Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Apr 12, 2007 11:06 am Post subject: Locktite on spinner bolt. |
I have flown my plane a couple times now and retorqued the prop. I want to put the spinner on now. It is a warp drive with the skull cap spinner. It is held on by one 8mm bolt. I have looked and looked for my instructions but can't find them. What type (color)of locktite should I put on the spinner bolt?
Tom Jones
neflyer48(at)cableone.net Guest
Posted: Thu Apr 12, 2007 3:54 pm Post subject: Locktite on spinner bolt. |
I have the same prop and spinner. I didn't put anything on the bolt and have
never had any problem coming loose in 860 hrs. I have taken it off a few
times to check the prop to hub bolts on annuals.
Jerry Kohles M3 912
Tom Jones
Posted: Thu Apr 12, 2007 4:25 pm Post subject: Re: Locktite on spinner bolt. |
Thanks Jerry. One difference that might be important is my prop turns left hand. I wonder if that might be more inclined to loosen the bolt?
Tom Jones
rjdaugh
Posted: Thu Apr 12, 2007 5:23 pm Post subject: Locktite on spinner bolt. |
Tom,
My spinner is fiberglass with three bolts. I use the red stuff at the
recommendation of the spinner manufacturer. I can try to get the number if
you need it.
I do think it is a good idea to use something.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Michel
Posted: Fri Apr 13, 2007 2:22 am Post subject: Locktite on spinner bolt. |
While on the subject of spinners ... I have a Jabiru engine with a Jabiru prop and a Jabiru spinner; glassfiber with six screws. It works fine but when I see it with the engine at idle, I can see it wobbling. So, I try to get it in-line with the help of a reference stick, a pencil line, marking the "offending" side, loosening the screws (the holes in the glassfiber are a little bit greater for that purpose) moving slightly the spinner, then screw again.
But I never manage to get it perfect, it always wobbles a bit, however I work on it. I remove the spinner about 4 times per year, to check the prop bolts torquing.
Do your spinner spin perfectly smooth or do you also have a slight wobble? Thanks.
While I am at it:
A big cheer for the departing list moderators and another one for the new ones!
Cheers,
Michel
jose_m_toro(at)yahoo.com Guest
Posted: Fri Apr 13, 2007 6:00 am Post subject: Locktite on spinner bolt. |
Hola Michel:
When I had the 582, my spinner also had a slight wobble. That never was a problem!
saludos!
José
Guy Buchanan
Posted: Fri Apr 13, 2007 7:26 am Post subject: Locktite on spinner bolt. |
At 03:21 AM 4/13/2007, you wrote:
| Quote: | Do your spinner spin perfectly smooth or do you also have a slight
wobble? Thanks.
I have a 10" UHS fiberglass spinner. The tip runs true, but the
trailing edge wobbles all over. I don't think the mounting flange was
tooled very well.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Michel
Posted: Fri Apr 13, 2007 12:44 pm Post subject: Locktite on spinner bolt. |
Thanks for your replies, Jose and Guy.
On Apr 13, 2007, at 5:24 PM, Guy Buchanan wrote:
| Quote: | I don't think the mounting flange was tooled very well.
Hum, thinking of it, my mounting flange is also glassfiber and maybe it
is not too well centred either. I didn't think of that. Will check.
Cheers,
Michel
GONER752(at)aol.com Guest
Posted: Fri Apr 13, 2007 12:57 pm Post subject: Locktite on spinner bolt. |
Michel,
Just a thought here. Have you tried this. Remove the spinner and place it big end down on a flat surface, then lay a pencil on the surface( you may have to block up the pencil to the location of the holes) and then simply slide the pencil on the surface as you draw a line around the spinner. That should give you an accurate "reference" line for the screws. Providing of course the spinner is symmetrical in relation to it's base,or big end.
Greg G.
375KL
Mod 2
582
See what's free at AOL.com.
Lynn Matteson
Posted: Fri Apr 13, 2007 2:04 pm Post subject: Locktite on spinner bolt. |
Michel and others-
I mounted my mounting flange in the lathe and made a fine cut on the
flange so as to minimize the runout. I couldn't take much off, as the
fiberglass is thin.
Lynn
On Apr 13, 2007, at 4:44 PM, Michel Verheughe wrote:
maybe it is not too well centred either. I didn't think of that.
Will check.
Cheers,
Michel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
rexinator(at)gmail.com Guest
Posted: Fri Apr 13, 2007 7:48 pm Post subject: Locktite on spinner bolt. |
Wait a sec! If that's a Aluminum spinner you don't want to use a lead
pencil right? Something about potential corrosion I think.
Rex
Colorado
GONER752(at)aol.com wrote:
| Quote: | Michel,
Greg G.
375KL
Mod 2
582
GONER752(at)AOL.COM Guest
Posted: Sat Apr 14, 2007 5:15 pm Post subject: Locktite on spinner bolt. |
Rex,
Most "lead" pencils today are actually graphite. I am not personally aware of aluminum corrosion being caused by drawing on it with a pencil, but then, what I know is always subject to correction or education.
Greg G.
375KL
Mod 2
582
kirkhull(at)kc.rr.com Guest
Posted: Sat Apr 14, 2007 6:12 pm Post subject: Locktite on spinner bolt. |
All I know about it is that in A&P school it was strictly forbidden to use a pencil on any aircraft aluminum but that was about 15 years ago. Also when doing inspections at the airline we would look to be sure that no one was using a pencil.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of GONER752(at)aol.com
Sent: Saturday, April 14, 2007 8:15 PM
Subject: Re: Locktite on spinner bolt.
