chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Sun Apr 22, 2007 3:35 am Post subject: XL main Spring gear placement |
OK Gang
Which way does the XL Main spring gear go?? Is it flat side to the raer or to the FWD side?
My photoguide shows flat side to the rear but the plans on page 6-3-G shows it with the arrow frwd. Now I have seen other pictures of it in both ways on other sites. But which is correct. I rang the factory but everyone was away at S&F.
Does it make much difference? Is it better for Cof G to have it one way or the other?
Just an AUSSIE thought.. is FRWD short for Forward or Flat RearWarDs??
I will have the Jab 3300 hanging on the nose.
Chris..
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Apr 22, 2007 3:47 am Post subject: Re: XL main Spring gear placement |
Chris,
I'm not sure what version of the plans you have, but my plans show the flat side aft, and the angle side forward. Same page 6G3. My plans date 12/03. I don't have tail dragger plans, but I believe they put they put the flat side forward.
Dan
_________________ Scratch building XL with Corvair Engine |
davgray(at)sbcglobal.net Guest
Posted: Sun Apr 22, 2007 4:08 am Post subject: XL main Spring gear placement |
Chris
The argument was :
If you reverse the original placement it would move the wheels about 2"
forward making it easier to hold the nose wheel off after a landing during
the roll out and make it easier to lift the front wheel during takeoff.
The Con is that you have to be more carefull during entry so you don't
rock backward onto the tail when somebody uses the boarding steps.
My gear is in the original more rearward position and it is not difficult
however the nosewheel does carry about 100 pounds more weight than either of
the main gear. It is definitely not the strongest part of the gear system.
In a normal landing I am not able to hold the nosewheel off the ground after
the mains touch down.
If I did it again, I would opt for gear placement that is more forward and
consider leaving the step off because I find it easier to mount the wing
from the front anyway. I just sit on the main spar and slide rearward a
little to enter the cabin. Less weight , less drag, less time to construct.
FWIW
Gary Ray
p.mulwitz(at)worldnet.att Guest
Posted: Sun Apr 22, 2007 4:31 am Post subject: XL main Spring gear placement |
Hi Chris,
My plans also show the flat side forward. I believe this is the
correct choice. However, I doubt the difference is huge.
I have heard there are some times when the nose tends to hit the
runway rather firmly on landings. Moving the main gear a little
forward by positioning the main gear spring with the flat side
forward may reduce this tendency a little bit. The only risk I can
see with this approach is the possibility that a really aft CG might
make the plane want to sit on its tail instead of the nose
wheel. This seems rather unlikely to be a condition where flight is possible.
I plan to install my gear with the flat side forward (soon, I hope).
Best regards,
Paul
XL Fuselage (nearly done)
At 03:35 AM 4/22/2007, you wrote:
<chris_sinfield(at)yahoo.com.au>
OK Gang
way or the other?
Chris..
chris Sinfield
Posted: Sun Apr 22, 2007 4:48 am Post subject: Re: XL main Spring gear placement |
Thanks for the replys already
I have the latest set of plans March 06 and its the normal version not Tail wheel.
With a Jab 3300 engine I believe the Cof G is a little aft anyway is this correct? so it would be worse if the flat was FWD
Chris
bryanmmartin
Posted: Sun Apr 22, 2007 4:55 am Post subject: XL main Spring gear placement |
I believe the original plans called for the flat side to the rear.
With a heavier engine, this puts the main wheels far enough behind
the normal CG that it's a little bit hard to lift the nosewheel for
takeoff or hold it off during landing. With my Subaru, for example, I
have to apply a lot of back pressure to rotate and as soon as the
mains leave the ground, the plane wants to pitch up so I have to be
prepared to release the back pressure right away. On landing, the
reverse applies, the nose wants to drop rapidly as soon as the mains
touch down. It's not a big problem but it's something to get used to.
I think the newer plans call for the flat side forward and I've seen
that the LSAs being built at AMD have the gear this way. The photo
guide probably reflects the older plans. I've done some calculations
and I figure that putting the flat side forward would move the mains
about four inches forward. With my airplane that would still put the
mains far enough back that I could climb in and out without tilting
the plane back on its tail, even with the plane loaded for gross
weight and maximum aft CG. Two people might not be able to climb in
at the same time though. It really wouldn't be a big deal to turn it
around the other way, just pull off the mains, flip the spring
around, re-mount the mains and then re-attach the brake lines the the
spring. I've though about turning my main spring around but just
haven't gotten around to it yet. If I were building it today knowing
what I do now, I would build it with the flat side forward.
