alfolavf(at)online.no Guest
Posted: Thu Feb 09, 2006 8:14 am Post subject: Flap attachment? |
Hi fellow builders!
We've just started working on QB-wings now, and I saw in the manual that there were two metods of mounting the flap hinge.
One was drilling a hole in the inboard aileron bracket, the other one was cutting the hinge in half.
Is there a metod that is preferred over the other by you people out there?
By the way; thank you for all the inputs regarding my question about heated pitot tube!
I've gotten alot of ideas and thougts!
Bets regards Alf Olav Frog
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
dan(at)rvproject.com Guest
Posted: Thu Feb 09, 2006 8:38 am Post subject: Flap attachment? |
Go with the split pin, installed from the center. You'll thank me later.
)_( Dan
RV-7 N714D (812 hours)
http://www.rvproject.com
frank.hinde(at)hp.com Guest
Posted: Thu Feb 09, 2006 8:41 am Post subject: Flap attachment? |
I drilled the hole but decided I didn't like it so went with the center
eyelet removed method...It will be a lot easier to remove a flep if you
ever had to this way.
Frank
RV7a, final engine connections...then paint!
