Fuel Tank Strainers
johngoodman
PostPosted: Wed Apr 11, 2007 7:14 pm    Post subject: Fuel Tank Strainers Reply with quote
Getting ready to leak test my QB Wing tanks and was wondering about the Fuel Tank Strainers. I assume that they should be torqued in but they should be able to come back out, right? I'm thinking either loc-tite or teflon tape, but I'm a newbie on this.
John
apilot2(at)gmail.com
PostPosted: Wed Apr 11, 2007 7:44 pm    Post subject: Fuel Tank Strainers Reply with quote
You don't want teflon tape anywhere it could leave little slivers in
your fuel or oil systems. Great for home plumbing, not for aircraft.
John
#40572 Empennage done, starting QB Wings
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=106442#106442
Rick S.
PostPosted: Wed Apr 11, 2007 8:22 pm    Post subject: Fuel Tank Strainers Reply with quote
John,
Order a tube (I bought a can, duh, enough for two lifes) of fuel lube from Aircraft Spruce or others...it is used on all the threads in the fuel system, no loctite or tape..
Rick S.
40185
Finishing
Rick S.
RV-10
40185
johngoodman
PostPosted: Thu Apr 12, 2007 5:07 am    Post subject: Re: Fuel Tank Strainers Reply with quote
Thanks for the feedback; I sort of suspected that teflon tape was a no-no. It just so happens Aircraft Spruce is 4 miles away from me, so I'll get the tube of fuel lube. Thanks again.
John
