Lynn Matteson
Posted: Sat Apr 21, 2007 3:10 am Post subject: My "Florida" trip...off topic |
Off topic, other than telling how GREAT a plane the Kitfox is in
saving one's bacon during less-than-perfect flying conditions.
This is a description of my recent attempt to fly to the Sun 'n'
Fun Fly-in, held in Lakeland, Florida. A friend, Nihl, was flying in
his own plane, a very nice 1963 Cessna 150. I was flying my own
Kitfox Model IV Speedster with a Jabiru 2200 engine for power.
We left the Napoleon, MI airport (3NP), at 7:30 am local time, last
Monday, and flew the 230 statute miles to Sporty's Pilot Shop at
Batavia, OH, in 96 minutes. Along the way I was showing 108mph
Indicated airspeed, while my GPS was showing 177mph ground speed...we
had a 70 mph tailwind! Nearing Dayton, Ohio's airspace, Nihl called
to notify ATC that we wished to transit their airspace, saying we
were a flight of two. The controller could not locate a flight of
two, and we discovered that Nihl's transponder did not transmit. I
was asked to squawk 0346, which I did and the controller told us that
my transponder worked, but his did not. Still not being real
comfortable with use of the radio, I was letting Nihl handle the
radio chores, while I became the designated transponder operator. ( I
was handling my own "self-announce" at the untowered airports)
Landing at Sporty's was a bit tricky, as the wind was almost a direct
crosswind, but both planes landed ok. We spent about an hour at
Sporty's, Nihl buying charts and fuel...I did not need fuel.
During our stopover at Sporty's, the wind increased, and became
more of a direct crosswind, and I was nervous about taking off using
the regular runway. I asked for permission to use what I found out
was called "high-speed turnoffs" for part of my takeoff "runway".
This was granted, so I taxied onto the normal taxiway, turned around,
and started out, using about 50 feet of the normal taxiway, turning
left onto the high-speed turnoff which is at 45 degrees to the
taxiway and the main runway, and crossing the main runway, I lifted
off with an approximately 45 degree crosswind. This worked out quite
well for me. Nihl, with his heavier plane, used the runway with no
problems.
My flight instructor had told me before I left that since I was
used to following section lines as part of my Michigan-based VFR
navigation procedures, that I would not find a recognizable section
line in Kentucky, and he was right. Suddenly there were no more
straight lines to follow, just curves, and hills and wandering rivers.
I had my chart and my GPS, so navigation was no problem. Nihl called
and told me we were clear to fly at 5500 feet elevation, which
became too bumpy, so I asked him to ask for permission to go to 7500,
which was granted. Minutes later, he called to say "Lynn, go to 5500
feet IMMEDIATELY!" I did, and it turned out traffic
was the reason for the command. A few minutes later the traffic was
gone...whatever it was...and we were cleared to go back up to 7500.
It was getting very bumpy, and I could see puffy clouds coming up,
and avoided then, but could feel the bumps as they passed by. Seeing
a bank of clouds that I wanted to avoid, I climbed even higher...we
were no longer under the jurisdiction of the ATC by this time. I was
getting closer to the ridge of clouds, and was at 9500 feet, close to
my Sport Pilot-mandated ceiling of 10,000 feet, and could see that I
was not going to make it over the clouds even if I bent the rules
"for safety", so I decided to head down. All this last 10 minutes or
so, the turbulence was getting greater, and as I descended, I was
getting hammered, and Nihl came on the radio and said he was going to
land, pointing out an airport below. I had the airport in sight, and
was thinking the same thing. I was well into the yellow band of my
airspeed indicator, and had to flatten out the descent to keep the
speed down into the green, even though this meant spending more time
getting bounced around. At one point I noticed that my GPS had lost
power, due to the cigar lighter power supply becoming loose due to
the vibration, bouncing, bumping, and slamming around that the plane
was getting. I had to circle the field to try and find the windsock,
and saw that it was straight out and at a 90 degree angle to the left
side of the runway, and I saw no other choices for landing. I came in
with left wing down as much as I could try to hold it there, and the
plane was really getting tossed. The left wheel made contact, bounced
a bit, and the left wing came up, slamming the right wheel down with
the plane starting to point to the left. I got lucky as hell that the
plane didn't groundloop, or cartwheel or anything else. I got stopped
pointing into the wind at the left side of the runway, completed the
rest of the turn to the left and back taxied off at the first turnoff
and pulled the plane up to a closed hangar for shelter from the wind.
