jareds(at)verizon.net Guest
Posted: Mon Apr 30, 2007 9:16 am Post subject: Puking Oil Reservoir |
I've been chasing a ghostly 582 oil leak for quite some time now and i think i've finally narrowed it down to the tiny oil reservoir on the 582. It holds only a few ounces and never made sense why they didnt feed from the big tank but none the less it has a tiny hole in the cap to allow air i presume and it seems as though it is puking oil out of that tiny hole.
I'm guessing that this should not be happening and am wondering if anyone else has ever experienced this?
Jared
dosmythe(at)cox.net Guest
Posted: Mon Apr 30, 2007 9:27 am Post subject: Puking Oil Reservoir |
Jared,
You could simply use the large tank to feed both but, the small tanks is
there to allow you to measure any usage of oil and also to see if any water
starts to appear. Either would indicate a rotary valve seal leaking
problem. Does the little tanks always indicate the exact same level?
Probably not since it's blowing out. Is there any water in the oil?
Don Smythe
Classic IV w/582
Newport News, Va.
Posted: Mon Apr 30, 2007 2:01 pm Post subject: Puking Oil Reservoir |
Hi Don,
The amount decreases (1/4 container per hour) and doesnt appear to have water in. Will look a little closer. I am guessing that these feeder lines are for the rotary valve shaft?
I"ve attached a length of clear tube to the top of the cover over the little hole to see if it still shoots it out the top or to get a better idea of whats going on.
Quote: | From: Don Smythe <dosmythe(at)cox.net>
Date: 2007/04/30 Mon PM 12:27:23 CDT
Subject: Re: Puking Oil Reservoir
Jared,
Don Smythe
Classic IV w/582
Newport News, Va.
Posted: Mon Apr 30, 2007 2:26 pm Post subject: Puking Oil Reservoir |
Jared,
I've never had a failure but, sounds like your rotary valve is shot?
Mine uses no oil and will actually increase in level about 1/8" when hot
then back down when cool.
Don Smythe
Classic IV w/582
Newport News, Va.
Float Flyr
Posted: Mon Apr 30, 2007 5:48 pm Post subject: Puking Oil Reservoir |
Just a little note Jared...
Coolant in the RV oil won't look like little bubbles of clear stuff like water in gas. With the agitation of the RV the oil will appear milky when there is water in it. If you are having problems with oil upchucking out of the RV reservoir bottle than I agree with the idea that you have a RV seal problem.
Bummer!
[img]cid:963214701(at)01052007-2262[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
419 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Mon Apr 30, 2007 6:22 pm Post subject: Puking Oil Reservoir |
New engine rebuild with about 60 hrs on it but over the winter it sat during all our snow and cold.
Date: 2007/04/30 Mon PM 05:25:50 CDT
Subject: Re: Re: Puking Oil Reservoir
Jared,
Don Smythe
Classic IV w/582
Newport News, Va.
Guy Buchanan
Posted: Mon Apr 30, 2007 7:53 pm Post subject: Puking Oil Reservoir |
At 03:01 PM 4/30/2007, you wrote:
Quote: | The amount decreases (1/4 container per hour) and doesnt appear to
Since you're showing leakage outside the engine I don't think you
have a rotary valve problem. (Maybe I should say that if the leakage
is on the tank side you don't have a rotary valve problem. If it's on
the water pump side, maybe your inner rotary valve seal is leaking.)
I had one of these tanks fail in the seam between the two tubes. It
was an incredibly small crack that leaked slowly. It was caused by a
thin seam during the tank's fabrication. I cleaned the tank and could
see a thin spot at the seam. I used a soldering iron to heat the area
very slowly until it was transparent and thereby weld the seam back
together. It worked fine after that.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Posted: Tue May 01, 2007 1:47 am Post subject: Puking Oil Reservoir |
I was under the impression Gared was puking oil out the vent hole in the top
of the cap. This would indicated an internal pressure coming from
somewhere. On the other hand, a cracked tank could also cause the oil to go
away. I did have one crack that leaked but it was apparent without the
engine running.
Don Smythe
Classic IV w/582
Newport News, Va.
wheetfly(at)yahoo.com Guest
Posted: Tue May 01, 2007 3:45 am Post subject: Puking Oil Reservoir |
Hi Jared
When I had my KF III 582 I had the same problem
It was like the system was making oil. well the seals
in the rotary valve Pump shaft were gone thus a little
water was mixing with the shaft oil and pushing it out
the top
I feel U better check and replace the shaft seals and
bearings and posibly the shaft too
Bill Wheet
Based in Maine
--- jareds(at)verizon.net wrote:
<jareds(at)verizon.net>
Hi Don,
whats going on.
>To: kitfox-list(at)matronics.com
>Jared,
valve seal leaking
exact same level?
water in the oil?
>Don Smythe
>Classic IV w/582
>Newport News, Va.
>Do Not Archive
msm_9949(at)yahoo.com Guest
Posted: Tue May 01, 2007 5:31 am Post subject: Puking Oil Reservoir |
I got the impression from the original post that oil was burping up through the vent hole in the reservoir bottle cap. That happened to me too. I cut a rubber gasket for inside of the reservoir cap and punched multiple off-center vent holes in the rubber. Problem solved.
Guy Buchanan <bnn(at)nethere.com> wrote:
[quote]--> Kitfox-List message posted by: Guy Buchanan
is on the tank side you don't have a rotary Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
