Roger Lee
Posted: Sat Apr 21, 2007 4:59 pm Post subject: Re: 912 Throttle Cable Failure |
400' per minute drop is nothing. d When doing auto-rotations in my helicopter it would drop 1400'-1600' per minute. It's all in what you get used to. That's why you need to try it so your ready if or when the day comes so you don't miss your landing spot. With a little practice you can get within 20' of a predetermined touchdown spot and when it's an emergency that may be exactly what you need. You won't under or over shoot your spot with a little practice.
You will have confidence that you can calmly handle any engine out.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Mon Apr 23, 2007 2:29 pm Post subject: 912 Throttle Cable Failure |
Subject: Re: 912 Throttle Cable Failure
Dennis/Gang:
Spend a buck and get a new cable. Why take a chance on another
failure.
Your home soldered cable is not the first failure I have heard about.
_________________ John Hauck
Titus, Alabama |
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Tue Apr 24, 2007 6:44 pm Post subject: Re: 912 Throttle Cable Failure |
| Quote: | Spend a buck and get a new cable. Why take a chance on another
failure.
mkIII |
I agree with John. You can get cables with professionally soldered ends in custom lengths from California Power Systems at a reasonable price.
It's also important to make sure the throttle end is properly done too - those disconnects between pilot and engine can ruin your whole day.
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
Posted: Tue Apr 24, 2007 6:52 pm Post subject: 912 Throttle Cable Failure |
| Dave Bigelow
Dave:
Over all my years flying Kolbs, I have always used throttle and
enricher cables supplied by Kolb. Give Travis a call. He'll fix you
up with the best. I have never had a throttle cable failure. One
less problem to worry about.
Titus, Alabama |
Dennis.Kirby(at)kirtland. Guest
Posted: Mon Apr 30, 2007 8:44 am Post subject: 912 Throttle Cable Failure |
John H. suggests: << Spend a buck and get a new cable. Why take a
chance on another failure. Your home soldered cable is not the first
failure I have heard about. john h >>
Thanks for the tip, John - I did exactly that.
I bought a replacement cable from the local bicycle shop ($5) with a
factory-pressed cable end. I had to file it down a bit so it would fit
in the little slot in the splitter slider. Have already test flown with
the new cable - all seems OK.
If I ever need to do this again, I will do it as Richard Pike suggests:
Fray the cable end that sticks out from the ferrule, then solder in a
big glop of solder into the frayed strands. THAT should keep it from
pulling out again!
Dennis Kirby