OK Gang
rear or to the FWD side?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
rstone4(at)hot.rr.com Guest
Posted: Sun Apr 22, 2007 8:19 am Post subject: XL main Spring gear placement |
Members,
I am running a Jabiru 3300 engine in my Zodiac601XL and it does the
same thing, that is requires more that usual back pressure to rotate and
when it does the nose pitches up sharply and requires immediate forward
pressure to prevent stall. I was told this was an easy airplane to fly but
this is not true. Every spam can I ever flew prior to flying the ZodiacXL
was much easer than this one.
Tracy Stone
Posted: Sun Apr 22, 2007 8:36 am Post subject: XL main Spring gear placement |
| Quote: | I am running a Jabiru 3300 engine in my Zodiac601XL and it does the same
thing
Which way does your gear face, Tracy?
-- Craig
Posted: Sun Apr 22, 2007 9:24 am Post subject: XL main Spring gear placement |
So if a person is building from scratch, would there be any sense in making the spring symmetrical? That way the effects would be half as severe for either condition. I do know that I do not want the plane to be difficult to unstick - or for it to zoom climb the instant of breaking ground...
Bryan Martin <bryanmmartin(at)comcast.net> wrote: | Quote: | --> Zenith-List message posted by: Bryan Martin
Dave Downey
Harleysville (SE) PA
Zodiac 601XL/Corvair?
Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
tonyplane(at)bellsouth.ne Guest
Posted: Sun Apr 22, 2007 10:26 am Post subject: XL main Spring gear placement |
I agree. One of the things I wish I had know about was the gear reversal, before I installed my gear.
I have this caution in my POH. Found this out in flight test when I set it up for a high speed (about 65 kt) landing with full flaps and rotated nose high but did not stop sink rate. Not a problem landing slow with full flaps or low or"high" speed with no flaps with sink rate arrested, but more forgiving at high speed with no flaps.
CAUTION<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
WATCH SINK RATE AND AIR SPEED: with the landing gear geometry of 493TG, a High sink rate combined with High air speed at touch down will result in the nose gear hitting the runway HARD… and bouncing the airplane airborne in a nose high attitude. IF THIS HAPPENS – GO AROUND or initiate a BOUNCE RECOVERY! Pilot Induced Oscillation (PIO) can result under this condition if landing is attempted.
Tony Graziano
601XL/Jab3300; N493TG 234 hrs.
Subject: Re: XL main Spring gear placement From: Bryan Martin (bryanmmartin(at)comcast.net ([email]bryanmmartin(at)comcast.net?subject=Re:%20XL%20main%20Spring%20gear%20placement&replyto=7C6CF49B-80E6-4C1A-A2D7-0F9DDCDDEDE6(at)comcast.net[/email])) Date: [b]Sun Apr 22 - 5:55 AM[/b] | Quote: | | Quote: | I believe the original plans called for the flat side to the rear.
| Quote: | <chris_sinfield(at)yahoo.com.au ([email]chris_sinfield(at)yahoo.com.au?subject=Re:%20XL%20main%20Spring%20gear%20placement&replyto=7C6CF49B-80E6-4C1A-A2D7-0F9DDCDDEDE6(at)comcast.net[/email])>
OK Gang
Bryan Martin
N61BM, CH 601 XL,
taffy0687(at)yahoo.com Guest
Posted: Sun Apr 22, 2007 10:51 am Post subject: XL main Spring gear placement |
my thoughts only--- I am building from plans -- I thought the same as Dave, splitting the difference. But, I decided to go "straight (flat) part of bar forward. MY reasoning, all else being ok--- keep as much weight as possible off from the nose gear assembly (and stay within the design). Why? nose gear strut has direct linkage to rudder pedals- crosswind landings.
Fritz
David Downey <planecrazydld(at)yahoo.com> wrote:
[quote]So if a person is building from scratch, would there be any sense in making the spring symmetrical? That way the effects would be half as severe for either condition. I do know that I do not want the plane to be difficult to unstick - or for it to zoom climb the instant of breaking ground...
Dave Downey
Zodiac Ahhh...imagining that irresistible "new car" smell?
afterfxllc(at)aol.com Guest
Posted: Sun Apr 22, 2007 11:23 am Post subject: XL main Spring gear placement |
At our hanger we have 3 601's 1 has a Rotax and 1 has a O-235 125HP conversion and 1 has the corvair and all have the flat of the mains aft. and they all fly fine. The plans show the flat aft also.
bryanmmartin
Posted: Sun Apr 22, 2007 3:16 pm Post subject: XL main Spring gear placement |
I think the plane was originally designed for the Rotax, which is a
fairly light engine. With any other engine, I don't think there will
be any problem with just building the gear to plans and mounting it
flat side forward. In any case, with the flat side aft, it isn't a
serious problem, just different. I got used to it fairly quickly.
On Apr 22, 2007, at 1:23 PM, David Downey wrote:
| Quote: | So if a person is building from scratch, would there be any sense
Bryan Martin <bryanmmartin(at)comcast.net> wrote: --> Zenith-List
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