I got out to assess the damage, and found that the right wheel pant
was slightly damaged due to the tire being flexed sideways (during
that hard hit) and grabbing the fairing and causing the fairing to be
pulled into and bent upwards, inside the pant, and dragging on the
tire. I unscrewed the fairing and left it off and tied the plane down
with help from a guy at the airport. During this time, Nihl was
trying to get down, and on his third attempt was successful.
We later discovered that we had landed at Scott County Airport (SCX),
near Oneida, Tennessee. More later on what a great facility, and
great people they have down there.
In retrospect, I'm surprised that the tire didn't roll off the rim. I
have tubeless tires with no tubes, and even though there are good
deep bead retention grooves in the wheels, I'm tempted to put tubes
in them if for nothing other than making it easier....if I can find
tubes with bent stems....to check tire pressure.
Next: Staying at the airport, making decisions, and getting back.
DO NOT ARCHIVE
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Sat Apr 21, 2007 6:53 am Post subject: My "Florida" trip...off topic |
Thanks for the PIREP, Lynn. I love reading that stuff and you're good
at writing too. It feels like being there. Keep your reports coming in.
On Apr 21, 2007, at 1:12 PM, Lynn Matteson wrote:
| Quote: | Minutes later, he called to say "Lynn, go to 5500 feet IMMEDIATELY!"
Here I get a bit puzzled. When you fly formation, don't you both listen
to the same ATC frequency? Over here, we fly together, one leading,
talking and squawking and the other one remaining silent of the ATC
frequency. Then one or the other may request to change for a few
minutes to a Unicom frequency to chat a bit, then back to the ATC. The
main point here is that ATC knows at any time on which frequency you
are. This is especially a must when you fly with a flight plan.
| Quote: | had to flatten out the descent to keep the speed down into the green,
even though this meant spending more time getting bounced around.
Do you side-slip to increase your ROD without gaining speed?
Cheers,
Michel
dcsfoto
Posted: Sat Apr 21, 2007 9:46 am Post subject: Re: My |
enjoyed the report great job
Lynn Matteson
Posted: Sat Apr 21, 2007 11:26 am Post subject: My "Florida" trip...off topic |
I'm very new to the formation flying bit, and still don't have my
"radio endorsement", so I was letting the other flier handle the
radio chores. I would have preferred to just go around the areas that
required radio contact...at least until I have confidence in my radio
manners and expertise. We were flying without flight plan.
There was no way in hades that I was going to slip at that altitude,
or under those turbulent conditions. At least, I don't THINK that it
would be safe. Maybe someone could enlighten me. I'm going to run the
whole scenario past my flight instructor, but he's out of town.
Thinking back on it, the other flier was good on the radio, but a bit
off when it came to navigation. His GPS was not the moving map
variety, and because I was following him, and trying to coax him back
onto our heading, we got off-track by a bunch. No excuses, but I'd
rather have been the one heading up the mission, because I had the
more up-to-date GPS, and would have steered us around the busy
airspaces, and away from radio talk. Using the charts was problematic
at best in Kentucky, because of the wide separation between towns,
landmarks, whatever, and also the lack of good N-S and E-W section
lines. I was relying on my GPS to guide me, and even though I had my
chart marked, I hadn't written down a list of landmarks to guide me
visually. I made a big mistake in not doing that. When the turbulence
became a factor, it didn't matter where we were, because the chart
was the last thing on my mind, because I saw the airport below. If my
GPS would have crapped out before it did, and I had no idea where I
was, then reverting back to the chart would have been the only
option, or steering over to I-75 (a divided Interstate highway),
which was also in view.
Before I go on another trip, I'll learn more about weather, and what
conditions cause what, and be better prepared to observe what I'm
getting into, and make a decision earlier as to when to go down, or
stay down 'til another day, or 'til conditions improve.
Lynn
On Apr 21, 2007, at 10:53 AM, Michel Verheughe wrote:
good at writing too. It feels like being there. Keep your reports
coming in.
listen to the same ATC frequency? Over here, we fly together, one
leading, talking and squawking and the other one remaining silent
of the ATC frequency. Then one or the other may request to change
for a few minutes to a Unicom frequency to chat a bit, then back to
the ATC. The main point here is that ATC knows at any time on which
frequency you are. This is especially a must when you fly with a
flight plan.
