HF Pnuematic Riveter
naumuk(at)alltel.net
PostPosted: Sun Apr 15, 2007 1:49 pm    Post subject: HF Pnuematic Riveter Reply with quote
All-
My HF riveter doesn't want to grab the rivet shank anymore.
Any quick fix, or do I get another one?
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
gfmjr_20(at)HOTMAIL.COM
PostPosted: Sun Apr 15, 2007 2:08 pm    Post subject: HF Pnuematic Riveter Reply with quote
" My HF riveter doesn't want to grab the rivet shank anymore."
Bill-
If you have not oiled it, it will bind up. Usually a couple drops of oil in
the air hole will loosen things up. If this doesn't do it, you will need to
disassemble it and oil it. You should not have to replace it.
George May
601XL 912s--65 hours
Mortgage rates near historic lows. Refinance $200,000 loan for as low as
$771/month*
https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117
gboothe5(at)comcast.net
PostPosted: Sun Apr 15, 2007 3:16 pm    Post subject: HF Pnuematic Riveter Reply with quote
Same thing happened to mine…took it apart, cleaned and oiled it…life’s good (or, as they say in the UK, Bob’s your uncle).
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Sunday, April 15, 2007 2:50 PM
Subject: HF Pnuematic Riveter
All-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Ron Lendon
PostPosted: Mon Apr 16, 2007 10:45 am    Post subject: Re: HF Pnuematic Riveter Reply with quote
I used a couple drops of air tool oil right down the nosepiece and it started grabbing the shanks again. I think the teeth built up with metal particles and the oil helped loosen them.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
