xfire
Posted: Tue Apr 24, 2007 8:32 am Post subject: Check your Gear legs |
Well yesterday started off great. I went out to the airport with my brother and changed out the radiator and put a shroud on it so he can control the airflow and regulate the temp. We did a runup and burped the system then off we went. after shooting a few off airport landings we headed over to a friends airstrip. The initial touchdown was not super smooth, but nothing to note either. My brother hollers into the headset that the left gear just folded and to hang on its gonna be a rough one.. He hit the mags and held in full right aileron to hold the left side off as long as possible. I see the windshield fill full of dirt then we settle back down right side up.
Shut off gas, made sure ELT was not activated then climb out ( I love the 4 point harness..much better than the single shoulder strap in my pacer when it went in). we pick up on the strut, pull the left gear back under it and tie it off with a short piece of rope then push it off the strip. Turns out, the gear leg had been broken about 1/2 was through for some time as the crack was nice and rusty and the metal was nice and rounded where it had been rubbing and pounding together. This is right where the bungies wrap around the gear leg. I will get a pic of it later on and post it up so you can see the break. I would pull your bungies and get the legs checked out before you get the oprotunity to elevate your heart rate and practice your fiberglassing skills.
The damage to the plane was cracked both fiberglass wingtips, got 2 blades off the IVO and cracked up the lower cowling. The new radiator and shroud took a good beating but can be repaired and the fuse gets a bit of fabric work to get rid of the new bomb bay hatch the gear leg and wheel installed in it.
More later....
776.24 KB |
771 Time(s) |
766.13 KB |
723 Time(s) |
606.83 KB |
770 Time(s) |
kitfoxmike
Posted: Tue Apr 24, 2007 9:35 am Post subject: Re: Check your Gear legs |
Now that this has happened concider the grove gear, a little heavier, but it sure handles the rough landings. I've landed where the plane flat out stalled 10ft off the runway and had a solid landing on the mains, no bounce, with no damage what so ever to the landing gear, cool stuff. Glad you made out like you did on the landing. I've had my landing gear break on the tube gear simular to yours, not fun.
Lynn Matteson
Posted: Tue Apr 24, 2007 1:37 pm Post subject: Check your Gear legs |
Did I mention that I have the Grove gear, and I consider this is the
one part (besides being in a Kitfox) that saved my bacon during my
recent harsh landing? And thanks to this group, and mainly Rex from
the Big Pond, I was informed about the Grove gear, bought one and
haven't been sorry. My flight instructor also says that as much abuse
as I put this through during my early hours is a testimony to the
Grove gear.
Lynn
On Apr 24, 2007, at 1:35 PM, kitfoxmike wrote:
<customtrans(at)qwest.net>
to yours, not fun.
kitfoxmike
model IV, 1200
speedster
912ul
http://forums.matronics.com/viewtopic.php?p=108957#108957
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Tue Apr 24, 2007 1:50 pm Post subject: Re: Check your Gear legs |
Bummer, glad that you guys didn't go over and are OK.
Due to the propstrike, call one of the Rotax shops for the latest tolerance on propshaft runout, as the tolerance is quite tight and important. Something like a half-thou, by memory. They also will have guidance on propstrike inspection for you.
_________________ Remember that internet advice may only be worth what you pay. |
xfire
Posted: Tue Apr 24, 2007 4:58 pm Post subject: Re: Check your Gear legs |
engine was shut down when the prop hit and it has a clutch, so there is no direct drive. He will check the runout on the crank just to make sure though.
kitfoxfugit(at)yahoo.com Guest
Posted: Thu Apr 26, 2007 10:10 pm Post subject: Check your Gear legs |
Subject: Re: Re: Check your Gear legs
[Grove Gear]
I have to second the favorable comments on the Grove
gear. I went to it after putting up with a squirrly
bungee gear far too long. Finally, a bungee broke.
With the Grove gear, it taxies straight, isn't wobbly
or springy, just lands straight, even in a crosswind.
Whether you flare too low, run into the ground and
bounce back up or flare too high, all you have to do
is hold the stick back and let it drop in. The gear
absorbs it, but is not stiff, either.
The Grove gear is cheaper than the repairs occasioned
by the bungee gear, I figured. I weighed the bungee
gear, with brakes, tires, and wheels, but without
bungees or wheel pants, and could not see much
difference from the Grove gear. I didn't see any
difference in speed either, but left the wheel pants
off. Mine has real airplane wheels and tires on it,
too, and dual caliper brakes that will handle tundra
tires when I am ready to go there. Now, what about
some little fenders to keep the mud off the wings and
tail?
John Allen
Kitfox IV Speedster, 912 UL, in CA
[Grove Gear]
tail?
John Allen
xfire
Posted: Thu Apr 26, 2007 10:37 pm Post subject: Re: Check your Gear legs |
Thanks for the grove gear tips... the intent of the post was to make guys aware that there could be a crack in the the gear UNDER THE BUNGIES that you CANT SEE. This post is for those who have the bungie gear in hopes it may save someone a bit of repair time, frustration and possibly harm.
Guy Buchanan
Posted: Fri Apr 27, 2007 7:12 am Post subject: Check your Gear legs |
At 11:37 PM 4/26/2007, you wrote:
| Quote: | This post is for those who have the bungie gear in hopes it may save
Hi Leonard. Thanks for the information on the tube gear. I
use it and like it just fine and will be careful to inspect it under
the bungies.
Would you please put your full name, approximate location,
aircraft and engine type, and build / flying status in your
signature? Mike and I are trying to make the place a little more
friendly and the information helps people get to know each other a
little better.
Guy Buchanan, Kitfox List Moderator
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Guy Buchanan
Posted: Fri Apr 27, 2007 7:39 am Post subject: Check your Gear legs |
Apologies to Leonard. The following post was supposed to be sent directly.
Guy
the bungies.
little better.
San Diego, CA
DO NOT ARCHIVE
Deceased K-IV 1200
Michel
Posted: Sun Apr 29, 2007 8:52 am Post subject: Check your Gear legs |
On Apr 27, 2007, at 8:37 AM, xfire wrote:
| Quote: | the intent of the post was to make guys aware that there could be a
Do you have any photo to share with us? In advance, thank you very much.
Michel Verheughe
Norway
Kitfox 3 - Jabiru
xfire
Posted: Sun Apr 29, 2007 10:37 pm Post subject: Re: Check your Gear legs |
the third pic in the original post is the stub of the gear leg that broke off.. You may have to read it onthe forum for it to show.
Michel
Posted: Mon Apr 30, 2007 12:46 am Post subject: Check your Gear legs |
| Quote: | From: xfire [leonard.perry(at)acsalaska.net]
Thank you, I have now seen your photos on the forum. Scary stuff! I don't understand how it can break at that point but it did, you are the proof of it. Thanks for sharing.
Michel Verheughe
Norway
Kitfox 3 - Jabiru
xfire
Posted: Mon Apr 30, 2007 6:46 am Post subject: Re: Check your Gear legs |
The break was right at the toe of the weld. When I first started welding 4130 I was replacing the tail post and lower longerons on a PA12. The tail cluster was a major PITA but when I got done it looked very nice. I did a dye check and all was well.. 3-4 days later the tail cluster was cracked all up. After talking to the local gurus it was determined that by using the TIG process, the heat affected zone was very small and the 4130 didnot like it. I now preheat to 500 deg. max interpass temp of 700 and when the welding is complete wrap with insulation till it is cooled to room temp. I have never had another welding related issue since doing this.