> green, even though this meant spending more time getting bounced
> around.
Cheers,
Michel
N369LM |
Michel
Posted: Sat Apr 21, 2007 1:21 pm Post subject: My "Florida" trip...off topic |
On Apr 21, 2007, at 9:25 PM, Lynn Matteson wrote:
| Quote: | I'm very new to the formation flying bit, and still don't have my
"radio endorsement", so I was letting the other flier handle the radio
chores.
If I understand correctly, Lynn, you were listening to a unicom
frequency while your friend was on the ATC frequency. I think it is
better that you both are on the same frequency. Then you would both had
received the instruction to descend in order to avoid another traffic.
Of course, while on the ATC frequency you can't talk to the other plane
but you can e.g. ask ATC to change frequency to unicom. At that moment,
your friend will also know that he must change frequency because you
wish to talk to him. In any case, and for a reason of safety, anyone
can break international radio rules if it is to prevent a fatal
accident. This is valid for maritime, aviation and ham radio.
As seen from ATC point of view, it is also important that the
controller knows at any moment on which frequency you are. If you are a
flight of two, or more, he or she would expect to have you both on the
same frequency. Since you were warned of a meeting traffic, it meant
that you were under radar coverage and even if you were in a G zone,
the controller will prefer to give you traffic information rather than
seeing a mid-air crash and a lot of paper work for him/her to do.
At least, that's my experience in Europe.
| Quote: | There was no way in hades that I was going to slip at that altitude,
I understand. Maybe I would also hesitate to do it. Was it very bad?
Thermal or mechanic turbulence? Were you in a mountainous region? But I
think side slipping is an important technique which I practice very
often. Today, to warm up my engine for the oil change at the 200 hours
of my Jabiru, I went for a few traffic pattern where each one was very
high on final and I side slipped both ways to come fast to land on the
mark. Last time was with the engine off. The reason is: If I loose
power one day, and see a nice patch of grass to land on, I may be too
low to do a 360 and fast sink rate will be my only alternative not to
overshoot the field. Beside that, side slipping makes me feel I have
control over the plane.
Cheers,
Michel
Lynn Matteson
Posted: Sat Apr 21, 2007 5:22 pm Post subject: My "Florida" trip...off topic |
You understand correctly, Michel...me on unicom, he on ATC freq.
Later, on the return trip, I did tune into ATC frequency, so I could
hear first-hand the directions. At one point I had lost sight of the
other plane, but I was on ATC freq., when I heard my friend call for
clearance for transit through their airspace. It was granted. He was
well ahead of me judging from his report of being 3 miles out. I was
5 miles out. We were flying against a 20 mph headwind, and it seemed
like forever for me to get to the airport. When I did get there, I
made a call, stating that my friend called for clearance, but had
neglected to say a flight of two. I told him where I was, altitude,
etc., and he cleared me too. Even though there was no traffic (the
controller said so), I felt better about making the call....got me
over the mike fright, too. Since that call, I've either monitored the
ATC freq., or made my own calls. The day following our return, we
flew into Jackson, MI (JXN) airport, class D, and I made my own call.
That was my first solo landing at a towered airport, and, explaining
my "greenness" on the radio the controller said I was "doing fine".
Maybe now my instructor will sign my radio endorsement...we'll see.
As to the turbulence, I'm not sure whether it was thermal or
mechanical...how do you tell? We were on the edge of a tapering off
mountain range, as the range gained altitude toward the east, and we
were heading south, skirting the range to the west. The airport
elevation was 1545 feet, and the nearby ridges are at about 3400-3500
feet, within 20 miles. There is a windmill farm on those
ridges...studying the chart now tells me something that I should have
read back then. Telling other pilots about where we were, elicits the
response of "you should've gone further west." And had we been
flying the chart that I marked, we would have been 20 miles further
west. Hard to say if 20 miles would have been more comfortable, but
looking at the contours, the terrain would have been much flatter,
and this seems to me now to have been a better route...hindsight and
all that.
Was the turbulence bad? Did I mention that my friend's right seat
came out of it's moorings? I don't think I did. He said the seat came
over and hit him, and that stuff on the seat was flying about the
cockpit. He later said he probably didn't have the belt tightened
enough. I didn't look at his plane and how the seat was held in, but
I will.
