Inside of cabin top.
indigoonlatigo(at)msn.com
PostPosted: Mon Apr 23, 2007 7:50 pm    Post subject: Inside of cabin top. Reply with quote
Now that my cabin top fit is as good as it is going to get, this coming
weekend will be spent working on the patching up the flaws and doing some
interior refinement.
I have seen the overhead consols which are used for ventilation and
lighting, but has anyone installed anything else up there. It seems that
there is a natural channel directly behind where the windscreen joins to the
top where a 1/4 flexible conduit could be run. I will be putting a few LED
dome lights up on the ceiling, but aside from the above mentioned, did
anyone else put in any switches or flap controls or anything else that one
could imagine (Apollo space craft look)
Jesse, Is there any picture that you could direct me to so that I could see
the proposed Overhead visor extension arm and where you are planning to
mount it. I may have missed an e-mail which showed some info.
It will be posible for me to make my own overheads out of hotwired foam and
glass and then pour acetone on the foam to melt it out before rejoining it
to the top, but I need someting to put in the compartments other than
sunglasses to make it worth the time.
Any suggestions. My creative mind wants to know.
JOhn G.
Rick S.
PostPosted: Tue Apr 24, 2007 7:10 am    Post subject: Inside of cabin top. Reply with quote
I have the Accuracy Avionics overhead also. I am in the process of molding a new part that will be bonded to the access panel to allow my O2 system outlets to be mounted there...I am using the 4 IP Mountain High system which does not require needle valves to set altitude pressure, of course the outrageous price I paid for Rosen visors can't compare to what I spent on the O2 system,door latches,leather interior, suede looking paint, new engine and of course the avionics....If I could only figure out a way to make these things out of waffle board and aluminum tubing I could have saved a bunch of money on these overpriced, overweight luxury items Wink
Rick S.
40185
Budget? We don't need no stinking budget!!
Rick S.
RV-10
40185
ddddsp1(at)juno.com
PostPosted: Tue Apr 24, 2007 2:03 pm    Post subject: Inside of cabin top. Reply with quote
Misquoted and misunderstood...................Smile
Dean [quote][b]
zackrv8
PostPosted: Tue Apr 24, 2007 6:16 pm    Post subject: Re: Inside of cabin top. Reply with quote
John,
Here are some ideas from Sun-N-Fun. I took more pics that can be found on Deem's website under SNF 2007.
Zack
 Filesize:  43.8 KB
 Viewed:  563 Time(s)
 Filesize:  69.47 KB
 Viewed:  555 Time(s)
 Filesize:  32.17 KB
 Viewed:  575 Time(s)
 Filesize:  50.47 KB
 Viewed:  525 Time(s)
 Filesize:  34.03 KB
 Viewed:  573 Time(s)
 Filesize:  46.63 KB
 Viewed:  547 Time(s)
RV8 #80125
RV10 # 40512
PostPosted: Tue Apr 24, 2007 8:41 pm    Post subject: Inside of cabin top. Reply with quote
Thanks Zack,
That is a real variety of cool stuff. Gives me some things to think about.
Appreciate it!
JOhn G.
Subject: Re: Inside of cabin top.
Date: Tue, 24 Apr 2007 19:16:26 -0700
John,
Zack
RV8 #80125
RV10 # 40512
http://forums.matronics.com/viewtopic.php?p=109086#109086
http://forums.matronics.com//files/dsc07478_128.jpg
http://forums.matronics.com//files/dsc07464_134.jpg
http://forums.matronics.com//files/dsc07428_2_105.jpg
http://forums.matronics.com//files/dsc07395_2_142.jpg
http://forums.matronics.com//files/dsc07380_720.jpg
http://forums.matronics.com//files/dsc07359_2_590.jpg
