GENTRYLL(at)aol.com Guest
Posted: Mon Apr 09, 2007 2:48 pm Post subject: Trimming Acrylic Windshield |
What is the best method to use for trimming an acrylic windshield as furnished by LP Aero.
See what's free at AOL.com.
Lynn Matteson
Posted: Mon Apr 09, 2007 3:24 pm Post subject: Trimming Acrylic Windshield |
I used my Dremel tool with a #426 fiberglass-reinforced disc for the
trimming. A saber saw would chip it as it cuts, and I recall that
they frown on this. Finish the cuts by filing and then fine grade
sandpaper, and round the edges slightly. No rough edges should remain.
Lynn
On Apr 9, 2007, at 6:46 PM, GENTRYLL(at)aol.com wrote:
| Quote: | What is the best method to use for trimming an acrylic windshield
www.matronics.com/Navigator?Kitfox-List _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Mon Apr 09, 2007 6:09 pm Post subject: Trimming Acrylic Windshield |
I'd try a rotary spin saw... they don chip at the glass and can produce a very clean edge. Use the same saw to cut composites.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Mon Apr 09, 2007 10:04 pm Post subject: Trimming Acrylic Windshield |
At 03:46 PM 4/9/2007, you wrote:
| Quote: | | What is the best method to use for trimming an acrylic windshield as furnished by LP Aero. |
I use a Dremel with their diamond disk. They're expensive but they last a long time. I cut about 1/16" off my mark. Make sure you cut against the rotation so the disk doesn't try to run across the plastic. Don't go slow because everything gets hot and heat's your enemy. (It causes thermal cracks.)
I then sand with 60 / 220 / 400. Make sure you use a board if you want straight edges. I then polish with TC6 (brown) and then PBC (blue) using the 1.5" cloth Dremel buffing disk. This leaves you with a transparent edge which is supposed to prevent cracks.
Just for information I drill small holes using plastic 0 rake angle drills and large holes using a Uni-bit. Be careful with the latter. Go slow and don't let it grab. De-burr the edges of any hole and polish the inside of the large holes using the small felt Dremel wheels and the above compuonds.
Good luck!
Guy Buchanan
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Fox5flyer Guest
Posted: Tue Apr 10, 2007 3:08 am Post subject: Trimming Acrylic Windshield |
I agree with Lynn. You might also use an angle die grinder with an abrasive
disk. It was recommended by LP and worked great for me. Makita makes a
nice 1/4" model that is only about $60 or so. With acrylics, stay away from
band saws. It's very easy to crack the material.
Deke
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Tue Apr 10, 2007 4:40 am Post subject: Re: Trimming Acrylic Windshield |
Lynn and Guy pretty well covered the cutting and dressing. I'd just add that I use lots of wide masking or blue tape, both in front of the cut, and then behind it. You don't want to put any stress on the plastic that you are about to cut, so every few inches, I'll stop and tape across the cut behind me. If it's a big piece (like a windshield) I'll tape flat pieces of wood to bridge the cut on the front and back sides.
Bob
_________________ Remember that internet advice may only be worth what you pay. |
n85ae
Posted: Tue Apr 10, 2007 10:50 am Post subject: Re: Trimming Acrylic Windshield |
I have a bi-metal blade in my big bandsaw, and I cut Lexan with it all the
time. Cuts it like butter, no chipping, and a simple attack on the edges with
a sanding block with some sandpaper knocks down the rough edges. I
cut one LP Bubble door with a dremel, the other with the bandsaw.
Heck of a lot better than smelling melted acrylic from the dremel,
and getting all that nasty grit all over yourself. The dremel, works ok
but if I had to do more than zero, I'll use the bandsaw any day. Practice
on the edge if you're scared.
Could trim a bubble door in the time it took to type this, and probably a
better job than the dremel to boot.
Jeff.
asq(at)roadrunner.com Guest
Posted: Tue Apr 10, 2007 11:17 am Post subject: Trimming Acrylic Windshield |
I agree. I have done a couple w/ the band saw and a fine blade and it worked
very well. Not the one I broke,that was on installation. LPAero will also
tell you how to grind your drill for drilling the holes.
Larry
n85ae
Posted: Tue Apr 10, 2007 12:54 pm Post subject: Re: Trimming Acrylic Windshield |
Actually when I first started building, I used to spend a lot of time
agonizing about things like this, which are really non-issues. Since I built
my Kitfox, I also built an entire set of lexan storm windows for our house
and I feel like I've cut and drilled several miles of the stuff (exaggeration)
and I have NOT once cracked or splintered any of it. I have even worked
with the stuff in the winter. It's really simple. I use a step drill for drilling
most of the time, but also I have ground some regular bits. I made a little
camper trailer, and cut windows for it with the bandsaw as well. Never
any trouble.