I practice slips a lot, because I have some fields that have trees on
both ends with 1700-2600 feet runway between...mine is 1700 with
trees at the normal approach end. I need to practice slips with
slowing the plane with up elevator. I'm usually at full (20°) flaps
when I slip. I'm better slipping with left wing down, and need to do
more right slips, because I don't like to do them.
Lynn
On Apr 21, 2007, at 5:20 PM, Michel Verheughe wrote:
> radio chores.
had received the instruction to descend in order to avoid another
traffic. Of course, while on the ATC frequency you can't talk to
the other plane but you can e.g. ask ATC to change frequency to
unicom. At that moment, your friend will also know that he must
change frequency because you wish to talk to him. In any case, and
for a reason of safety, anyone can break international radio rules
if it is to prevent a fatal accident. This is valid for maritime,
are a flight of two, or more, he or she would expect to have you
both on the same frequency. Since you were warned of a meeting
traffic, it meant that you were under radar coverage and even if
you were in a G zone, the controller will prefer to give you
traffic information rather than seeing a mid-air crash and a lot of
> altitude, or under those turbulent conditions.
bad? Thermal or mechanic turbulence? Were you in a mountainous
region? But I think side slipping is an important technique which I
practice very often. Today, to warm up my engine for the oil change
at the 200 hours of my Jabiru, I went for a few traffic pattern
where each one was very high on final and I side slipped both ways
to come fast to land on the mark. Last time was with the engine
off. The reason is: If I loose power one day, and see a nice patch
of grass to land on, I may be too low to do a 360 and fast sink
rate will be my only alternative not to overshoot the field. Beside
that, side slipping makes me feel I have control over the plane.
Cheers,
Michel
N369LM |
Guy Buchanan
Posted: Sat Apr 21, 2007 9:44 pm Post subject: My "Florida" trip...off topic |
At 12:25 PM 4/21/2007, you wrote:
| Quote: | I would have preferred to just go around the areas that
Best thing I ever did for radio work was buy and use the COMM-1 PC
software for VFR flight. I still use it to brush up before a big
cross-country. I also do preparatory cross countries before big cross
countries. In the preparatory I do everything I would do on the long
one, but do it all in one hour.
A slip would not be unsafe if you were flying at less than
maneuvering speed, Va, which I assume you were doing, given the conditions.
| Quote: | Using the charts was problematic
lines.
I had a good friend teach me pilotage in the wilds of Wyoming. It is
amazing what you can identify on a chart and how you can
cross-correlate that information to find your location. If you ever
get a chance to do a mountain check-out, make sure the instructor
helps you with this. You can often quite easily identify mountain
geometry, stream and dry beds, lakes, and man-made objects sufficient
to identify your location. When I flew to Ft. Worth from San Diego I
used pilotage exclusively until I got to west Texas, where it became
so flat I started to rely more on the GPS. Even then I kept a close
track on where I was on the chart and made it a game to identify
landmarks and locate them and myself.
| Quote: | Before I go on another trip, I'll learn more about weather, and what
I can't remember, did you get a full weather briefing from Flight
Service before departure? If so, did they mention a turbulence AIRMET?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Sun Apr 22, 2007 3:15 am Post subject: My "Florida" trip...off topic |
What does the COMM-1 PC software cover? I'm using a Mac, and most
software is geared to PC's/IBM's, unless you're talking a DVD. I've
got the Sporty's Recreational Course on DVD, which has a LOT of
weather training included. This trip to Florida was going to be my
brush up before I attempt to fly to California in late May. I guess I
learned what I don't know...or didn't apply.
I guess I was just too rattled to think of using a slip at 9,000
feet. I was concerned about getting it down, and I had never used a
slip except for during landings at approx. 60 mph. I did make sure I
got it under Va just to be sure the control surfaces weren't going to
rip off. When the bouncing began I was right at 108mph, and slowed
from there to a controlled descent...well, as controlled as much as I
could.