Rex,
Greg G.
375KL
Mod 2
582
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234
rjdaugh
Posted: Sat Apr 14, 2007 7:46 pm Post subject: Locktite on spinner bolt. |
Hey, there must be a metallurgist out there. I always thought it was that the graphite scratched the oxide surface off of the aluminum and left a spot for corrosion. But why would that be worse than scratching the oxide off with a scotch brite pad? Cause water or salt can displace the graphite? I really don’t know.
Or is it just an old wives tale?
Randy – looking for enlightenment.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of kirk hull
Sent: Saturday, April 14, 2007 8:12 PM
Subject: RE: Locktite on spinner bolt.
Rex,
Greg G.
375KL
Mod 2
582
[/b]http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.com[/b]01234567890
Kitfox 5/7 912S
Float Flyr
Posted: Sun Apr 15, 2007 4:35 am Post subject: Locktite on spinner bolt. |
You are right not to mark on aluminium with a pencil... you are also right that pencil lead is not lead but graphite, a form of carbon. Generally if I'm going to mark a piece of aluminium I'll use a pilot marker. I make sure it doesn't have carbon in the pigment. Using a scribe can work.
BTW Never sand aluminium with standard sand paper that will also cause the plate to corrode. Use only aluminium oxide paper. I won't go near the different colours of scotch brite (that one has been flogged to death many times) but obviously checking which ones use an aluminium oxide are preferred.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Sun Apr 15, 2007 5:02 am Post subject: Re: Locktite on spinner bolt. |
I personally know of two airliners which depressurized at altitude when big flaps of fuselage skin opened. (Airliners flex the skin between frames and stringers every time the cabin pressurizes.) Markings on the aluminum skins of each to lay-out repair areas had been done with pencil in one and with a scribe on the other. I also saw a float that had been sitting behind a hangar for years and somebody had written on it. The letters had corroded into the skin. Pencils and scribes should not be used on aluminum.
Michel, to center the spinner you might simply pull your spark plugs, put masking tape on the end of the spinner, and put a marker on the end of a stick so it touches the spinner. Spin the prop by hand and the marker will make a circle on the tape. You can shift the spinner in the mounting bolts until the circle is centered then toss the tape. A work-mate was flying a Piper Seneca that threw a spinner about two years ago and you can't believe the damage it did when it hit the fuselage. Even the rubber engine shock mounts had to be replaced from the side loads in ripping off. Make sure it is secure when done!
Bob
_________________ Remember that internet advice may only be worth what you pay. |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Apr 15, 2007 6:15 am Post subject: Locktite on spinner bolt. |
Also in the instruction manual I received from SS in 1993 we were advised to
use a sharpie as pencil lead could be a corrosion initiator - this was in
laying out the wing rib position on the wing jig. Maybe those that had the
quick build wing option missed out on this bit of information.
Lowell
Float Flyr
Posted: Sun Apr 15, 2007 6:26 am Post subject: Locktite on spinner bolt. |
I just thought of another no-no that is using any form of diamond grit, including some grinding pastes. Diamond is a crystalline form of carbon.
Noel [quote]
Kitfox III-A
Mdkitfox(at)aol.com Guest
Posted: Sun Apr 15, 2007 12:57 pm Post subject: Locktite on spinner bolt. |
In a message dated 4/14/2007 11:48:20 P.M. Eastern Daylight Time,
rjdaugh(at)rapidnet.com writes:
really don’t know.
Randy,
It's not a wives tale. I was only an aero engineer at Kennedy Space Center,
not a metallurgist, but I saw a mechanic draw a line with a pencil on a
piece of aluminum used on the Saturn V. I brought this to his attention and he
laughed and gave me a rough time since I was just out of school and the new
kid on the block.
Long story short, for a $5 bet, we put 2 identical pieces of aluminum in 2
pull testers. One was scribed with a pencil line the other wasn't. During
the pull, the piece scribed with the pencil cracked right along the drawn line
and the other piece did not break. Could it have been luck? I don't think
so, I had performed that same test in college and it did the same thing more
than once.
The carbon in the lead or graphite sets up stress corrosion in the aluminum
and when you place the part under stress it doesn't take long for the crack
to occur. It will even follow gentle curves. The humidity in the air and
especially in a salty environment like the beach will cause this corrosion to
accelerate quickly. Just leave a piece of painted chrome molly steel outside
for a day and see how quickly corrosion attacks it.
Rick
Series V Speedster - N39RW, Serial Number 1
DO NOT ARCHIVE
************************************** See what's free at http://www.aol.com
Posted: Sun Apr 15, 2007 1:26 pm Post subject: Locktite on spinner bolt. |
Hey Rick,
I live near the Space Coast now. Worried about
corrosion all the time.
You probably know about drawing on a jet engine
exhaust with pencil. Very shortly you can get a
crack, or even cut out a circle or design you drew. I
would think piston engine exhaust would do the same if
it was hot enough.
The carbon jet engine exhaust does not do it, only the
pencil mark.
Hide the pencils!
Kurt S.
| Quote: | Randy,
with a pencil on a
kid on the block.
than once.
Rick
DO NOT ARCHIVE
