Posted: Thu May 03, 2007 2:08 am Post subject: Overhead Seat Belt Holder Attach |
I've seen lot of -10's (including Van's) with a seat belt strap holder mounted overhead on the canopy between the front seats. How are people attaching it? I drilled mine between the doors near the front door hinges and there is foam between the layers of fiberglass. I could either pull rivet it (but then it is not easily removable for the headliner, etc.) or drill through the whole top and use flat head screws.
Just wondering what others were doing
-Mike K
Tim Olson
Posted: Thu May 03, 2007 3:16 am Post subject: Overhead Seat Belt Holder Attach |
Removing the rear hinge nuts and installing under those nuts, so it's
not requiring any additional holes.
Mike Kraus wrote:
| Quote: | I've seen lot of -10's (including Van's) with a seat belt strap holder
-Mike K
mritter509(at)msn.com Guest
Posted: Thu May 03, 2007 3:25 am Post subject: Overhead Seat Belt Holder Attach |
Folks are using the door hinge bolts.
| Quote: | From: "Mike Kraus" <n223rv(at)wolflakeairport.net>
Subject: Overhead Seat Belt Holder Attach
Date: Thu, 3 May 2007 06:06:14 -0400
screws.
-Mike K
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/default.aspx?ss=Restaurants~Hotels~Amusement%20Park&cp=33.832922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=1&FORM=MGAC01
deutscht(at)rhwhotels.com Guest
Posted: Thu May 03, 2007 4:18 am Post subject: Overhead Seat Belt Holder Attach |
Where can one get these brackets?
Tom Deutsch
Posted: Thu May 03, 2007 4:50 am Post subject: Overhead Seat Belt Holder Attach |
They are fairly easy to fabricate but if you are lazy like me Jesse Saint
might sell you a couple. I believe he might also make you a tunnel
console/mapbox.
Mark
N410MR
[quote]From: "Tom Deutsch" <deutscht(at)rhwhotels.com>
Subject: RE: Overhead Seat Belt Holder Attach
Date: Thu, 3 May 2007 07:18:01 -0500
Tom Deutsch
Posted: Thu May 03, 2007 5:44 am Post subject: Overhead Seat Belt Holder Attach |
If you don’t want it under the same nuts as the door hinges, you can pop rivet a plate with nutplates in it to the cabin top and screw into the nutplates. This is a good way to fasten a lot of different things to the cabin top where desired.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus
Sent: Thursday, May 03, 2007 6:06 AM
-Mike K
[quote] [b]
Tim Olson
Posted: Thu May 03, 2007 6:02 am Post subject: Overhead Seat Belt Holder Attach |
I don't know if I have photos or not, but I can take some. I used
photos of Randy's to make mine. They're just a joggled piece of
aluminum. Jesse also takes it up a notch and has leather covers
for them, but you could use whatever leather/vinyl/cloth you want
if you wanted them covered.
Tom Deutsch
Posted: Thu May 03, 2007 6:32 am Post subject: Overhead Seat Belt Holder Attach |
A photo would be great! Does the aluminum tend to bend out of shape
when used or do you make them just loose enough that the belt just slips
in? When flying solo does the pass belt stay secured ok?
Tom Deutsch
Flying 35 great hours, woorkin' out various issues.
Tim Olson
Posted: Thu May 03, 2007 7:13 am Post subject: Overhead Seat Belt Holder Attach |
They do bend down some, but just use a little stiffer material
and they'll stay pretty good. They're plenty loose to
just slip the belt in. When solo, I can leave the other
belt in, but the buckles jingle, so I usually pop it out
and let it sit on the back seat. I attached a photo that
I dug up that was in the photos area of my site. It's
the hangers Van's RV-10 has. Mine are a little wider, and
I attached them to the rear door hinge instead of the front,
but the concept is the same.
Tom Deutsch
53.72 KB |
375 Time(s) |
Posted: Thu May 03, 2007 9:20 am Post subject: Overhead Seat Belt Holder Attach |
I usually suggest hooking up the unused shoulder harnesses to the seatbelt
when not being used. That's one projectile I would like to have "tied off"
if I was in an accident or in turbulence. When stuff starts happening, the
last thing you want is to have seatbelts dangling in your face. In fact, we
always leave the rear seat belts fastened as if someone was in the seat and
that also acts as a retainer for the baggage area in case something wanted
to fly forward in a sudden stop situation.
Jesse Saint
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Tim Olson
Posted: Thu May 03, 2007 9:44 am Post subject: Overhead Seat Belt Holder Attach |
That's a great suggestion. It's the little things that count.
I'll have to start doing that. Thanks for posting!
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
dav1111(at)suddenlink.net Guest