I too find the following of chart features a game, and enjoy doing
it. I guess I was more concerned with keeping the other plane in
sight, and thus relied more on the GPS for direction. In hindsight,
it would have better to not have a traveling partner, then I would
have been left to my own resources, would have marked the chart with
more checkpoints, made that call to FSS, and probably would have been
told about a turbulent AIRMET...nope, no briefing...probably relying
on the more experienced other pilot who hasn't owned his own plane in
over 9 years, and hasn't done all that much flying lately. When I
mentioned calling FSS and filing a flight plan, he reminded me we
were just flying VFR...big mistake to accept that as an answer. When
I look back on it, I've flown more hours in the past 10 months than
he probably has in the past 4-5 years. I should have known better,
and now I do, I hope.
Lynn
On Apr 22, 2007, at 1:34 AM, Guy Buchanan wrote:
cross countries. In the preparatory I do everything I would do on
the long one, but do it all in one hour.
conditions.
> lines.
is amazing what you can identify on a chart and how you can cross-
correlate that information to find your location. If you ever get a
chance to do a mountain check-out, make sure the instructor helps
sufficient to identify your location. When I flew to Ft. Worth from
San Diego I used pilotage exclusively until I got to west Texas,
where it became so flat I started to rely more on the GPS. Even
then I kept a close track on where I was on the chart and made it a
game to identify landmarks and locate them and myself.
Guy Buchanan
San Diego, CA
N369LM |
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Sun Apr 22, 2007 4:42 am Post subject: Re: My |
Lynn - Sounds like you had a a great adventure, even if you didn't get to Lakeland!
Slips work, but I learned in a jump plane that if you want to come down fast, crank it over into a steep bank, relax the back pressure, and watch the airspeed. The descents can get scary fast IF you want them to, because not as much of the wing is lifting upward. Again, be careful of how fast the airspeed builds and keep it in the green arc.
No reason to skirt using the radio or airports with traffic. The worst are SunNFun and Oshkosh which have lots of traffic and while I know that you'd memorized the 30+ pages of procedures, you ought to be able to use the radio. An ATC person will be saying stuff like "Pink Avid go to XXX" and you need to realize he's talking to you, not an Avid, while two other airplanes pass so close you can see the faces of the occupants. Even there isn't hard, it's just the difference between walking alone toward a goal versus in a crowd of strangers. You'll be loads more relaxed if you do pattern work with other planes this summer. Also, I don't think I've ever had a problem with a FSS on the radio, at least after getting them (contact can be tough sometimes.)
Bob
_________________ Remember that internet advice may only be worth what you pay. |
Guy Buchanan
Posted: Sun Apr 22, 2007 7:42 am Post subject: My "Florida" trip...off topic |
At 04:18 AM 4/22/2007, you wrote:
| Quote: | What does the COMM-1 PC software cover? I'm using a Mac
Comm1 is software that helps you learn radio protocol. It
uses scenarios to teach you the content and form of a radio exchange
on the ground and in the air. For each scenario it first teaches you
what the radio exchange should look like, it then puts you through a
small multiple choice test to ascertain your knowledge of content,
and asks you to make the aircraft replies using a PC headset. You
then assess your form by listening to yourself, and comparing with
how the "expert" sounds. I have found the scenarios to accurately
simulate real radio situations and have therefore benefited greatly by it.
Happy news! I checked the website,
http://www.comm1.com/home.html, and found that Comm1 operates on Mac
or PC! I purchased "Comm1 VFR" since that's all I do. I can't speak
for their other products.
By the way I'm glad everything turned out well for you and
that it has turned into a learning and not debilitating experience.
As a fairly recent pilot I well remember how scary the first
excursions out of the nest can be. I'm still learning, and still
regularly test my heart rate.
Take care,
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Lynn Matteson
Posted: Sun Apr 22, 2007 10:08 am Post subject: My "Florida" trip...off topic |
Thanks, Guy...wow, somebody actually made software for the
Mac..unbelievable. I'll check it out.
By the way, I flew past Battle Creek, MI airport today (BTL), and the
ATIS guy was reading so fast I could hardly make out when he left one
subject and turned to another. I got curious and timed his delivery...
11.9 seconds. His "wind" description was: one-niner-zero-zero-niner-
zero....no "at" in the description. I had to listen about ten times
to get the information. I tuned in the tower frequency and there was
no traffic to speak of. Why do they think they have to rattle off
those numbers so damn fast that it takes multiple listenings to get
all the numbers? Are they making an audition tape for a job at
O'Hare? There was a guy at Jackson, MI (JXN) that was that way and
they got so many complaints that he's no longer there....probably
went to BTL!
