n616tb(at)btsapps.com Guest
Posted: Thu May 03, 2007 11:43 am Post subject: Flying without gear leg fairings |
Hi all,
I have been flying my RV-6 without wheel pants or leg fairings since October
when it first took to the air. I had my wheel pants fitted but not the leg
fairings. I am wondering if anyone sees a reason why I can't fly with the
wheel pants on, and the leg fairings off. At least till I find another day
I can spend working on it to fit the leg fairings. Too much flying to do
and not enough days to work on it.
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Dale Ensing
Posted: Thu May 03, 2007 5:31 pm Post subject: Flying without gear leg fairings |
Tim,
I flew my 6A for several hours with just the wheel pants. No leg
fairings and no lower intersection fairings.
Dale Ensing
Description: |
 Download |
Filename: |
densing@carolina.rr.com.vcf |
Filesize: |
112 Bytes |
Downloaded: |
190 Time(s) |
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu May 03, 2007 10:41 pm Post subject: Flying without gear leg fairings |
In a message dated 5/3/2007 2:44:36 PM Central Daylight Time, n616tb(at)btsapps.com writes:
Quote: | I am wondering if anyone sees a reason why I can't fly with the
wheel pants on, and the leg fairings off. |
Sure- your carbon signature will be higher- put on the leg fairings and enjoy the efficiency improvement! Better yet, try a leg fairing on one side and a pant on the other. You never know, you might like it like that- somewhere on your plane should be a big sign that says "EXPERIMENTAL", so whatever floats yer boat.
(we now return you to your regularly scheduled ?: Can't think of any particular reason not to fly with your pants on and your leg thingies off, unless it has something to do with the mile-high club or somethin'...)
Mark & DO NOT ARCHIVE
See what's free at AOL.com.
_________________ From The PossumWorks... |
Posted: Fri May 04, 2007 4:56 am Post subject: Flying without gear leg fairings |
Exactly what I wanted to hear. Thanks Dale.
I was just wanted to make sure they would be stable without the leg fairing
and in particular the lower fairing. I will put leg fairings on, but want
to keep the airplane flying as I get each step done.
Thanks again to all answers
[quote] --
tcervin(at)valkyrie.net Guest
Posted: Fri May 04, 2007 5:23 am Post subject: Flying without gear leg fairings |
Tim, I flew last season with just the wheel pants on my RV6-A.....No
problems.
Tom in Ohio
crowbotham(at)hotmail.com Guest
Posted: Sun May 06, 2007 7:25 am Post subject: Flying without gear leg fairings |
Hi Tim,
We flew our 8A with on the wheel pants on for about 6 months - No problem.
With that said - when you get the gear leg and intersection fairings
installed you will see a very nice increase in cruise speed!
One note I would suggest that you install your main gear fairings first and
fly. You can then install the nose wheel fairing and may avoid a rudder tab,
if needed.
Chuck & Dave Rowbotham
RV-8A
Quote: | From: "Tim Bryan" <n616tb(at)btsapps.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: RE: Flying without gear leg fairings
Date: Fri, 4 May 2007 07:55:34 -0500
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/default.aspx?ss=Restaurants~Hotels~Amusement%20Park&cp=33.832922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=1&FORM=MGAC01