I've read some many posts between this and the Zenith list over the years
you would think it's like working with fine crystal, but it's really not.
Actually I think slipping with a dremel and scoring it, is MUCH more
likely that the odds of wrecking a piece with a bandsaw.
Jeff
Lynn Matteson
Posted: Tue Apr 10, 2007 1:02 pm Post subject: Trimming Acrylic Windshield |
I'd rather have that big $400 piece of acrylic resting comfortably on
my workbench, and manipulate my small Dremel tool around it than the
other way around.
To each his own.
Lynn
On Apr 10, 2007, at 2:50 PM, n85ae wrote:
all the
edges with
works ok
Practice
probably a
Jeff.
http://forums.matronics.com/viewtopic.php?p=106097#106097
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Tue Apr 10, 2007 3:54 pm Post subject: Trimming Acrylic Windshield |
One of you fellows is talking about polycarbonate and the other is talking
about acrylic. BIG difference. You can cut polycarbonate with tin snips if
you want to. It won't crack,but let a Dremel hog into a piece of acrylic(or
a drill or anything else) and you will crack it. I have cut a fair amount of
each. One of you said Lexan and acrylic in the same context Lexan is a brand
name of polycarbonate. Plexiglas is a brand name for acrylic.
Like plums and tangerines. ;o)
Not trying to start any arguments, just don't want someone to make an
expensive mistake like some have before you. Larry
Posted: Tue Apr 10, 2007 4:03 pm Post subject: Trimming Acrylic Windshield |
Now we are understanding the problem. The original "glass" that comes with a Kitfox kit is Lexan. If you have to order a replacement from LP Aero it will be acrylic. I had 4 shipped to me before I received one that UPS could not break.
jdmcbean(at)cableone.net Guest
Posted: Tue Apr 10, 2007 4:19 pm Post subject: Trimming Acrylic Windshield |
Actually that would depend on which kit… The acrylic is what is supplied now with the kit.. We are also a distributor for LP and it doesn’t cost anymore.. sometimes can even save a little…
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of GENTRYLL(at)aol.com
Sent: Tuesday, April 10, 2007 6:03 PM
Subject: Re: Re: Trimming Acrylic Windshield
<![if !supportLineBreakNewLine]> <![endif]>
See what's free at AOL.com. [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
Posted: Tue Apr 10, 2007 4:58 pm Post subject: Trimming Acrylic Windshield |
The older kits,model 4 did not use Lexan. They used Rhino. It worked very well for me. Larry
Posted: Tue Apr 10, 2007 5:12 pm Post subject: Trimming Acrylic Windshield |
My kit was a 1992 and it had Lexan written on the paper. My windshield broke from the tight radius bend at the end of the spar on top down a line at maximum curvature on both sides to the bottom. In each case it broke in the garage while I was in the back working on the header tank behind the seat. During installation, I did not stress relieve with heat as was later reccommended to me as it wasn't mentioned in the installation instructions
Float Flyr
Posted: Tue Apr 10, 2007 5:55 pm Post subject: Trimming Acrylic Windshield |
I have to ask, Isn't polycarbonate more sensitive to the effects of having gasoline dropped on it? Where gas will just drip off acrylic with little damage?
Noel [quote]
Kitfox III-A
Posted: Tue Apr 10, 2007 6:08 pm Post subject: Trimming Acrylic Windshield |
What ser # was yours? Mine is (I think) 1805. We must be pretty close together. Sounds like whatever polycarbonate was available is what was used. I stress relieved mine and it was in place about 2 yrs ago w/ 400 hrs when it became so scratched and rough that I changed it. I found some Rhino locally and used it again. Wonder if there is much difference? Larry
Posted: Tue Apr 10, 2007 6:15 pm Post subject: Trimming Acrylic Windshield |
That is correct. I have a white line down my right door window where gas leaked from the tank drain while the door was latched up. That is the next replacement. Larry
Fox5flyer Guest
Posted: Wed Apr 11, 2007 3:40 am Post subject: Trimming Acrylic Windshield |
I think whether it's Lexan or Rhino, it's still polycarbonate. My second windshield on my M2 was by Manchester, also polycarbonate.
Deke