Lynn
On Apr 22, 2007, at 11:36 AM, Guy Buchanan wrote:
exchange on the ground and in the air. For each scenario it first
teaches you what the radio exchange should look like, it then puts
you through a small multiple choice test to ascertain your
knowledge of content, and asks you to make the aircraft replies
using a PC headset. You then assess your form by listening to
yourself, and comparing with how the "expert" sounds. I have found
the scenarios to accurately simulate real radio situations and have
Happy news! I checked the website, http://www.comm1.com/
home.html, and found that Comm1 operates on Mac or PC! I purchased
"Comm1 VFR" since that's all I do. I can't speak for their other
products.
Take care,
Guy Buchanan
San Diego, CA
N369LM |
Michel
Posted: Sun Apr 22, 2007 11:59 am Post subject: My "Florida" trip...off topic |
On Apr 22, 2007, at 3:25 AM, Lynn Matteson wrote:
| Quote: | Later, on the return trip, I did tune into ATC frequency, so I could
I think it was a wise decision, Lynn. With only 250 hours as a pilot, I
have little advice to give anyone. But I have nearly a life time with
the maritime GOC radio license and have been for years a keen radio
amateur, using all kind of communications. The "fear of the microphone"
(and the keyer when you start Morse) is quite common. You pretty
quickly overcome it.
My advice to anyone is: Talk to ATC and fly with a flight plan for
three reasons: safety, safety and safety. If you want, put "student" in
the Remarks field of your flight plan. If you don't understand, say:
"say again" as many times as needed. Radio communication courtesy says
that no one should send faster than what is understood from the other
side.
In Norway, English is the ATC language. Some pilots don't feel too
comfortable with the English vocabulary. If not understanding, pilots
are advised to talk Norwegian, or anything else that could make sure
instructions are understood for the three above-mentioned reasons.
As a pilot, you only have to remember two things: Read-back and your
callsign. Incidentally, I have heard a SAS training tape (actually a
cockpit voice recording) from an approach to O'Hare. Scary! But then,
we seldom dwell in those airspaces with our Kitfoxes.
.. Here is a good one from Rod Machado's book:
A pilot visits for the first time an airfield:
Tower: - "Do you have information Hotel?"
Pilot: - "Nah, I intend to stay with some friends!"
Cheers,
Michel
Lynn Matteson
Posted: Sun Apr 22, 2007 1:19 pm Post subject: My "Florida" trip...off topic |
Thanks for the encouragement, Bob. I'm starting to go to busier
'ports, as of Friday. Went to a Class D on that day, and to a fairly
busy "restaurant" airport today. Sat with a guy who used to live in
New Mexico and he gave me some good advice about flying the western
USA...get started early, stop early, and maybe go again later on in
the day, if there's a stopping point maybe an hour away from there.
He spoke of some of the winds encountered out there...so much that
the tie down are made of cable because of the high winds and of
course the rotting effect of the sun...boy oh boy, can hardly wait! : )
This airport that I went to was Plainwell, MI (61D) and has a 9-27
paved, and a 1-19 turf. That's the way all airports should be in my
estimation...make it a 9-27 if that's the main wind direction, then
throw in another runway made of turf, so as to have a choice, but a
less-expensive means of building it...just a thought...or what the
heck make 'em ALL turf!
I agree about getting ahold of the FSS people...sometimes a lengthly
wait, and part of the reason that on our recent flight we opted out
of the info that we really needed.
Lynn
On Apr 22, 2007, at 8:42 AM, Bob wrote:
get to Lakeland!
Bob
http://forums.matronics.com/viewtopic.php?p=108438#108438
N369LM |
wingnut
Posted: Sun Apr 22, 2007 3:47 pm Post subject: Radio practice |
Lynn, I'm in the same boat when it comes to talking to ATC. I feel like my brain goes out to lunch every time I press the PTT button. One thing that has helped me tremendously is listening to actual ATC traffic on www.liveatc.net. It helped me so much that I downloaded several clips and made a CD that I can listen to on the way to work. One thing I noticed right away is that most commercial pilots do the readback a little different from the text book. Instead of starting with their tail number, they do the readback then end it with the tail number. It seems like a more natural response to me.
Luis Rodriguez
824KF
Lynn Matteson
Posted: Sun Apr 22, 2007 5:55 pm Post subject: My "Florida" trip...off topic |
Hi Luis-
Haven't heard from you for awhile...thanks for responding.
