 am Post subject: 24v lamps in 14v system |
try:
http://www.aconinc.com/web05/s24v.html
they also have 28V output units in case that's what
you really need.
If just powering the LED position lights, size the
convertor according to the power consumption of the
lights. I'm assuming this is an experimental plane?
Mike