The readback first and tail number last seems better to me too. Good
idea on the taped/CD'd clips. Maybe I'll tape myself making calls
until they become second nature.
Lynn
do not archve
On Apr 22, 2007, at 7:47 PM, wingnut wrote:
response to me.
Luis Rodriguez
824KF
http://forums.matronics.com/viewtopic.php?p=108521#108521
N369LM |
wingnut
Posted: Sun Apr 22, 2007 7:19 pm Post subject: Re: My |
You understand that I wasn't taping myself? Check out the web site I posted (www.liveatc.com). You can listen to live ATC from dozens of airports around the world being streamed over the Internet. You can even download archived broadcasts. It's some of those archived broadcasts that I burned to a CD. Nothing like hearing the pros do it.
| Quote: | Haven't heard from you for awhile...thanks for responding.
until they become second nature. |
davef(at)cfisher.com Guest
Posted: Mon Apr 23, 2007 2:50 am Post subject: My "Florida" trip...off topic |
Lynn, Good write up about your trip.
Did you know what was past that bank of clouds ?
Wx brief #1 -- then in flight you have to talk to flight sevice to get WX
ahead .
Mic Fright ? Well you should not be planning long X countries without being
fully trained and comfortable with radio.
Another thing is Slips from 9k or what ever altitude. Well if you are flying
over top and have to find a hole to come down through you should be able to
make rapid decents in tight areas to be abel to do this.
Just my thoughts, Good report and good learning experience for everyone.
Dave
xfire
Posted: Mon Apr 23, 2007 3:53 am Post subject: Re: My |
I made the mistake early on in my flight training to stay away from controled airspace. I was flying in and out of a controled airport, but as soon as I hit 500' I was rolling out to the west and heading out to spot bears and moose and go fishing. I avoided heading North into Anchorage or Merril field at all costs as I did not want to screw up on the radio and sound like an idiot. I had a great understanding of the procedures and all, but was just to bashfull about using them. I figured out after about 10 years that it was not so bad after all and now wish I had all the gas I burned up avoiding airspace instead of going straight through it. I also found that I was not alone in trying to avoid the airspace so the narrow coridor between ANC airspace and the mountains was full of idiots like me.. It is a wonder that there are not anymore midairs due to that.
I am not up on sport pilot regs, but didnt you have to demonstrate radio proficiency as well as the airmanship on the check ride?
Lynn Matteson
Posted: Mon Apr 23, 2007 4:48 am Post subject: My "Florida" trip...off topic |
Yes, I copy that you were not taping yourself...I just took the
process a step further, thinking that if I heard myself talking, I
might see how I sound compared to the** liveatc** stuff and grade my
own ability. Thanks, Luis.
And I just added this note: I ran into my flight instructor at
coffee just now, told him of my solo flight into JXN Class D airport,
using the radio, and he said "We'll have to get you signed
off...bring your log book over." Sounds like I'll be legal soon, even
if it takes a little question and answer session.
Lynn
On Apr 22, 2007, at 11:19 PM, wingnut wrote:
http://forums.matronics.com/viewtopic.php?p=108555#108555
N369LM |
Lynn Matteson
Posted: Mon Apr 23, 2007 5:02 am Post subject: My "Florida" trip...off topic |
Re "demonstrate radio proficiency as well as the airmanship on the
check ride?"...no, I told the examiner that at the point of taking
the checkride, my intercom was low on volume, and this caused the
radio (which goes through the i'com) to be low on volume, and being a
little hard of hearing, I didn't want to be examined on radio use. He
understood...especially when my flight instructor, who is good
friends with the examiner, told him that I was an old fart and
couldn't hear worth a s__t, and he would sign the radio endorsement
after I got the radio volume increased and we did the required radio
work at towered fields. Reading between the lines this meant Brian
(flight instructor) would yell at me, slap me around a bit, call me a
dumb s--t and sign me off.
The radio endorsement is an add-on to the Sport Pilot ticket, or can
be done at the same checkride if desired.
Lynn
On Apr 23, 2007, at 7:53 AM, xfire wrote:
<leonard.perry(at)acsalaska.net>
I made thye mistake early on in my flight training to stay away
due to that.
http://forums.matronics.com/viewtopic.php?p=108594#108594
N369LM |
